" /> SIP Endpoint for Genesys SIP TServer - Genesys CTI User Forum
Author Topic: SIP Endpoint for Genesys SIP TServer  (Read 8545 times)
Offline jamesmurphyau
« on: September 17, 2009, 01:25:55 AM »
Hey Guys
We are looking for a SIP endpoint to run on the Genesys SIP TServer.
Preferably free or open source and needs to have third party call control.
Thanks.
« Last Edit: September 17, 2009, 07:13:04 AM by skoom »
Offline Timur Karimov
Re: SIP Endpoint for Genesys SIP TServer
« Reply #1 on: September 17, 2009, 11:52:29 AM »
Why u don't take Genesys SipEndPoint what came in-box with Genesys Agent Desktop ? It's also have the source code and fully cover you request.
WBR Timur
Offline Dionysis
« Reply #2 on: September 17, 2009, 01:05:52 PM »
Can you use this end point with no GAD licenses?
« Reply #3 on: September 22, 2009, 07:04:22 AM »
[quote author=Dionysis link=topic=4689.msg20967#msg20967 date=1253192752]
Well, good question. My answer yes and no at the same time. Because Genesys SIPEndPoint to simple to have the complete call controlling modules. It has been written for work  in the close cooperation with GAD. But it have the own source code in box based on Genesys .Net SDK and u can rewrite it to remove AIL-based modules(that used GAD and integration license) to use the pure T-Library request.
Also if u have the complete Genesys Universal SDK u already got the 2 or 3(i don't remember exactly) complete SIP Softphone project in the included sample source codes.
WBR Timur.
« Reply #4 on: September 23, 2009, 02:59:30 AM »
I noticed that but seen there was none in the Java SDK which is what we will be using. It looked Windows specific.
« Reply #5 on: September 23, 2009, 04:42:46 AM »
it really depends on whast you want to do. I have wrote the whole SIP phone using Microsoft RTC and found it to be more sufficient.
There is obviously an Asterisk's based SIP phone (quite a few of them out there) that you can build upon as well...
If I am not mistaken, Genesys sample is built on top of Microsoft RTC as well... We looked at pro's and con's of using RTC, and at the end of the day decided that multi-platform support is NOT what we really care about, since we cannot imagine a situtation where a corporate client would not use Windows...
« Reply #6 on: September 23, 2009, 05:09:34 PM »
[quote author=victor link=topic=4689.msg21030#msg21030 date=1253680966]
exactly
well, using a unix-like desktop may be a more chipper for a first point of view. but support of this solution - same time may be looks like a sysadmin hell. anyway, for our test we found only one complete free and good soft phone for linux what work fine and good with Genesys Sip Server- Twinkle.
