" /> Identify DN from various Switch - Genesys CTI User Forum
Author Topic: Identify DN from various Switch  (Read 3132 times)
Ramkumar_TPS
« on: May 15, 2009, 09:54:29 AM »
I've a doubt in identify Dn from various switch.
I've switch ( for ex: abc,def ).
Both switch contain a DN named "3103".  Now i've registered both the Dn's with T-Server, to listen all the events of the DN's.
I received the events from T-Server.  Now my doubt is how to identify the event comes from T-Server is belongs to which DN.  i.e.,) "3103-abc" or "3103-def".
Please give me solution to resolve this issue.
Thanks & Regards,
S. Ramkumar
Offline S
Re: Identify DN from various Switch
« Reply #1 on: May 15, 2009, 02:16:36 PM »
  • do they have different aliases ? if so, run the query against that DN name and get the switch name.
    Ramkumar_TPS
    « Reply #2 on: May 15, 2009, 02:47:35 PM »
  • Does TServer support multiple switches? If so, how to identify the DN with respect to Switch?
    Offline ecki
    « Reply #3 on: May 15, 2009, 03:13:58 PM »
  • No. One TServer can be connected to only one switch at a time. There are exceptions like Cisco clusters but this is not your case I guess as you cannot have the same extension configured on each switch.
