" /> Please help me , Voive Treatment Server down each week - Genesys CTI User Forum
Author Topic: Please help me , Voive Treatment Server down each week  (Read 11295 times)
Offline catvrom01
« on: March 21, 2011, 03:55:01 PM »
Hi guy .
Can you help me in this problem.
Each week  the VTO Genessy server stopped.
The service is instaled on Windows Server 2003.
The version of Voice Treatment Server  is 5.1.
And also Voice Treatment Manager is 5.1.
In Event Viewer is see only:
The Genesys Voice Treatment Server service terminated unexpectedly.  It has done this 2 time(s).
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Do you have any ideea from what is down each week or what can i do to stop this?
Many Thanks
Offline Fra
Re: Please help me , Voive Treatment Server down each week
« Reply #1 on: March 21, 2011, 04:19:42 PM »
[quote author=catvrom01 link=topic=6274.msg27272#msg27272 date=1300722901]
Hi guy .
Many Thanks
You should be looking at the VTS log files.
Fra
Offline catvrom01
« Reply #2 on: March 21, 2011, 05:03:51 PM »
Hi
I see now the logs.
I see that in one minute create 40 files with logs . One log have 5 MB.
And create many logs.
In all the logs i see only this line who repeat :
16:10:09.379 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
16:10:09.379 Dbg 21026 Channel 7 finished playing node 19 ("Attach data to the call info") result = 0
16:10:09.379 Dbg 21024 Channel 7 start playing node 23 ("")
16:10:09.379 Dbg 21026 Channel 7 finished playing node 23 ("") result = 0
16:10:09.379 Dbg 21024 Channel 7 start playing node 19 ("Attach data to the call info")
[b]I see that normaly must change the Channel, like in this log:[/b]
17:44:48.179 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
17:44:48.492 Trc 21021 Channel 11 started playing script 2351 ("FR_Menu_old")
17:44:48.492 Dbg 21024 Channel 11 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
17:44:48.492 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
17:44:51.789 Dbg 21026 Channel 14 finished playing node 5 ("FR_H4_Accueil réseau First Stop .wav") result = 0
17:44:51.789 Dbg 21024 Channel 14 start playing node 6 ("FR_H4_Accueil P Zéro Expérience.wav")
17:45:07.211 Dbg 22000 Invalid TLib message received from 65200(FR_TServer_760), wrong type of AttributeNetworkCallID
17:45:07.211 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
17:45:07.429 Dbg 22000 Invalid TLib message received from 65200(FR_TServer_760), wrong type of AttributeNetworkCallID
17:45:07.429 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
17:45:07.429 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
17:45:07.429 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
17:45:07.445 Dbg 21026 Channel 11 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 260
17:45:07.445 Trc 21022 Channel 11 finished playing script 2351 ("FR_Menu_old")
17:45:07.742 Trc 21021 Channel 12 started playing script 1879 ("FR_Attente")
17:45:07.742 Dbg 21024 Channel 12 start playing node 2 ("FR_Attente_8kHz 8 bits uLaw.wav")
17:45:07.742 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
17:45:07.898 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
17:45:11.664 Dbg 21026 Channel 14 finished playing node 6 ("FR_H4_Accueil P Zéro Expérience.wav") result = 0
17:45:11.664 Dbg 21024 Channel 14 start playing node 7 ("FR_Attente_8kHz 8 bits uLaw.wav")
17:45:38.382 Dbg 22000 Invalid TLib message received from 65200(FR_TServer_760), wrong type of AttributeNetworkCallID
17:45:38.382 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
17:45:38.382 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
17:45:38.398 Dbg 21026 Channel 12 finished playing node 2 ("FR_Attente_8kHz 8 bits uLaw.wav") result = 260
17:45:38.398 Trc 21022 Channel 12 finished playing script 1879 ("FR_Attente")
17:45:38.851 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
« Reply #3 on: March 21, 2011, 05:39:44 PM »
Try setting the logs to DEBUG mode (verbose=all)
Offline catvrom01
« Reply #4 on: March 21, 2011, 07:27:06 PM »
I see that in the options for log it is verbose="all".
For the moment i put a new version 7.0.1 for the VTSserver and VTManager.
« Reply #5 on: March 21, 2011, 07:34:45 PM »
Hum, try uploading your complete log, specially the last part of the log file.
Is there some .nco file on the application folder for VTS?
Offline catvrom01
« Reply #6 on: March 23, 2011, 03:53:08 PM »
Hi
I dont have .nco files.
Also with this new version i see that this problem repeat.
This is the time when the application start to have the problem:
Also at the end of the log it is the same line who repeat.
Today create 40 minute continuous logs and after that the VoiceTreatmentServer is down.
The line that must be after :
15:05:27.650 Dbg 21026 Channel 9 finished playing node 19 ("Attach data to the call info") result = 0
it is for exampel this : 15:01:24.650 Dbg 21024 Channel 5 start playing node 21 ("FR_F1_Touche_SAV.wav")
But when this errore apeare the line it is empty:
15:05:27.650 Dbg 21024 Channel 9 start playing node 23 ("")
The log:
15:01:27.072 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:01:27.290 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:01:27.290 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:01:27.306 Dbg 21026 Channel 11 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 260
15:01:27.337 Trc 21022 Channel 11 finished playing script 2351 ("FR_Menu_old")
15:01:27.759 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:01:38.681 Dbg 21026 Channel 14 finished playing node 5 ("FR_2009_ Speedy_8kHz 8 bits ALaw.wav") result = 0
15:01:38.681 Dbg 21024 Channel 14 start playing node 6 ("FR_H4_Accueil P Zéro Expérience.wav")
15:01:40.743 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:01:40.962 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:01:41.275 Trc 21021 Channel 17 started playing script 2351 ("FR_Menu_old")
15:01:41.275 Dbg 21024 Channel 17 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:01:41.275 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:01:58.556 Dbg 21026 Channel 14 finished playing node 6 ("FR_H4_Accueil P Zéro Expérience.wav") result = 0
15:01:58.556 Dbg 21024 Channel 14 start playing node 8 ("FR_Attente_8kHz 8 bits uLaw.wav")
15:01:58.790 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:01:58.790 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:01:58.806 Dbg 21026 Channel 14 finished playing node 8 ("FR_Attente_8kHz 8 bits uLaw.wav") result = 260
15:01:58.837 Trc 21022 Channel 14 finished playing script 1869 ("FR_Speedy")
15:01:59.259 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:02:00.290 Dbg 21026 Channel 17 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 49
15:02:00.290 Dbg 21024 Channel 17 start playing node 17 ("Attach data to the call info")
15:02:00.290 Dbg 21026 Channel 17 finished playing node 17 ("Attach data to the call info") result = 0
15:02:00.290 Dbg 21024 Channel 17 start playing node 21 ("FR_F1_Touche_SAV.wav")
15:02:00.290 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:02:02.181 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:02:02.290 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:02:02.290 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:02:02.306 Dbg 21026 Channel 17 finished playing node 21 ("FR_F1_Touche_SAV.wav") result = 260
15:02:02.337 Trc 21022 Channel 17 finished playing script 2351 ("FR_Menu_old")
15:02:02.509 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:02:02.712 Trc 21021 Channel 16 started playing script 2308 ("FR_Siligom")
15:02:02.712 Dbg 21024 Channel 16 start playing node 5 ("FR_Accueil P Zéro Expérience.wav")
15:02:02.712 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:02:02.775 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:02:22.353 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:02:22.353 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:02:22.353 Dbg 21026 Channel 16 finished playing node 5 ("FR_Accueil P Zéro Expérience.wav") result = 260
15:02:22.384 Trc 21022 Channel 16 finished playing script 2308 ("FR_Siligom")
15:02:22.806 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:03:50.243 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:03:50.462 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:03:50.775 Trc 21021 Channel 2 started playing script 2351 ("FR_Menu_old")
15:03:50.775 Dbg 21024 Channel 2 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:03:50.775 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:04:09.493 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:04:09.493 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:04:09.509 Dbg 21026 Channel 2 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 260
15:04:09.540 Trc 21022 Channel 2 finished playing script 2351 ("FR_Menu_old")
15:04:09.962 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:04:57.072 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:04:57.290 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:04:57.603 Trc 21021 Channel 9 started playing script 2351 ("FR_Menu_old")
15:04:57.603 Dbg 21024 Channel 9 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:04:57.603 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:05:27.650 Dbg 21026 Channel 9 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 84
