" /> Call ID:0 - Genesys CTI User Forum
Author Topic: Call ID:0  (Read 3473 times)
Offline kishore
Call ID:0
« on: April 28, 2009, 07:51:26 PM »
Hi all,
I am getting this event error..and because of this call not transfering.
call id = 0
15:29:03.959 Int 04543 Interaction message "RequestMuteTransfer" received from 17 ("crcur")
@15:29:03.9592 [tsgctm] Distributing request RequestMuteTransfer
@15:29:03.9593 [mlink] Address [65647,t1,s1] (reqMuteTransfer)
Initiate Transfer
Reference ID:58d
Origination Address:Unknown, 65647
Destination Address:Unknown, 64012
@15:29:03.9595 [>>] FF 0A 00 1C 05 05 8D 08 04 00 30 09 00 00 36 35 36 34 37 31 09 00 00 36 34 30 31 32
@15:29:03.9853 [<<] FF 0A 00 2E 05 85 8D 08 08 00 30 09 00 08 36 35 36 34 37 31 09 00 16 36 34 30 31 32 78 04 10 06 2E 04 0A 03 3F 04 EC 5F 96 06 00 00 00 00
Progress
Reference ID:58d
Origination Address:Internal, 65647
Destination Address:CDN, 64012
Cause:1006
Connection Status:Invalid Called Dn
Origination TN:ec5f
Call ID:0
64012 CDN is valid and defined both on switch and CME. could some one help me what would be the reason
Offline SisB
Re: Call ID:0
« Reply #1 on: April 28, 2009, 07:57:46 PM »
Error 1006 means "1006 -  No free CDNs".
Is it external route? More detailed log will help.
Offline kishore
Re: Call ID:0
« Reply #2 on: April 28, 2009, 08:35:28 PM »
Hi SisB,
Please find the log as an attachment
connid 00f201aef33b9708
No free CDn's? my understanding of genesys is CDN's should be able to handle any number of calls right? if no target is available it should wait in Q or target as per logic.
its not external route. its internal
« Last Edit: April 28, 2009, 08:39:21 PM by kishore »
Offline SisB
Re: Call ID:0
« Reply #3 on: April 28, 2009, 09:28:54 PM »
Yes you are correct with your CDN understanding.
However, with this specific xfer request I see access for xfer request is specified as This DN (65647).
That is why it is getting no free error an no dial event generated. can you check the difference with the mute xfer request in connid: 00f201aef33b9715, if you are doing something differently.
« Last Edit: April 28, 2009, 09:40:32 PM by SisB »
