" /> Chat call not getting routed - Genesys CTI User Forum
Author Topic: Chat call not getting routed  (Read 15732 times)
shri
« on: June 16, 2009, 03:43:28 PM »
Hi
    The chat call which is initiated from webapi server is not getting routed to an agent.I am using the ABC sample chat business process .When i cheked the logs the stat server is recognising the agent as not ready. Any idea why this is happening?
Re: Chat call not getting routed
« Reply #1 on: June 16, 2009, 04:17:34 PM »
  • Is the agent logged in a chat media? Any logs would be helpful you know? The magic balls are becoming more difficult to get...
    Offline catanirex
    « Reply #2 on: June 16, 2009, 05:39:04 PM »
  • Does the StatServer have a connection to InteractionServer?
    Is the option UseAgentCapacity true on URS?
    Does the chat agent/agent place have a Capacity Rule that allows chat?
    shri
    « Reply #3 on: June 17, 2009, 03:25:21 AM »
  • Hi,
        Yes the agent has logged into chat media.
    1. Stat server has connection to Interaction sever
    2. UseAgentCapacity is false
    3. There is a capacity rule but that allows chat.
    Statserver log:
    2009-06-16 22:12:45> Client: Sending message to urs_gts
    2009-06-16 22:12:45> Client: Message 'Info'
    'LONG_VALUE' 0
    'TM_LENGTH' 0
    'TM_SERVER' 1245208365
    'USER_REQ_ID' 0
    'REQ_ID' 7
    2009-06-16 22:12:45> Init: Capacity rule 'MMedia_CCRule' automatically assigned to agent '9992'
    2009-06-16 22:12:45> Status: Capacity snapshot for place 'Place_C_5002'('GTS_DEV'), agent '9992'('GTS_DEV') (CR='MMedia_CCRule')
      media_state    current_number  max_number      routable
    [ NR              0              1              0              ] <-- chat
    [ NR              0              1              0              ] <-- voice
    2009-06-16 22:12:45> Server: Event "_we_event_current_agent_status" has been sent to MCR Interaction Server[CR2CLTIIS50:8888:InteractionServer2]
    2009-06-16 22:12:45> Server: IxnEvent 'event_media_added' message:
    attr_actor_type [int] = 2 [AGENT]
    attr_actor_place_id [str] = "Place_C_5002"
    attr_actor_tenant_id [int] = 101
    attr_actor_agent_id [str] = "9992"
    attr_event_time [str] = "2009-06-17T03:12:45Z"
    attr_reason [int] = 0
    attr_place_id [str] = "Place_C_5002"
    attr_tenant_id [int] = 101
    attr_agent_id [str] = "9992"
    attr_media_type_name [str] = "chat"
    attr_media_type_state [int] = 0
    2009-06-16 22:13:02> Client: Client 372 Connected from '171.133.247.249'(port 3886)
    22:13:02.910 Trc 04521 New client 372 connected from '171.133.247.249'
    2009-06-16 22:13:02> Client: Creating Client 372
    22:13:02.910 Trc 04541 Message RegisterClient received from 372 ( 'contactserver')
    2009-06-16 22:13:02> Client: Message from contactserver(372) received
    2009-06-16 22:13:02> Client: Message 'RegisterClient'
    'CLIENT_NAME' 'contactserver'
    'LIB_INTERNAL_VERSION' 7
    'PROTOCOL' 'StatExchangeProtocol 2.0.4'
    22:13:02.910 Trc 04522 Client 372 authorized, name 'contactserver', type 'Unknown'
    2009-06-16 22:13:02> Client: Sending message to contactserver
    2009-06-16 22:13:02> Client: Message 'ClientRegistered'
    'STRING_VALUE' '7.2.002.05'
    'LONG_VALUE' 61
    'TM_LENGTH' 1245208382
    'TM_SERVER' 1245208382
    'USER_REQ_ID' 0
    'REQ_ID' 0
    22:13:02.972 Trc 04541 Message OpenDataStream received from 372 ( 'contactserver')
    2009-06-16 22:13:02> Client: Message 'OpenDataStream'
    'DATASTREAM_DATACONSUMER_URL' 'eServiceContactStat.jar'
