" /> dailer dailed outbound calls and agent dailed outbound stats - Genesys CTI User Forum
Author Topic: dailer dailed outbound calls and agent dailed outbound stats  (Read 3437 times)
Offline kevin
can we get stats in pulse for dailer dailed outbound calls and agent dailed outbound calls?
thanks in advance
Re: dailer dailed outbound calls and agent dailed outbound stats
« Reply #1 on: May 14, 2010, 02:05:25 PM »
Yes, create a filter, if the call contains GSW_PHONE then it is a dialer call, if not it is a manual call.
Offline kevin
« Reply #2 on: May 14, 2010, 02:43:26 PM »
Hi Cav,
Are you talking about filter in DMA?
« Reply #3 on: May 14, 2010, 02:54:58 PM »
In the StatServer, which can be done using DMA if you want.
Offline kevin
« Reply #4 on: May 14, 2010, 05:43:59 PM »
Hi Cav,
I updated a routing with key GSW_PHONE value = dailer, created a filter on statserver and a formula on pulse report to check the and print call type. Am i doing it right?
please advice
THanks
« Last Edit: May 15, 2010, 04:32:53 PM by kevin »
« Reply #5 on: May 15, 2010, 06:21:31 PM »
Filter should be:
PairExist("GSW_PHONE",*) for OCS Outbound calls
and
~(PairExist("GSW_PHONE",*)) for agent outbound calls.
Offline kevin
« Reply #6 on: May 17, 2010, 05:10:20 PM »
HI Cav,
could you pls let me know the formula/stat to display with that filter  assigned in pulse.
I dont know if we could assign filter to coustom formula and display that.
thanks
« Last Edit: May 17, 2010, 07:45:03 PM by kevin »
