" /> IRD 7.6 on Windows 2008 Server? - Genesys CTI User Forum
Author Topic: IRD 7.6 on Windows 2008 Server?  (Read 2693 times)
Offline catanirex
« on: January 20, 2011, 01:12:53 PM »
Any one out there that knows about some tricks that makes it possible to install IRD 7.6 on a Windows 2008 server?
I know that it is not supported, but I still need it..
Have tried with compatibility mode on setup.exe, and by adding the OS into the xml file - no luck :(
Offline kubikle
Re: IRD 7.6 on Windows 2008 Server?
« Reply #1 on: January 21, 2011, 01:46:03 AM »
Install IRD on any supported platform. manually copy all files from directory where IRD was installed to Windows 2008 server in some folder. Check that files gs.dll and unilogin.dll are among them (if not they were installed in common for all genesys componets directory, like c:\Program Files\Common Files\GCTI - take them from there).
Manually register gs.dll (with Regsvr32 for example) and Viewserver.exe (Viewserver.exe /Regserver).
