" /> SSG - How's it work ? - Genesys CTI User Forum
Author Topic: SSG - How's it work ?  (Read 2697 times)
Offline CTI-traveller
« on: February 24, 2011, 03:07:43 AM »
Hi All,
I 'm planning to use  SSG version 8.1.03 to make mass outbound call to external recipients.
I want to handle SSG to make outbound call as 3 times mnks ax retries. And within tries, interval should be 5 mins.
Which configuration I have to set to get this feature? And I want to know how SSG calculate TTL(time to live).
Another question is if I get the reason "unknownexternalerror" when the recipient take long time to pickup and miss call, what does this reason stand for?
Thanks in advance. I 'm looking forward to any reply.
Rgds,
CTI-User
Re: SSG - How's it work ?
« Reply #1 on: February 24, 2011, 11:54:20 AM »
[quote]I want to handle SSG to make outbound call as 3 times mnks ax retries. And within tries, interval should be 5 mins.[/quote]
Number of retries (attempts) is specified in the HTPP request - parameter 'MaxAttempts'. Interval between the attempts is (not 100% sure about it) defined by the parameter 'pacing.NextRetryIntervalSecs' stored in 'SSG' section of application's options.
[quote]And I want to know how SSG calculate TTL(time to live).[/quote]
I think TTL is calculated from the moment the request is accepted by SSG. And lasts for specified number of (mili)seconds.
[quote]Another question is if I get the reason "unknownexternalerror" when the recipient take long time to pickup and miss call, what does this reason stand for?[/quote]
You would need to check the logs to find out what happened to the call as SSG didn't receive any valid information allowing classification of the error.
