" /> how to get agent status using tlib TqueryAddress - Genesys CTI User Forum
Author Topic: how to get agent status using tlib TqueryAddress  (Read 3772 times)
Zaman
« on: June 06, 2009, 04:57:47 PM »
I need to know the agent status using tlib. For this i tried the the following queries
TQueryAddress(this->serverHandle,
NULL,
"4201", // Extension ID
AddressTypePosition,
AddressInfoAddressStatus,
NULL);
NULL,
AddressTypeDN,
AddressInfoDNStatus,
NULL);
NULL,
"4201",
AddressTypeDN,
NULL);
with genesys starter application showing the status of the agent  "Ready"
In returning event it shows the status of the agent = AgentWorkModeUnknown
Can any body help me to figure out how i can get the agent status using tlib?
Re: how to get agent status using tlib TqueryAddress
« Reply #1 on: June 07, 2009, 11:22:26 AM »
  • Zaman,
    What PBX/switch do you have? Could you post here snippet of T-Server log showing your request and response (event)?
    Offline bcyk
    « Reply #2 on: June 07, 2009, 04:29:11 PM »
  • Responses for similar question can be found in
          http://www.sggu.com/smf/index.php/topic,4051.0.html