15:05:27.650 Dbg 21024 Channel 9 start playing node 19 ("Attach data to the call info")
15:05:27.650 Dbg 21026 Channel 9 finished playing node 23 ("") result = 0
15:05:27.650 Dbg 21024 Channel 9 start playing nodedata to the 19 ("Attach  call info")
15:05:27.650 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
Offline catvrom01
« Reply #7 on: March 23, 2011, 04:04:19 PM »
This is the log after the rstart of VTS:
Application name: FR_VTO_Server_701
Application type: VoiceTreatmentServer (6)
Command line:
Host name:        localhost
DST:              TZ = 1, timeb = 0
Time zone:        -3600, Romance Standard Time, Romance Daylight Time
UTC time:        2011-03-23T14:44:25.947
Local time:      2011-03-23T15:44:25.947
Start time (UTC): 2011-03-23T14:44:25
Running time:    0:00:00:00
15:44:25.947 Trc 04112 The Log Output of type 'c:\gcti\logs\VTOServer701.log' has been created and opened
15:44:25.978 Trc 04112 The Log Output of type 'network' has been created and opened
15:44:25.900 Trc 04110 Option 'buffering' has been set to the value 'yes'
15:44:25.900 Trc 04110 Option 'expire' has been set to the value '5 days'
15:44:25.900 Trc 04110 Option 'segment' has been set to the value '5000'
15:44:25.900 Trc 04110 Option 'spool' has been set to the value ''
15:44:25.900 Trc 04110 Option 'MessageFile' has been set to the value 'VoiceTreatmentServer.lms'
15:44:25.900 Trc 04110 Option 'time-format' has been set to the value 'time'
15:44:25.900 Trc 04110 Option 'time-convert' has been set to the value 'local'
15:44:25.900 Trc 04110 Option 'message-format' has been set to the value 'short'
15:44:25.900 Trc 04110 Option 'memory-storage-size' has been set to the value '2 Mb'
15:44:25.900 Trc 04110 Option 'compatible-output-priority' has been set to the value 'no'
15:44:25.900 Trc 04110 Option 'print-attributes' has been set to the value 'no'
15:44:25.900 Trc 04110 Option 'check-point' has been set to the value '1'
15:44:25.915 Std 04106 Log Messages file 'VoiceTreatmentServer.lms' successfully loaded
15:44:25.978 Trc 04100 Logging service started
15:44:25.978 Std 21094 Voice Treatment Server 7.0.000.05
15:44:25.978 Trc 21095 Voice Treatment Server sevice start pending
15:44:25.978 Trc 04500 Connecting to Configuration Server '' at host 'foxtrot', port 2020
15:44:25.993 Trc 04003 Voice Treatment Server main process started
15:44:26.743 Std 04503 Connected to Configuration Server '' at host 'foxtrot', port 2020
15:44:26.743 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=9
15:44:26.775 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=101
15:44:26.775 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=10
15:44:26.775 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:26.822 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=99
15:44:26.822 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:26.822 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=11
15:44:26.853 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Application RequestID=12
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Host RequestID=13
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Tenant RequestID=14
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Switch RequestID=15
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=DN RequestID=16
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Person RequestID=17
15:44:26.853 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=18
15:44:26.884 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Application
15:44:26.900 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Host
15:44:26.900 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Tenant
15:44:26.900 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Switch
15:44:26.900 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=DN
15:44:26.900 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Person
15:44:26.915 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=657
15:44:26.915 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:26.915 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=19
15:44:26.978 Trc 04500 Connecting to Message server '' at host 'foxtrot', port 4220
15:44:27.165 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=515
15:44:27.165 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:27.165 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=20
15:44:27.275 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=601
15:44:27.275 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:27.275 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=21
15:44:27.306 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=105
15:44:27.306 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:27.306 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=22
15:44:27.337 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=156
15:44:27.337 Trc 04110 Option 'buffering' has been set to the value 'yes'
15:44:27.337 Trc 04110 Option 'expire' has been set to the value '10 days'
15:44:27.337 Trc 04110 Option 'segment' has been set to the value '10000'
15:44:27.337 Trc 04110 Option 'spool' has been set to the value ''
15:44:27.337 Trc 04110 Option 'MessageFile' has been set to the value 'VoiceTreatmentServer.lms'
15:44:27.337 Trc 04110 Option 'time-format' has been set to the value 'time'
15:44:27.337 Trc 04110 Option 'time-convert' has been set to the value 'local'
15:44:27.337 Trc 04110 Option 'message-format' has been set to the value 'short'
15:44:27.337 Trc 04110 Option 'memory-storage-size' has been set to the value '2 Mb'
15:44:27.337 Trc 04110 Option 'compatible-output-priority' has been set to the value 'no'
15:44:27.337 Trc 04110 Option 'print-attributes' has been set to the value 'no'
15:44:27.337 Trc 04110 Option 'check-point' has been set to the value '1'
15:44:27.337 Trc 04500 Connecting to Message server '' at host 'foxtrot', port 4220
15:44:27.337 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.400 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Tenant RequestID=23
15:44:27.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Tenant DBID=101
15:44:27.447 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Tenant
15:44:27.447 Dbg 21152 ConfigServer request sent: ConfRegisterObjectType ObjType=Script RequestID=24
15:44:27.447 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Application RequestID=25
15:44:27.462 Dbg 21015 ConfigServer event received: CfgEvent=Registered ObjType=Script
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=167
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=269
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=417
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=489
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=507
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=521
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=523
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=538
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=583
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=594
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Application DBID=657
15:44:27.603 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Application
15:44:27.603 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=26
15:44:27.634 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=111
15:44:27.634 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=27
15:44:27.634 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.665 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=169
15:44:27.665 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=28
15:44:27.665 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.697 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=148
15:44:27.697 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=29
15:44:27.697 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.728 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=120
15:44:27.728 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=30
15:44:27.728 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.743 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=125
15:44:27.743 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=31
15:44:27.743 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.775 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=158
15:44:27.775 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=32
15:44:27.775 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.806 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=174
15:44:27.806 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:27.806 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=33
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=113
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=122
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=124
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=147
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=171
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=188
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=220
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=292
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=296
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=337
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1525
15:44:29.
