" /> Finding out the state the call originated from. - Genesys CTI User Forum
Author Topic: Finding out the state the call originated from.  (Read 3193 times)
Offline siddharth.taneja
« on: April 03, 2009, 11:47:21 AM »
The setup is of an inbound contact center, and people from all the regions would be using the same toll-free-number to get to the contact center.
I need to route the calls on the basis of the zonal location of the customer. Is there a way of finding out which state the call originated from?
Thanks in advance.
Siddharth.
Offline Adam G.
  • Still Gorgeous.......
Re: Finding out the state the call originated from.
« Reply #1 on: April 03, 2009, 01:11:47 PM »
I guess you're using an 00800 number. In this case you need to talk to your service provider if ANI\CLI is supplied.
Offline Adam_W
« Reply #2 on: April 06, 2009, 01:57:03 PM »
Yes, make sure the caller's CLI is presented and then you can retrieve the areacode/prefix from the ANI, which should tell you where they are calling from.
There are two functions in IRD which might make this easier if you're in the USA - NPA and NPANXX.  NPA returns the first 3 digits of the ANI which should let you find out the area code.  NPANXX returns the first 6 digits to give you the area code and prefix.