    'DATASTREAM_DATASOURCE_NAME' 'contactserver'
    'DATASTREAM_TYPE' 1
    'PROTOCOL_VERSION_MINOR' 0
    'PROTOCOL_VERSION_MAJOR' 1
    'PROTOCOL_DATASOURCE_TYPE' 'MCR Universal Contact Server'
    'PROTOCOL_NAME' 'Data Stream Wraper protocol'
    'USER_REQ_ID' 0
    'REQ_ID' 1
    2009-06-16 22:13:02> Client: Message 'DataStreamOpeningFailure'
    'STRING_VALUE' 'Java Host Environment is not initialized'
    'LONG_VALUE' 13
    'TM_LENGTH' 0
    'USER_REQ_ID' 0
    'REQ_ID' 1
    22:13:03.019 Trc 04541 Message UnRegisterClient received from 372 ( 'contactserver')
    2009-06-16 22:13:03> Client: Message from contactserver(372) received
    2009-06-16 22:13:03> Client: Message 'UnRegisterClient'
    2009-06-16 22:13:03> Client: Client 372 Disconnected
    22:13:03.019 Trc 04524 Client 'contactserver' disconnected
    2009-06-16 22:13:03> Client: Removing Client contactserver
    2009-06-16 22:13:03> Status:  Agent '9992'([2009-06-16 22:13:03]WaitForNextCall)
      Place 'Place_C_5002'([2009-06-16 22:13:03]WaitForNextCall)
        Chat '5002@sw_cacon_multimedia'([2009-06-16 05:53:37]NotMonitored)
        Media Channel chat([2009-06-16 22:13:03]Available)
    2009-06-16 22:13:03> Client: Sending message to Genesys_Desktop-MODULE
    2009-06-16 22:13:03> Client: Message 'Info'
    'LONG_VALUE' 0
    'TM_LENGTH' 0
    'TM_SERVER' 1245208383
    'USER_REQ_ID' 0
    'REQ_ID' 11
    2009-06-16 22:13:03> Client: Sending message to Genesys Supervisor Desktop
    'LONG_VALUE' 0
    'TM_LENGTH' 0
    'USER_REQ_ID' 0
    'REQ_ID' 45
    2009-06-16 22:13:03> Client: Sending message to urs_gts
    'LONG_VALUE' 0
    'TM_LENGTH' 0
    'USER_REQ_ID' 0
    'REQ_ID' 7
    2009-06-16 22:13:03> Status: Capacity snapshot for place 'Place_C_5002'('GTS_DEV'), agent '9992'('GTS_DEV') (CR='MMedia_CCRule')
    [ R              0              1              1              ] <-- chat
    2009-06-16 22:13:03> Server: Event "_we_event_current_agent_status" has been sent to MCR Interaction Server[CR2CLTIIS50:8888:InteractionServer2]
    2009-06-16 22:13:03> Server: IxnEvent 'event_ready_for_media' message:
    attr_event_time [str] = "2009-06-17T03:13:03Z"
    2009-06-16 22:13:11> Server: IxnEvent 'event_properties_changed' message:
    attr_actor_type [int] = 1 [STRATEGY]
    attr_actor_strategy_id [str] = "Chat inbound strategy"
    attr_actor_router_id [str] = "urs_gts"
    attr_itx_id [str] = "00018a53EAWA004E"
    attr_state [int] = 2
    attr_itx_type [str] = "Inbound"
    attr_itx_subtype [str] = "InboundNew"
    attr_itx_prnt_itx_id [str] = ""
    attr_itx_queue [str] = "Chat inbound queue"
    attr_itx_media_type [str] = "chat"
    attr_itx_user_data [bstr] = TKVList:
      'ContactId' [str] = "0000Fa4VHJC50022"
      'Subject' [str] = "Some Subject"
      'EmailAddress' [str] = "a@b.com"
      'FirstName' [str] = "123"
      'LastName' [str] = "456"
      'ChatServerHost' [str] = "CR2CONVRU04"
      'ChatServerPort' [str] = "3003"
      'PegRejected' [int] = 1
    attr_itx_tenant_id [int] = 101
    attr_itx_received_at [str] = "2009-06-17T03:12:38Z"
    attr_itx_submitted_at [str] = "2009-06-17T03:12:38Z"
    attr_itx_submitted_to_router_at [str] = "2009-06-17T03:12:41Z"
    attr_itx_placed_in_queue_at [str] = "2009-06-17T03:12:38Z"
    attr_itx_submitted_by [str] = "ChatServer"
    attr_itx_is_online [int] = 1
    attr_itx_is_locked [int] = 0
    attr_itx_moved_to_queue_at [str] = "2009-06-17T03:12:38Z"
    attr_event_time [str] = "2009-06-17T03:13:11Z"