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2471
15:44:29.072 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:29.087 Dbg 21081 Voice file descriptor 113 loaded
15:44:29.087 Dbg 21081 Voice file descriptor 122 loaded
15:44:29.087 Dbg 21083 Action descriptor descriptor 124 loaded
15:44:29.087 Dbg 21081 Voice file descriptor 147 loaded
15:44:29.087 Dbg 21081 Voice file descriptor 171 loaded
15:44:29.103 Dbg 21081 Voice file descriptor 188 loaded
15:44:29.
15
15:44:29.759 Dbg 21081 Voice file descriptor 2468 loaded
15:44:29.759 Dbg 21081 Voice file descriptor 2469 loaded
15:44:29.759 Dbg 21081 Voice file descriptor 2470 loaded
15:44:29.759 Dbg 21081 Voice file descriptor 2471 loaded
15:44:29.759 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=34
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=132
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=138
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=230
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1208
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1230
15:44:29.837 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:29.837 Dbg 21085 Script 132 loaded
15:44:29.837 Dbg 21085 Script 138 loaded
15:44:29.837 Dbg 21085 Script 230 loaded
15:44:29.837 Dbg 21085 Script 1208 loaded
15:44:29.837 Dbg 21085 Script 1230 loaded
15:44:29.837 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=35
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=503
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=527
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=990
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1144
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1145
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1146
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1160
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1237
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1256
15:44:30.087 Std 21086 Script 503 was NOT loaded
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1284
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1285
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1303
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1363
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1367
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1492
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1576
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1577
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1578
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1579
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1580
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1581
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1582
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1592
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1698
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1885
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1894
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1939
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1930
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1935
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2129
15:44:30.087 Std 21086 Script 527 was NOT loaded
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2132
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2135
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2145
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2351
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2366
15:44:30.087 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=36
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=37
15:44:30.087 Std 21086 Script 990 was NOT loaded
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=38
15:44:30.087 Std 21086 Script 1144 was NOT loaded
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=39
15:44:30.087 Std 21086 Script 1145 was NOT loaded
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=40
15:44:30.087 Std 21086 Script 1146 was NOT loaded
15:44:30.087 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=41
15:44:30.087 Dbg 21085 Script 1160 loaded
15:44:30.087 Dbg 21085 Script 1237 loaded
15:44:30.087 Dbg 21085 Script 1256 loaded
15:44:30.103 Dbg 21085 Script 1284 loaded
15:44:30.103 Dbg 21085 Script 1285 loaded
15:44:30.103 Dbg 21085 Script 1303 loaded
15:44:30.103 Std 21086 Script 1363 was NOT loaded
15:44:30.103 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=42
15:44:30.103 Dbg 21085 Script 1367 loaded
15:44:30.103 Dbg 21085 Script 1492 loaded
15:44:30.103 Dbg 21085 Script 1576 loaded
15:44:30.103 Dbg 21085 Script 1577 loaded
15:44:30.103 Dbg 21085 Script 1578 loaded
15:44:30.103 Dbg 21085 Script 1579 loaded
15:44:30.103 Dbg 21085 Script 1580 loaded
15:44:30.103 Dbg 21085 Script 1581 loaded
15:44:30.103 Dbg 21085 Script 1582 loaded
15:44:30.103 Dbg 21085 Script 1592 loaded
15:44:30.103 Std 21086 Script 1698 was NOT loaded
15:44:30.103 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=43
15:44:30.103 Dbg 21085 Script 1885 loaded
15:44:30.103 Dbg 21085 Script 1894 loaded
15:44:30.103 Dbg 21085 Script 1939 loaded
15:44:30.103 Dbg 21085 Script 1930 loaded
15:44:30.103 Dbg 21085 Script 1935 loaded
15:44:30.103 Dbg 21085 Script 2129 loaded
15:44:30.103 Dbg 21085 Script 2132 loaded
15:44:30.103 Dbg 21085 Script 2135 loaded
15:44:30.103 Dbg 21085 Script 2145 loaded
15:44:30.103 Dbg 21085 Script 2351 loaded
15:44:30.103 Dbg 21085 Script 2366 loaded
15:44:30.103 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=44
15:44:30.118 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.150 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=153
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=158
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=183
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=271
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=199
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=272
15:44:30.447 Dbg 21085 Script 153 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=301
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=305
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=306
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=349
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=372
15:44:30.447 Dbg 21085 Script 158 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=408
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=844
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=845
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=948
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=950
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=951
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=952
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1014
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1050
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1019
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1074
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1097
15:44:30.447 Dbg 21085 Script 183 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1101
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1167
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1168
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1232
15:44:30.447 Dbg 21085 Script 271 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1250
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1251
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1252
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1253
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1254
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1258
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1273
15:44:30.447 Dbg 21085 Script 199 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1280
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1312
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1313
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1344
15:44:30.447 Dbg 21085 Script 272 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1370
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1358
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1457
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1458
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1459
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1466
15:44:30.447 Dbg 21085 Script 301 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1499
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1509
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1519
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1523
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1524
15:44:30.447 Dbg 21085 Script 305 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1538
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1540
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1541
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1542
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1543
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1583
15:44:30.447 Dbg 21085 Script 306 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1584
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1585
