" /> T-Server Upgrade 7.2 - 7.6 Nortel x.25 NCS2000/2100 (DMS-100) Connect Problem - Genesys CTI User Forum
Author Topic: T-Server Upgrade 7.2 - 7.6 Nortel x.25 NCS2000/2100 (DMS-100) Connect Problem  (Read 4435 times)
Offline smarsolais
Upgrading T-Server from 7.2 to 7.6
I'm getting a problem connecting to the switch when trying T-Server 7.6.0.13 and 7.6.0.9 Nortel NCS2000/2100 over x.25 switch link.
I have simply created a new T-Server from 7.6 template in CME and I imported all options from a running T-Server 7.2 application. Theoritically, these options, I thought, would have been sufficient to at least connect to the switch regardless of new features available in the new version.
What is strange here is that I see that T-Server sends a DV-APPL-LOGON to the switch but I do not get any error back from the switch. I only get a timeout from the T-Server after 10 seconds waiting.
@07:07:33.7210 [tsgctm] Link [1,s0] restart timer expired. Opening link.
@07:07:33.7210 [tsgctm] Link [1,s0] start
(link_start) link [1] 'link-x25-1' start
@07:07:33.7210 x25_start(id=1)
@07:07:33.7210 [tsgctm] Link [1,s0] Changing state to 1
link 1 started (fd 1)
@07:07:33.7990 [slog] Link [1,s1] (rxLinkUpPacket)
@07:07:33.7990 [slog] Link [1,s1] (startSessionOpen)
@07:07:33.7990 [tsgctm] Link [1,s1] Changing state to 2
@07:07:35.7990 [tsgctm] Link [1,s2] openSession
@07:07:35.7990 [tsgctm] Link [1,s2] Changing state to 2
@07:07:35.7990 [slog] Link [1,s2] (sysReqSessionOpen)
@07:07:35.7990 [slog] Switch [sUNK] InvokeID FREE 84
@07:07:35.7990 [slog] Switch [sUNK] InvokeID GET  85
host: invoke
invoke id = 0x85
operation = DV_APPL_LOGON
networkNodeID 0x1  01
serviceID 0x1  01
serviceVersion 0x1  0e
businessGroupID 0x2  04 03
applicationID 0x1  01
password 0x6 REVECM
@07:07:35.7990 [>>] A1 21 02 02 00 85 02 01 01 30 18 80 01 01 81 01 01 82 01 0E 83 02 04 03 84 01 01 85 06 52 45 56 45 43 4D
@07:07:45.7990 [tsgctm] Link [1,s2] session timer expired. Closing link.
@07:07:45.7990 [tsgctm] Link [1,s2] stop
@07:07:45.7990 [tsgctm] LinkReg [1, act=0] clearAll
@07:07:45.7990 [tsgctm] Link [1,s2] Changing state to 0
@07:07:45.7990 [slog] Link [1,s0] (stopped)
(link_stop) link [1] 'link-x25-1' stop
@07:07:45.7990 (x25_stop)[1/0]: reader timer is deleted
@07:07:45.8770 (x25_stop) link[id=1/fd=1]: stopped
Moreover, I can see from my EICON card tool that when the attempt is made to logon to the switch that an x.25 session is opened through the link so I'm thinking this confirms the link parameters are fine.
If I stop the 7.6 versions and start over the 7.2 version then 7.2 will start fine which seems to indicate the switch is not the issue here.
The LEC software load of the DMS is 14.
Offline Fra
Have you checked the TServer release notes and deployment guide? You jumped two major releases up, some options may be deprecated or removed. Also, I guess you have checked whether TServer 7.6 supports your switch version especially on a X.25 link, haven't you?
Fra
Offline jfberni
Hi there,
One check new option on Tserver 7.6 into release notes.
Second you might check your Switch option, different option have to be added. Because the way Genesys handle their call in 7.6 is very different from 7.2. That could explain why 7.2 works and 7.6 doesn't work.
Regards,
J-F
