" /> Preserving Caller's ID on Call Transfer - Genesys CTI User Forum
Author Topic: Preserving Caller's ID on Call Transfer  (Read 2930 times)
Offline anupamjain
« on: July 13, 2010, 11:43:17 AM »
I am using Genesys Voice Portal 7.6. For a bridge/blind transfer the caller ID that goes out is the PRI line's number (basically GVP's caller ID) and not the original caller's number. Is it possible to change this behaviour?
Thanks!
Anupam
Offline saz
Re: Preserving Caller's ID on Call Transfer
« Reply #1 on: July 20, 2010, 07:27:34 AM »
  You can change it at application level under <transfer> tag by using signalvar's attribute.
Offline anupamjain
« Reply #2 on: July 27, 2010, 06:02:40 AM »
Thanks. But it doesn't seem to work on GVP 7.6. Does it only work on later versions?
I searched for it on the web and it seems its a VG extension?
http://developer.voicegenie.com/reference.php?ref=variablesdetails#signalvar
Anupam