    attr_changed_prop [bstr] = TKVList:
    URS Log:
    TARGETS: Chat distribution for processing@ss_cit_chat_rtg_server.GA
    20:22:19.533_M_I_0ce001b31194c214 [13:01] current virtual queue: 01ffb030 id=57, nVQ=1-1d2abd0, priority=0, time=1245208358.0
        _M_I_ [17:0f] VQ(01ff8400) [at all 1 0] 1 target(s), flag=2a, guid: 0GTS_DEV||1|37|1|0|""|||00|00{}{}[]Chat distribution for processing@ss_cit_chat_rtg_server.GA
    20:22:19.533_M_I_0ce001b31194c214 [17:11] VQ(01ff8400) first available call: 0ce001b31194c214, reason=binding
    20:22:19.533_M_I_0ce001b31194c214 [13:03] call (virtual queue 01ffb030, id=57, priority 0, time 1245208358.0) waits for VQ 01ff8400 (name="") now
        _C_W_0000000000000000 [0D:03] default value (0) will be used for option targets_order
    20:22:19.533_M_I_0ce001b31194c214 [17:0e] virtual queue ""(id=57), VQ 01ff8400 (1 targets): SELECT ANY by statistic NONE(random )
        _M_I_0ce001b31194c214 [17:0b] VQ 01ff8400 target "Chat distribution for processing" (#1, 5-4 components): SELECT ANY by statistic StatAgentLoading(random)
        _M_I_0ce001b31194c214 [17:0b] component #1 9991: logged out
        _M_I_0ce001b31194c214 [17:0b] component #2 1118: logged out
        _M_I_0ce001b31194c214 [10:0c] tenant GTS_DEV Agent 9992: dn chat is ignored: other dn type(cfg)
        _M_I_0ce001b31194c214 [17:0b] component #3 9992: not ready
        _M_I_0ce001b31194c214 [17:0b] component #4 9993: logged out
        _M_I_0ce001b31194c214 [17:0b] component #5 9998: logged out
        _M_I_0ce001b31194c214 [17:0b] VQ 01ff8400 target "Chat distribution for processing": component was NOT SELECTED (4 0 1 33550496)
        _M_I_0ce001b31194c214 [17:0e] target Chat distribution for processing: not ready passed
        _M_I_0ce001b31194c214 [17:0e] virtual queue ""(id=57), VQ 01ff8400: target for routing was NOT SELECTED (0 0 0 1)
        _I_I_0ce001b31194c214 [07:0a] HERE IS WAIT (-1 sec)
        _I_I_0ce001b31194c214 [07:0a] HERE IS WAIT (30 sec)
        _C_W_0000000000000000 [0D:03] default value (0) will be used for option skip_targets
    20:22:19.533_B_I_0ce001b31194c214 [07:09] start chain of treatments
    20:22:19.533_I_I_0ce001b31194c214 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT), timers:10000
    « Reply #4 on: June 17, 2009, 05:05:53 AM »
  • Before the target object try to use the function UseMedia['chat'], that might help.
    shri
    « Reply #5 on: June 17, 2009, 05:16:37 AM »
  • Hi ,
        I am new to genesys . i am not getting u  properly. Could u pls explain me .
    You mean to say add a function called usemedia[chat] in strategy target
    shri
    « Reply #6 on: June 17, 2009, 09:11:30 AM »
  • More URS Logs:
    22:31:18.012_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1245216677, mem=0,51672,708,23,172,0)
        _M_I_0000000000000000 [10:20] try to route to agent "9993" (place "Place_C_6000", 1 ready DNs reported)
        _M_I_ [10:20] VQ(01ffba10) is ignored: other dn type(cfg)
        _M_I_0000000000000000 [10:20] try to route to agent "9992" (place "Place_C_5002", 1 ready DNs reported)
    22:31:20.012_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1245216679, mem=0,51672,708,23,172,0)
    22:31:22.012_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1245216681, mem=0,51672,708,23,172,0)
    22:31:24.012_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1245216683, mem=0,51672,708,23,172,0)
    shri
    « Reply #7 on: June 17, 2009, 12:21:24 PM »
  • someone pls temme a solution ....