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1586
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1587
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1588
15:44:30.447 Dbg 21085 Script 349 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1589
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1590
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1591
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1622
15:44:30.447 Dbg 21085 Script 372 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1670
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1675
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1676
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1677
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1678
15:44:30.447 Dbg 21085 Script 408 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1679
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1689
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1774
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1794
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1810
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1815
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1827
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1844
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1866
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1867
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1868
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1869
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1870
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1871
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1872
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1873
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1874
15:44:30.447 Dbg 21085 Script 844 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1875
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1876
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1877
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1878
15:44:30.447 Dbg 21085 Script 845 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1879
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1880
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1881
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1882
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1883
15:44:30.447 Dbg 21085 Script 948 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1898
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1900
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1905
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1909
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1929
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1960
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=1966
15:44:30.447 Dbg 21085 Script 950 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2021
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2083
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2091
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2092
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2116
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2118
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2119
15:44:30.447 Dbg 21085 Script 951 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2120
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2123
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2127
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2137
15:44:30.447 Dbg 21085 Script 952 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2141
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2142
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2143
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2152
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2153
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2154
15:44:30.447 Dbg 21085 Script 1014 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2156
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2159
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2167
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2180
15:44:30.447 Dbg 21085 Script 1050 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2181
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2182
15:44:30.447 Dbg 21085 Script 1019 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2188
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2189
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2202
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2219
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2226
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2232
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2249
15:44:30.447 Dbg 21085 Script 1074 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2259
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2267
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2289
15:44:30.447 Dbg 21085 Script 1097 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2301
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2303
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2304
15:44:30.447 Dbg 21085 Script 1101 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2305
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2306
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2308
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2349
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2356
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2382
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2386
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2387
15:44:30.447 Dbg 21085 Script 1167 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2388
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2391
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2392
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2393
15:44:30.447 Dbg 21085 Script 1168 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2397
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2400
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2401
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2412
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2444
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2445
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2446
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2447
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2448
15:44:30.447 Dbg 21085 Script 1232 loaded
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2449
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2472
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=2473
15:44:30.447 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.447 Dbg 21085 Script 1250 loaded
15:44:30.447 Dbg 21085 Script 1251 loaded
15:44:30.447 Dbg 21085 Script 1252 loaded
15:44:30.447 Dbg 21085 Script 1253 loaded
15:44:30.447 Dbg 21085 Script 1254 loaded
15:44:30.447 Dbg 21085 Script 1258 loaded
15:44:30.447 Dbg 21085 Script 1273 loaded
15:44:30.447 Dbg 21085 Script 1280 loaded
15:44:30.447 Std 21086 Script 1312 was NOT loaded
15:44:30.447 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=45
15:44:30.447 Dbg 21085 Script 1313 loaded
15:44:30.447 Dbg 21085 Script 1344 loaded
15:44:30.447 Dbg 21085 Script 1370 loaded
15:44:30.447 Dbg 21085 Script 1358 loaded
15:44:30.447 Dbg 21085 Script 1457 loaded
15:44:30.447 Dbg 21085 Script 1458 loaded
15:44:30.447 Dbg 21085 Script 1459 loaded
15:44:30.447 Dbg 21085 Script 1466 loaded
15:44:30.447 Dbg 21085 Script 1499 loaded
15:44:30.447 Dbg 21085 Script 1509 loaded
15:44:30.447 Dbg 21085 Script 1519 loaded
15:44:30.447 Dbg 21085 Script 1523 loaded
15:44:30.447 Dbg 21085 Script 1524 loaded
15:44:30.447 Dbg 21085 Script 1538 loaded
15:44:30.447 Dbg 21085 Script 1540 loaded
15:44:30.447 Dbg 21085 Script 1541 loaded
15:44:30.447 Dbg 21085 Script 1542 loaded
15:44:30.447 Dbg 21085 Script 1543 loaded
15:44:30.447 Dbg 21085 Script 1583 loaded
15:44:30.447 Dbg 21085 Script 1584 loaded
15:44:30.447 Dbg 21085 Script 1585 loaded
15:44:30.447 Dbg 21085 Script 1586 loaded
15:44:30.447 Dbg 21085 Script 1587 loaded
15:44:30.447 Dbg 21085 Script 1588 loaded
15:44:30.447 Dbg 21085 Script 1589 loaded
15:44:30.447 Dbg 21085 Script 1590 loaded
15:44:30.447 Dbg 21085 Script 1591 loaded
15:44:30.447 Dbg 21085 Script 1622 loaded
15:44:30.447 Dbg 21085 Script 1670 loaded
15:44:30.447 Dbg 21085 Script 1675 loaded
15:44:30.447 Dbg 21085 Script 1676 loaded
15:44:30.447 Dbg 21085 Script 1677 loaded
15:44:30.447 Dbg 21085 Script 1678 loaded
15:44:30.447 Dbg 21085 Script 1679 loaded
15:44:30.447 Dbg 21085 Script 1689 loaded
15:44:30.447 Dbg 21085 Script 1774 loaded
15:44:30.447 Dbg 21085 Script 1794 loaded
15:44:30.447 Dbg 21085 Script 1810 loaded
15:44:30.447 Dbg 21085 Script 1815 loaded
15:44:30.447 Dbg 21085 Script 1827 loaded
15:44:30.447 Dbg 21085 Script 1844 loaded
15:44:30.447 Dbg 21085 Script 1866 loaded
15:44:30.447 Dbg 21085 Script 1867 loaded
15:44:30.447 Dbg 21085 Script 1868 loaded
15:44:30.447 Dbg 21085 Script 1869 loaded
15:44:30.447 Dbg 21085 Script 1870 loaded
15:44:30.447 Dbg 21085 Script 1871 loaded
15:44:30.447 Dbg 21085 Script 1872 loaded
