" /> [RESOLVED] Agent routing with genesys statistics CMS (AVAYA) problems - Genesys CTI User Forum
Author Topic: [RESOLVED] Agent routing with genesys statistics CMS (AVAYA) problems  (Read 5617 times)
Offline Xavier
Hello !
We study a way to do direct routing to agents when customers recall.
Our problem is that actually statistics are getting from CMS (behind an AVAYA ACD), and when directly routing to an agent from genesys all CMS statistics from these calls aren't referenced like "normal calls".
In example a normal call is counted on acdcalls (in hourly agent table from the CMS) whereas a direct agent call from genesys is counted on auxincalls. Moreover lots of time stats aren't well valued and it's even worse on split table where direct agent calls aren't referenced at all.
Did someone knows if it's possible to call from genesys a script or a method of the ACD with parameters (like agent loginACD) so the ACD do the routing (like that calls will be well followed in stats) ?
Or did someone got others ideas so stats in CMS ok ?
Thank you (Sorry if my english is so so)
« Last Edit: April 08, 2009, 09:13:26 AM by Xavier »
Offline bcyk
Re: Agent routing with genesys statistics CMS (AVAYA) problems
« Reply #1 on: April 07, 2009, 01:17:06 PM »
Not understand your problem exactly but below info may help if Genesys URS is used in the environment
http://www.sggu.com/smf/index.php/topic,3452.0.html
or search keyword in the web-site "route-thru-queue"
Offline Xavier
« Reply #2 on: April 07, 2009, 02:47:44 PM »
That is exactly what I needed !
Thank you.
Only one more question, is the URS option mentionned ('route-thru-queue') a specific option for Genesys with avaya ? Because I don't find the definition in reference guide...
Offline bcyk
« Reply #3 on: April 07, 2009, 03:38:23 PM »
Yes, the option is for Avaya switch only
The option "route-thru-queue" is described in T-Server for Avaya Communication Manager manual.
It is not an URS option, however.
Offline Xavier
Re: [RESOLVED] Agent routing with genesys statistics CMS (AVAYA) problems
« Reply #4 on: April 08, 2009, 09:16:45 AM »
Thank you bcyk.
I'll do tests when ACD staff will have implement the DirectAgent option.
I'll post my results comments when it's done.
