" /> Installing Dialogic D120 card - board ID query - Genesys CTI User Forum
Author Topic: Installing Dialogic D120 card - board ID query  (Read 2929 times)
Offline seanh
« on: June 02, 2010, 03:59:15 PM »
Hi all,
We have a 2nd D120JCT Dialogic card that i need to install in my VT server and i wanted to know whether i need to leave the Board ID wheel set to "0" (zero) or is it best to set it to "1"
Can anyone let me know please
Thanks in advance
Regards,
Sean
Offline stevehaz
Re: Installing Dialogic D120 card - board ID query
« Reply #1 on: June 03, 2010, 11:02:21 AM »
Def set it to 1. If not both boards will report as ID 0 and cause conflicts. Make sure you have your boards linked by a CT Bus ribbon cable too.
Offline seanh
« Reply #2 on: June 03, 2010, 02:26:40 PM »
thanks for your input Steve
the 2nd card has gone in without a problem  :)
so, once i get my new VTO license key from Genesys, i will have 12 more ports to play with
Can anyone confirm other than config manager activities, is there any config required on the VTO server / dialogic side ?
FYI, our main genesys server is solaris and VTO is a windows server.
TIA
Sean