15:44:30.447 Dbg 21085 Script 1873 loaded
15:44:30.447 Dbg 21085 Script 1874 loaded
15:44:30.447 Dbg 21085 Script 1875 loaded
15:44:30.447 Dbg 21085 Script 1876 loaded
15:44:30.447 Dbg 21085 Script 1877 loaded
15:44:30.447 Dbg 21085 Script 1878 loaded
15:44:30.447 Dbg 21085 Script 1879 loaded
15:44:30.447 Dbg 21085 Script 1880 loaded
15:44:30.447 Dbg 21085 Script 1881 loaded
15:44:30.447 Dbg 21085 Script 1882 loaded
15:44:30.447 Dbg 21085 Script 1883 loaded
15:44:30.447 Dbg 21085 Script 1898 loaded
15:44:30.462 Dbg 21085 Script 1900 loaded
15:44:30.462 Dbg 21085 Script 1905 loaded
15:44:30.462 Dbg 21085 Script 1909 loaded
15:44:30.462 Dbg 21085 Script 1929 loaded
15:44:30.462 Dbg 21085 Script 1960 loaded
15:44:30.462 Dbg 21085 Script 1966 loaded
15:44:30.462 Dbg 21085 Script 2021 loaded
15:44:30.462 Dbg 21085 Script 2083 loaded
15:44:30.462 Dbg 21085 Script 2091 loaded
15:44:30.462 Dbg 21085 Script 2092 loaded
15:44:30.462 Dbg 21085 Script 2116 loaded
15:44:30.462 Dbg 21085 Script 2118 loaded
15:44:30.462 Dbg 21085 Script 2119 loaded
15:44:30.462 Dbg 21085 Script 2120 loaded
15:44:30.462 Dbg 21085 Script 2123 loaded
15:44:30.462 Dbg 21085 Script 2127 loaded
15:44:30.462 Dbg 21085 Script 2137 loaded
15:44:30.462 Dbg 21085 Script 2141 loaded
15:44:30.462 Dbg 21085 Script 2142 loaded
15:44:30.462 Dbg 21085 Script 2143 loaded
15:44:30.462 Dbg 21085 Script 2152 loaded
15:44:30.462 Dbg 21085 Script 2153 loaded
15:44:30.462 Dbg 21085 Script 2154 loaded
15:44:30.462 Dbg 21085 Script 2156 loaded
15:44:30.462 Dbg 21085 Script 2159 loaded
15:44:30.462 Dbg 21085 Script 2167 loaded
15:44:30.462 Dbg 21085 Script 2180 loaded
15:44:30.462 Dbg 21085 Script 2181 loaded
15:44:30.462 Dbg 21085 Script 2182 loaded
15:44:30.462 Dbg 21085 Script 2188 loaded
15:44:30.462 Dbg 21085 Script 2189 loaded
15:44:30.462 Dbg 21085 Script 2202 loaded
15:44:30.462 Dbg 21085 Script 2219 loaded
15:44:30.462 Dbg 21085 Script 2226 loaded
15:44:30.462 Dbg 21085 Script 2232 loaded
15:44:30.462 Dbg 21085 Script 2249 loaded
15:44:30.462 Dbg 21085 Script 2259 loaded
15:44:30.462 Dbg 21085 Script 2267 loaded
15:44:30.462 Dbg 21085 Script 2289 loaded
15:44:30.462 Dbg 21085 Script 2301 loaded
15:44:30.462 Dbg 21085 Script 2303 loaded
15:44:30.462 Dbg 21085 Script 2304 loaded
15:44:30.462 Dbg 21085 Script 2305 loaded
15:44:30.462 Dbg 21085 Script 2306 loaded
15:44:30.462 Dbg 21085 Script 2308 loaded
15:44:30.462 Dbg 21085 Script 2349 loaded
15:44:30.462 Dbg 21085 Script 2356 loaded
15:44:30.462 Dbg 21085 Script 2382 loaded
15:44:30.462 Dbg 21085 Script 2386 loaded
15:44:30.462 Dbg 21085 Script 2387 loaded
15:44:30.462 Dbg 21085 Script 2388 loaded
15:44:30.462 Dbg 21085 Script 2391 loaded
15:44:30.462 Dbg 21085 Script 2392 loaded
15:44:30.462 Dbg 21085 Script 2393 loaded
15:44:30.462 Dbg 21085 Script 2397 loaded
15:44:30.462 Dbg 21085 Script 2400 loaded
15:44:30.462 Dbg 21085 Script 2401 loaded
15:44:30.462 Dbg 21085 Script 2412 loaded
15:44:30.462 Dbg 21085 Script 2444 loaded
15:44:30.462 Dbg 21085 Script 2445 loaded
15:44:30.462 Dbg 21085 Script 2446 loaded
15:44:30.462 Dbg 21085 Script 2447 loaded
15:44:30.462 Dbg 21085 Script 2448 loaded
15:44:30.462 Dbg 21085 Script 2449 loaded
15:44:30.462 Dbg 21085 Script 2472 loaded
15:44:30.462 Dbg 21085 Script 2473 loaded
15:44:30.462 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Script RequestID=46
15:44:30.478 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.509 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Script DBID=800
15:44:30.509 Dbg 21085 Script 800 loaded
15:44:30.509 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Script
15:44:30.978 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=47
15:44:31.009 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2141
15:44:31.009 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Switch RequestID=48
15:44:31.009 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:31.040 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Switch DBID=111
15:44:31.040 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Switch
15:44:33.040 Std 04503 Connected to Message server '' at host 'foxtrot', port 4220
15:44:35.197 Dbg 21156 Successfully initialized Dialogic hardware: detected devices: voice: 24; network: 0
15:44:35.197 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=49
15:44:35.228 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2221
15:44:35.228 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.228 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=50
15:44:35.243 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2220
15:44:35.243 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=51
15:44:35.243 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.275 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2219
15:44:35.275 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=52
15:44:35.275 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.290 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2218
15:44:35.290 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=53
15:44:35.290 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.322 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2217
15:44:35.322 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=54
15:44:35.322 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.337 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2216
15:44:35.337 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=55
15:44:35.337 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.368 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2215
15:44:35.368 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=56
15:44:35.368 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.384 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2214
15:44:35.384 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=57
15:44:35.384 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.415 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2213
15:44:35.415 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=58
15:44:35.415 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.447 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2222
15:44:35.447 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=59
15:44:35.447 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.462 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2193
15:44:35.462 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=60
15:44:35.462 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.493 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2194
15:44:35.493 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=61
15:44:35.493 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.509 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2210
15:44:35.509 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=62
15:44:35.509 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.540 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2212
15:44:35.540 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=63
15:44:35.540 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.572 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2211
15:44:35.572 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=64
15:44:35.572 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.603 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2143
15:44:35.603 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=DN RequestID=65
15:44:35.603 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.618 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=DN DBID=2142
15:44:35.618 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=DN
15:44:35.837 Std 07101 Feature 'VTPort': 18 licenses checked out
15:44:35.837 Trc 20001 Open LCALayer on port=4999
15:44:35.837 Trc 20001 LCA Library version 7.0.100.01
15:44:35.853 Dbg 21152 ConfigServer request sent: ConfGetObjectInfo ObjType=Host RequestID=66
15:44:35.868 Dbg 21015 ConfigServer event received: CfgEvent=ObjectInfo ObjType=Host DBID=157
15:44:35.868 Trc 04500 Connecting to TServer 'FR_TServer_760' at host 'APP011FR', port 3000
15:44:35.868 Dbg 21015 ConfigServer event received: CfgEvent=EndObjectsList ObjType=Host
15:44:35.868 Std 04503 Connected to TServer 'FR_TServer_760' at host 'APP011FR', port 3000
15:44:35.868 Trc 04541 Message EventLinkConnected received from 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04542 Message RequestQueryServer sent to 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04542 Message RequestSetInputMask sent to 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04542 Message RequestRegisterAddress sent to 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04541 Message EventServerInfo received from 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04541 Message EventACK received from 65200 (TServer 'FR_TServer_760')
15:44:35.868 Trc 04541 Message EventRegistered received from 65200 (TServer 'FR_TServer_760')
15:44:35.884 Trc 04541 Message EventRegistered received from 65200 (TServer 'FR_TServer_760')
15:44:35.884 Trc 04542 Message EventOnHook sent to 65200 (TServer 'FR_TServer_760')
15:44:35.884 Trc 20001 ************************************
15:44:35.884 Trc 20001 LCALayer: REventRegistered on LCA...