    « Reply #8 on: June 17, 2009, 01:14:18 PM »
  • Hi,
    URS isn't able to determine right type of DN required to handle interaction. Please add new "Function" block to your strategy and use following function "UseMedia['chat']". Please insert this block before routing an interaction to the agents.
    shri
    « Reply #9 on: June 17, 2009, 01:48:37 PM »
  • Hi Rene,
    I have added usemediatype[chat] in strategy , then also the call didnt get routed
    the urs logs comes as below
    ..sent to CR2CLTIIS50:8888(fd=580)
    06:38:34.435_M_I_059301b328b6e002 [13:02] entering virtual queue "VQ_CHAT"
        _M_I_ [17:0f] VQ(02005f60) [at all 1 0] 1 target(s), flag=a, guid: 0GTS_DEV|VQ_CHAT|1|37|1|0|""|||00|00{}{}[]Chat distribution for processing@ss_cit_tcc_con_rtg_pri.GA
    06:38:34.435_M_I_059301b328b6e002 [17:11] VQ(02005f60) first available call: 059301b328b6e002, reason=binding
    06:38:34.435_M_I_059301b328b6e002 [13:03] call (virtual queue 020040d0, id=2, priority 0, time 1245245911.0) waits for VQ 02005f60 (name="VQ_CHAT") now
    06:38:34.435_M_I_059301b328b6e002 [17:0e] virtual queue "VQ_CHAT"(id=2), VQ 02005f60 (1 targets): SELECT ANY by statistic NONE(random )
        _M_I_059301b328b6e002 [17:0b] VQ 02005f60 target "Chat distribution for processing" (#1, 5-3 components): SELECT ANY by statistic StatAgentLoading(random)
        _M_I_059301b328b6e002 [17:0b] component #1 9991: not ready
        _M_I_059301b328b6e002 [17:0b] component #2 1118: logged out
    06:38:34.435_M_I_ [10:0a] object Place_C_5002|GTS_DEV| is unblocked
    06:38:34.435_M_I_ [10:0a] object 9992|GTS_DEV| is unblocked
    06:38:34.435_M_I_ [10:0a] object chat|| is unblocked
        _M_I_059301b328b6e002 [10:0c] tenant GTS_DEV Agent 9992: dn chat is ignored: other dn type(cfg)
        _M_I_059301b328b6e002 [17:0b] component #3 9992: not ready
        _M_I_059301b328b6e002 [17:0b] component #4 9993: logged out
        _M_I_059301b328b6e002 [17:0b] component #5 9998: logged out
        _M_I_059301b328b6e002 [17:0b] VQ 02005f60 target "Chat distribution for processing": component was NOT SELECTED (3 1 1 33574016)
        _M_I_059301b328b6e002 [17:0e] target Chat distribution for processing: not ready passed
        _M_I_059301b328b6e002 [17:0e] virtual queue "VQ_CHAT"(id=2), VQ 02005f60: target for routing was NOT SELECTED (0 0 0 1)
        _I_I_059301b328b6e002 [07:0a] HERE IS WAIT (-1 sec)
        _I_I_059301b328b6e002 [07:0a] HERE IS WAIT (30 sec)
    shri
    « Reply #10 on: June 17, 2009, 01:54:03 PM »
  • Also when one chat call is inititated from webapi ,the number of interactions keeps increasing infinitely in the vrp.
    How to resolve this . Its urgent. Any pointers wud be helpfull.
    Thanks in advance.
    « Reply #11 on: June 17, 2009, 02:14:24 PM »
  • Please check that StatServer used by URS is connected to Interaction Server.
    shri
    « Reply #12 on: June 17, 2009, 02:26:45 PM »
  • Yes the stat server used  by URS has connection to Interaction server .....
    « Reply #13 on: June 17, 2009, 09:02:00 PM »
  • Post the respecting logs please
    Offline YevgeniyP
    « Reply #14 on: June 18, 2009, 04:09:26 AM »
  • for 7.x solution you do not need any chat  DNs and UseMedia['chat'].
    You do need UseAgentCapacity =true in URS.
    in URS log you have:
    it means agent is ready from URS point of view.
    The question - do you have all your strategies in chat business process activated?
    Have you configured properly routing strategy in this business process?
    If you stop your solution, cleanup Ixnteraction server DB, start solution and submit 1 chat interaction, interaction server log will show you what happeneing with interaction.
