" /> OCM hangs while retrieving call list.... - Genesys CTI User Forum
Author Topic: OCM hangs while retrieving call list....  (Read 3675 times)
Manish
« on: August 12, 2009, 10:07:04 AM »
Sample DBServer Log:
DBClient Oracle, Copyright (c) 1997-2006 Genesys Telecommunications Labs, Inc.
All Rights Reserved
Db Client version:        7.2.000.03
DB Common part version:    7.2.000.03
Vendor supported versions: Oracle 8i, 9i
Build on 'powerpc-aix4.3.2.0'
Oracle: id='6.1' req='-1' Connection to multiserver created, host 'aixctidb01', port '42943', socket '4'
+0028  MSG_STARTDB status='6'
Oracle: id='6.1' req='3' Protocols versions: dbclient='00010003' dbserver='00010003' dblib='00010002'
+0000  Open DB: username = 'cticall', database = 'CTIP', dbserver = 'CTIP'
+0151  MSG_DBOPENED status='DBM_SUCCESS' msg='Open DB success'
10:49:43.979 Dbg 10743 'Oracle: 6.1' is spare
10:49:43.979 Dbg 10739 Oracle: id='6.1' req='0' Chmode to extended packet on sock 4
10:49:43.982 Dbg 10741 'App: 6' has put request id='4' into queue
10:49:43.982 Dbg 10737 Forwarding request '4' from 'App: 6' to 'Oracle: 6.1'
10:49:43.982 Dbg 10743 'Oracle: 6.1' is spare
10:49:44.022 Dbg 10749 Forwarding response '4.1' from 'Oracle: 6.1' to 'App: 6'
10:49:44.022 Dbg 10749 Forwarding response '4.2' from 'Oracle: 6.1' to 'App: 6'
10:49:44.022 Dbg 10739 Oracle: id='6.1' req='4' SQL: SELECT count(*) FROM user_views WHERE view_name='TEST_PROD'
+0039  Executed SQL statement 'SELECT', start retrieve records...
+0039  MSG_RETRIEVED2 status='DBM_SUCCESS'
+0039  MSG_RETRIEVED status='DBM_NOMORE'
10:49:44.174 Dbg 10741 'App: 6' has put request id='5' into queue
10:49:44.174 Dbg 10737 Forwarding request '5' from 'App: 6' to 'Oracle: 6.1'
10:49:44.174 Dbg 10743 'Oracle: 6.1' is spare
10:49:44.204 Dbg 10749 Forwarding response '5.1' from 'Oracle: 6.1' to 'App: 6'
10:49:44.204 Dbg 10749 Forwarding response '5.2' from 'Oracle: 6.1' to 'App: 6'
10:49:44.204 Dbg 10739 Oracle: id='6.1' req='5' SQL: SELECT count(*) FROM user_tables WHERE table_name='TEST_PROD'
+0027  Executed SQL statement 'SELECT', start retrieve records...
+0030  MSG_RETRIEVED2 status='DBM_SUCCESS'
+0030  MSG_RETRIEVED status='DBM_NOMORE'
10:49:47.902 Dbg 10741 'App: 6' has put request id='6' into queue
10:49:47.902 Dbg 10737 Forwarding request '6' from 'App: 6' to 'Oracle: 6.1'
10:49:47.902 Dbg 10743 'Oracle: 6.1' is spare
10:49:48.060 Dbg 10749 Forwarding response '6.1' from 'Oracle: 6.1' to 'App: 6'
10:49:48.060 Dbg 10739 Oracle: id='6.1' req='6' SQL: CREATE TABLE Test_Prod(record_id INTEGER NOT NULL UNIQUE,phone VARCHAR2(64) NOT NULL,phone_type INTEGER NOT NULL,record_type INTEGER NOT NULL,record_status INTEGER NOT NULL,call_result INTEGER NULL,attempt INTEGER NOT NULL,dial_sched_time INTEGER NULL,call_time INTEGER NULL,daily_from INTEGER NOT NULL,daily_till INTEGER NOT NULL,tz_dbid INTEGER NOT NULL,campaign_id INTEGER NULL,agent_id VARCHAR2(32) NULL,chain_id INTEGER NOT NULL,chain_n INTEGER NOT NULL,treatments VARCHAR2(255) NULL,CoCode VARC ...
+0158  MSG_SQLEXECUTED status='DBM_SUCCESS'
10:49:48.062 Dbg 10741 'App: 6' has put request id='7' into queue
10:49:48.062 Dbg 10737 Forwarding request '7' from 'App: 6' to 'Oracle: 6.1'
10:49:48.062 Dbg 10743 'Oracle: 6.1' is spare
10:49:53.076 Std 05023 Process 'dbclient_oracle' stopped  <<<<<<<<<<<<  this should not have occured
  /dbclient_oracle
    pid                      = 1868008
    id                        = 4
    expiration_time          = 2009-08-06T10:49:52
    client copy              = 0
Manish
Re: OCM hangs while retrieving call list....
« Reply #1 on: August 12, 2009, 10:08:21 AM »
Please advice what could be the possible cause for this.
Marked as best answer by on Today at 01:08:35 PM
« Reply #2 on: August 12, 2009, 03:59:03 PM »
  • Undo Best Answer
  • What versions of:
    - OCM
    - OCS
    - DBServer
    - Oracle
    Are you using?
