" /> Oracle Instance or Schemas - Genesys CTI User Forum
Author Topic: Oracle Instance or Schemas  (Read 2825 times)
« on: April 29, 2009, 04:50:32 PM »
Hi guys,
For Oracle, each component of Genesys needs an Instance or a Schema? Meaning the DB for ETL, ConfigServer, ODS, etc etc.
Offline catanirex
Re: Oracle Instance or Schemas
« Reply #1 on: April 29, 2009, 06:13:38 PM »
A schema :-)
Microsoft SQL vs Oracle
Server = instance
database=schema
Which means that you have one user/pw for every schema in Oracle.
In MSQL you can have the same user/pw for several dbs.
Hope this helps!
« Reply #2 on: April 29, 2009, 06:17:03 PM »
;D Yeah, it was! I had forgot Oracle at all...been years I don't work with it.
Thanks!