15:44:35.900 Dbg 21157 Channel 0: Dialogic device dxxxB1C1: network interface type 0x3
15:44:35.900 Dbg 21157 Channel 1: Dialogic device dxxxB1C2: network interface type 0x3
15:44:35.900 Dbg 21159 Channel 0: Dialogic voice device dxxxB1C1 routed with Dialogic analog timeslot device dxxxB1C1
15:44:35.900 Trc 21020 Channel 0 attached to DN 2193 ( 660 )
15:44:35.900 Dbg 21159 Channel 1: Dialogic voice device dxxxB1C2 routed with Dialogic analog timeslot device dxxxB1C2
15:44:35.915 Trc 21020 Channel 1 attached to DN 2194 ( 661 )
15:44:35.915 Dbg 21157 Channel 3: Dialogic device dxxxB1C4: network interface type 0x3
15:44:35.915 Dbg 21157 Channel 4: Dialogic device dxxxB2C1: network interface type 0x3
15:44:35.931 Dbg 21157 Channel 6: Dialogic device dxxxB2C3: network interface type 0x3
15:44:35.931 Dbg 21159 Channel 3: Dialogic voice device dxxxB1C4 routed with Dialogic analog timeslot device dxxxB1C4
15:44:35.931 Dbg 21159 Channel 4: Dialogic voice device dxxxB2C1 routed with Dialogic analog timeslot device dxxxB2C1
15:44:35.931 Trc 21020 Channel 4 attached to DN 2212 ( 664 )
15:44:35.931 Trc 21020 Channel 3 attached to DN 2211 ( 663 )
15:44:35.947 Dbg 21159 Channel 6: Dialogic voice device dxxxB2C3 routed with Dialogic analog timeslot device dxxxB2C3
15:44:35.947 Dbg 21157 Channel 10: Dialogic device dxxxB3C3: network interface type 0x3
15:44:35.947 Trc 21020 Channel 6 attached to DN 2214 ( 666 )
15:44:35.947 Dbg 21157 Channel 8: Dialogic device dxxxB3C1: network interface type 0x3
15:44:35.947 Dbg 21159 Channel 10: Dialogic voice device dxxxB3C3 routed with Dialogic analog timeslot device dxxxB3C3
15:44:35.947 Trc 21020 Channel 10 attached to DN 2218 ( 670 )
15:44:35.962 Dbg 21157 Channel 2: Dialogic device dxxxB1C3: network interface type 0x3
15:44:35.962 Dbg 21159 Channel 8: Dialogic voice device dxxxB3C1 routed with Dialogic analog timeslot device dxxxB3C1
15:44:35.962 Dbg 21159 Channel 2: Dialogic voice device dxxxB1C3 routed with Dialogic analog timeslot device dxxxB1C3
15:44:35.962 Trc 21020 Channel 2 attached to DN 2210 ( 662 )
15:44:35.962 Trc 21020 Channel 8 attached to DN 2216 ( 668 )
15:44:35.978 Dbg 21157 Channel 16: Dialogic device dxxxB5C1: network interface type 0x3
15:44:35.978 Dbg 21157 Channel 14: Dialogic device dxxxB4C3: network interface type 0x3
15:44:35.978 Dbg 21159 Channel 16: Dialogic voice device dxxxB5C1 routed with Dialogic analog timeslot device dxxxB5C1
15:44:35.993 Dbg 21159 Channel 14: Dialogic voice device dxxxB4C3 routed with Dialogic analog timeslot device dxxxB4C3
15:44:35.993 Trc 21020 Channel 14 attached to DN 2222 ( 674 )
15:44:35.993 Trc 21020 Channel 16 attached to DN 2142 ( 676 )
15:44:35.993 Dbg 21157 Channel 12: Dialogic device dxxxB4C1: network interface type 0x3
15:44:35.993 Dbg 21159 Channel 12: Dialogic voice device dxxxB4C1 routed with Dialogic analog timeslot device dxxxB4C1
15:44:35.993 Trc 21020 Channel 12 attached to DN 2220 ( 672 )
15:44:36.009 Dbg 21157 Channel 11: Dialogic device dxxxB3C4: network interface type 0x3
15:44:36.009 Dbg 21159 Channel 11: Dialogic voice device dxxxB3C4 routed with Dialogic analog timeslot device dxxxB3C4
15:44:36.009 Trc 21020 Channel 11 attached to DN 2219 ( 671 )
15:44:36.009 Dbg 21157 Channel 13: Dialogic device dxxxB4C2: network interface type 0x3
15:44:36.025 Dbg 21157 Channel 15: Dialogic device dxxxB4C4: network interface type 0x3
15:44:36.025 Dbg 21159 Channel 13: Dialogic voice device dxxxB4C2 routed with Dialogic analog timeslot device dxxxB4C2
15:44:36.025 Trc 21020 Channel 13 attached to DN 2221 ( 673 )
15:44:36.025 Dbg 21157 Channel 9: Dialogic device dxxxB3C2: network interface type 0x3
15:44:36.025 Dbg 21159 Channel 15: Dialogic voice device dxxxB4C4 routed with Dialogic analog timeslot device dxxxB4C4
15:44:36.040 Trc 21020 Channel 15 attached to DN 2141 ( 675 )
15:44:36.040 Dbg 21159 Channel 9: Dialogic voice device dxxxB3C2 routed with Dialogic analog timeslot device dxxxB3C2
15:44:36.040 Dbg 21157 Channel 7: Dialogic device dxxxB2C4: network interface type 0x3
15:44:36.056 Dbg 21157 Channel 5: Dialogic device dxxxB2C2: network interface type 0x3
15:44:36.056 Dbg 21159 Channel 7: Dialogic voice device dxxxB2C4 routed with Dialogic analog timeslot device dxxxB2C4
15:44:36.056 Trc 21020 Channel 7 attached to DN 2215 ( 667 )
15:44:36.056 Dbg 21157 Channel 17: Dialogic device dxxxB5C2: network interface type 0x3
15:44:36.056 Dbg 21159 Channel 5: Dialogic voice device dxxxB2C2 routed with Dialogic analog timeslot device dxxxB2C2
15:44:36.072 Trc 21020 Channel 9 attached to DN 2217 ( 669 )
15:44:36.072 Trc 21020 Channel 5 attached to DN 2213 ( 665 )
15:44:36.072 Dbg 21159 Channel 17: Dialogic voice device dxxxB5C2 routed with Dialogic analog timeslot device dxxxB5C2
15:44:36.072 Trc 21020 Channel 17 attached to DN 2143 ( 677 )
15:44:36.493 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_76
Re: Please help me , Voive Treatment Server down each week
« Reply #8 on: March 23, 2011, 05:25:50 PM »
[quote author=catvrom01 link=topic=6274.msg27337#msg27337 date=1300896259]
And here is where it dies or you stopped the log?
