" /> How to make a composer project to become a java related project? - Genesys CTI User Forum
Author Topic: How to make a composer project to become a java related project?  (Read 5114 times)
Offline kevinwang
« on: February 24, 2011, 03:13:25 PM »
Hi, Friend,
I tried to develop a backend jsp block in a composer project.
However, my jsp code can not be recognized as a java related code,
that means it will not be compiled automatically, it's very hard to debug.
Is there anything I can do to make my composer project become a automatic compiled java related project?
Thanks in advance.
Kevin
Offline kevinwang
Re: How to make a composer project to become a java related project?
« Reply #1 on: February 24, 2011, 03:23:36 PM »
another thing is if I add a external jar into this composer project, which directory should I put it in?
/include? /WEB-INF/lib ?  /src ?
Offline kevinwang
« Reply #2 on: February 24, 2011, 03:36:34 PM »
[quote author=kevinwang link=topic=6203.msg27009#msg27009 date=1298561016]
myabe it should be put into tomcat's lib directory,  I found json.jar there.
« Reply #3 on: February 25, 2011, 09:07:55 AM »
Hi Kevin,
You can find the answer in Composer's help:
[quote]If any custom backend logic pages use libraries, place the libraries in the Java Composer Project’s WEB-INF/lib directory. This directory typically contains JAR files that contain Java class files (and associated resources) required for the application. Note: The Tomcat application server should be restarted after changing any JAR files in this folder.[/quote]
Offline kevinwang
« Reply #4 on: March 02, 2011, 03:49:51 PM »
[quote author=René link=topic=6203.msg27019#msg27019 date=1298624875]
Hi Kevin,
Thank you, René.
I haven't got a chance to put it in to composer project/WEB-INF/lib directory, At least, it works in tomcat's common lib directory, since I found json.jar there.
However, it must be better to put jar into directory only related to project.
