" /> Config Import Wizard times out - Genesys CTI User Forum
Author Topic: Config Import Wizard times out  (Read 3233 times)
Offline Scottyjohn
« on: October 30, 2009, 12:52:45 PM »
Hi all,
I have been trying to export a config using the CIW but keep getting the following error?  Is there a timeout somewhere that needs adjusting.  Looked in confserv options but it just has soap port to be configured nothing else
Error is:
SOAP Server Error: Wrong responce document or timeout elapsed
Any help appreciated
Offline steveb
Re: Config Import Wizard times out
« Reply #1 on: July 04, 2010, 04:29:29 PM »
Any luck with this? I'm having the same problems.
Cheers
Steve
Offline catanirex
« Reply #2 on: July 04, 2010, 04:43:17 PM »
Sound like confserv.cfg does not has the SOAP port defined?
Add and restart :-)
Offline rpenney
« Reply #3 on: July 05, 2010, 07:58:39 AM »
or your config is really big.
I had this with a config from a hosted provider servicing about 3000 agents with approx 550 applications. It imported correctly (mostly) but the response was an error in the GUI.
Have a look at the config server logs, turn up the debugging if you have to. You should see the objects being inserted in the DB.
Offline Krister
« Reply #4 on: July 15, 2010, 08:24:18 AM »
Same problem...  :(
Time for a request to investigate the issue to Genesys perhaps?