Offline catvrom01
« Reply #9 on: March 23, 2011, 06:30:08 PM »
I stop the log.
Because from  that point  i see the normal activiti of it.
It die only after that lines who repeat.
For exemple the log contiue with this lines:
15:44:36.493 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:44:41.665 Int 04543 Interaction message "EventAbandoned" received from 65200 ("FR_TServer_760")
15:44:43.650 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:44:43.868 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:44:44.181 Trc 21021 Channel 2 started playing script 2351 ("FR_Menu_old")
15:44:44.181 Dbg 21024 Channel 2 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:44:44.181 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:44:46.275 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:44:46.493 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:44:46.806 Trc 21021 Channel 9 started playing script 2351 ("FR_Menu_old")
15:44:46.806 Dbg 21024 Channel 9 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:44:46.806 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:44:51.853 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:44:51.853 Int 04543 Interaction message "EventAbandoned" received from 65200 ("FR_TServer_760")
15:44:52.072 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:44:52.384 Trc 21021 Channel 14 started playing script 2351 ("FR_Menu_old")
15:44:52.384 Dbg 21024 Channel 14 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:44:52.384 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:44:52.806 Int 04543 Interaction message "EventAbandoned" received from 65200 ("FR_TServer_760")
15:44:53.290 Int 04543 Interaction message "EventAbandoned" received from 65200 ("FR_TServer_760")
15:45:00.822 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:01.040 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:45:01.368 Trc 21021 Channel 5 started playing script 2351 ("FR_Menu_old")
15:45:01.368 Dbg 21024 Channel 5 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:45:01.368 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:45:03.009 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:03.072 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:45:03.072 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:03.118 Dbg 21026 Channel 2 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 260
15:45:03.212 Trc 21022 Channel 2 finished playing script 2351 ("FR_Menu_old")
15:45:03.228 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:45:03.556 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:03.556 Trc 21021 Channel 6 started playing script 1960 ("FR_Moto")
15:45:03.556 Dbg 21024 Channel 6 start playing node 5 ("FR_Accueil_2009_MOTO SUPERBIKE.wav")
15:45:03.556 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:45:03.775 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:03.775 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:45:04.165 Trc 21021 Channel 17 started playing script 2351 ("FR_Menu_old")
15:45:04.165 Dbg 21024 Channel 17 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:45:04.165 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:45:05.197 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:45:05.197 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:05.228 Dbg 21026 Channel 6 finished playing node 5 ("FR_Accueil_2009_MOTO SUPERBIKE.wav") result = 260
15:45:05.572 Trc 21022 Channel 6 finished playing script 1960 ("FR_Moto")
15:45:05.743 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:05.962 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:45:05.962 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:05.962 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:45:05.962 Dbg 21026 Channel 9 finished playing node 16 ("Message d'accueil F1 Touche SAV.wav") result = 260
15:45:05.993 Trc 21022 Channel 9 finished playing script 2351 ("FR_Menu_old")
15:45:06.181 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:06.306 Trc 21021 Channel 13 started playing script 1879 ("FR_Attente")
15:45:06.306 Dbg 21024 Channel 13 start playing node 2 ("FR_Attente_8kHz 8 bits uLaw.wav")
15:45:06.306 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:45:06.415 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:08.368 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:45:08.368 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:08.384 Dbg 21026 Channel 13 finished playing node 2 ("FR_Attente_8kHz 8 bits uLaw.wav") result = 260
15:45:08.415 Trc 21022 Channel 13 finished playing script 1879 ("FR_Attente")
15:45:08.837 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
15:45:09.681 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:09.900 Int 04543 Interaction message "EventEstablished" received from 65200 ("FR_TServer_760")
15:45:10.212 Trc 21021 Channel 15 started playing script 2351 ("FR_Menu_old")
15:45:10.212 Dbg 21024 Channel 15 start playing node 16 ("Message d'accueil F1 Touche SAV.wav")
15:45:10.212 Int 04545 Interaction message "RequestUpdateUserData" sent to 65200 ("FR_TServer_760")
15:45:10.993 Int 04543 Interaction message "EventRinging" received from 65200 ("FR_TServer_760")
15:45:11.212 Int 04543 Interaction message "EventReleased" received from 65200 ("FR_TServer_760")
15:45:11.212 Trc 04541 Message EventOnHook received from 65200 (TServer 'FR_TServer_760')
Offline catvrom01
« Reply #10 on: March 23, 2011, 06:35:16 PM »
I think i must find a solution to alert me when one VTO port it block for more then 10 minute.
Because in this case the VTS is down after 40 minute.
Only when it is down i recive an alarm and i can start again the service.
In this 40 minute dose'nt enter calls. And this is a big problem.
« Reply #11 on: March 23, 2011, 07:02:28 PM »
Wait, then VTO blocks or goes down (service crash)??
If blocks:
Is this always happening? Which board do you use? Which PBX? I think you can monitor VTO extensions on CCPulse right? Cant remember...long time don't use it, but if so TServer should also indicate the status of the port and why it is not being able to use it.
If goes down:
Post the last log snippet before the service crashes.
Offline Kevin S
« Reply #12 on: March 25, 2011, 02:55:40 PM »
Can you post a screen shot of the VTO script "FR_menu_old", fully expanded? It looks like the issue is with Node 23 - but we can't see what Node 23 is.
I would first think that the script is getting caught in a loop, which may be why it's hanging. Though at the end of the script for Channel 9, I see the "AttachData step"...
You indicated "for the moment I loaded VTS 7.0.1" - any reason you wouldn't use these permanently? I was not aware that VTS 5.1 was supported on Windows 2003. As a VTS user on a Nortel switch, I know they have made a number of corrections in VTS 7.0 to support staying on it vs. VTS 5.1
The other thought I had - in your VTS configuration, make sure that the codes are set correctly for the Dialogic OnHook/OffHook. If the OnHook is not being detected correctly, it may be causing the script to hang.
Offline catvrom01
« Reply #13 on: March 28, 2011, 10:30:25 AM »
Hi guys
We have an PBX= AlcatelA4400.
Yes cavagnaro you are right , with CCPulse we can monitor VTO places and we can atach one script to send me an email when one VTO port is offhook for more than 10 minute.
I try to explain better.
When enter the calls , at one moment one is block , after this call  all other have an errore and dosen't enter. After 40 minute the serivice VTO crash , and we recive the alert .
I try today or tomorow to put also logs and shot the VTO script.
Offline catvrom01
« Reply #14 on: March 29, 2011, 04:46:13 AM »
[b]Because i can't attache files with logs I try to put a part of UR-server log  and to explain it.
This is the call that block the FR_VTO, and after this call all the call for FR dosen’t  enter.
On this UR-server  are connected also other 2 T-server for Italia e Spania.
When this call block the VTO also this 2 server have some problem and lost the conection with this UR-server .In this periode all the calls dosen’t  enter, are in abandone.
The call enter  at 11:02:[/b]
  _M_I_ [10:17] tenant Resources object FR_5013 statserver StatServer_Tz_EU-Wb: 0 ready DNs reported
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventQueued
AttributeOtherDN '381479798'
AttributeOtherDNRole 1
AttributeOtherTrunk 262155
AttributeThisDN '732'
AttributeThisDNRole 2
AttributeThisTrunk 1083
AttributeThisQueue '732'
AttributeOtherQueue '5830732'
AttributeCallState 22
AttributeCallType 2
AttributeCallID 25975
AttributeConnID 025901e83fb4cd98
attr_#141 'B66T7G358L05PBH5420MG5FQC8000OPV'
AttributeDNIS '5830732'
AttributeANI '381479798'
AttributeCustomerID 'Resources'
AttributeNetworkCallID 0d4f904d77650100
AttributeExtensions [197] 00 06 01 00..
'GCTI_BUSINESS_CALL' 1
'GCTI_LAST_REDIRECTION_DEVICE' '732'
'GCTI_NETWORK_TIMESLOT' 29
'GCTI_GLOB_CID' bin: 0D 4F 90 4D.. (len=8)
'GCTI_NAT_INDICATIONTYPE' 'Public:National'
'GCTI_NAT_INDICATION' '381479798'
AttributeTimeinSecs 1301302959 (11:02:39)
AttributeTimeinuSecs 549000
attr_#148 000000000001bc56
Mon Mar 28 11:02:39 2011.606 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:39 2011.606_T_I_0000000000000000 [14:0c] EventQueued is received for tserver FR_TServer_760 (this dn=732)
    _C_W_025901e83fb4cd98 [0D:03] default value (0) will be used for option use_parking_threshold
    _C_W_025901e83fb4cd98 [0D:03] default value (3) will be used for option on_route_overlap
    _T_I_025901e83fb4cd98 [01:11] connid 025901e83fb4cd98 is bound to the call 5757-8000000102630dd0
    _I_I_025901e83fb4cd98 [01:01] call (5757-8000000102630dd0) for Resources created
    _T_I_025901e83fb4cd98 [14:09] add DN FR_TServer_760 732 <732@FR_Paris> (CDN 57 025901e83fb4cd98) to the call 5757-8000000102630dd0 truly
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventRouteRequest
AttributeCallState 0
AttributeCallType 2
attr_#148 000000000001bc57
Mon Mar 28 11:02:39 2011.612 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:39 2011.612_T_I_025901e83fb4cd98 [14:0c] EventRouteRequest is received for tserver FR_TServer_760 (this dn=732)
    _T_I_025901e83fb4cd98 [14:09] add DN FR_TServer_760 732 <732@FR_Paris> (CDN 71 025901e83fb4cd98) to the call 5757-8000000102630dd0 truly
    _T_I_025901e83fb4cd98 [14:08] check delayed proc
    _I_I_025901e83fb4cd98 [14:32] strategy: *0x65*FR_Paris7_V49 is attached to the call
Mon Mar 28 11:02:39 2011.613 Int 20001 interaction 025901e83fb4cd98 is started
Mon Mar 28 11:02:39 2011.613_I_I_025901e83fb4cd98 [09:06] >>>>>>>>>>>>start interpretator
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: __Return(SCRIPT) <- STRING:
    _I_I_025901e83fb4cd98 [07:46] no error mode for this call
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: __DBReturn(SCRIPT) <- STRING:
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: __DBStrReturn(SCRIPT) <- STRING:
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: __TargetVar(SCRIPT) <- STRING:
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_StatServer(LOCAL) <- STRING: FR_VTO@StatServer_Tz_EU-Wb.GP
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_Timeout(LOCAL) <- INTEGER: 30
Mon Mar 28 11:02:39 2011.614_M_I_025901e83fb4cd98 [07:0c] default priority 3
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_ANI(LOCAL) <- STRING: 381479798
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_Priority(LOCAL) <- STRING: 1
request to 65218(FR_TServer_760) message RequestAttachUserData
AttributeReferenceID 7010
AttributeUserData [22] 00 01 00 00..
'Service' 'Business'
..sent to APP011FR:3000(fd=22)
    _I_I_025901e83fb4cd98 [10:0d] HERE IS SDATA: FR_AllAgents@StatServer_Tz_EU-Wb - StatAgentsLoggedin
Mon Mar 28 11:02:39 2011.616_M_I_ [10:06] tenant Resources GroupAgents <FR_AllAgents>: statistic StatAgentsLoggedin with server StatServer_Tz_EU-Wb <request=39, status=2> asked
    _I_I_025901e83fb4cd98 [10:0d] sdata returns 16(S)
  result of SData: FLOAT: 16.000000
    _I_I_025901e83fb4cd98 [10:0d] HERE IS SDATA: FR_VTO@StatServer_Tz_EU-Wb - FR_VTOAvailable
Mon Mar 28 11:02:39 2011.616_M_I_ [10:06] tenant Resources GroupPlaces <FR_VTO>: statistic FR_VTOAvailable with server StatServer_Tz_EU-Wb <request=41, status=2> asked
    _I_I_025901e83fb4cd98 [10:0d] sdata returns 18(S)
  result of SData: FLOAT: 18.000000
[b]At this time we made some querry to find the client. I don’t put this log with querry .
After this we play the welcome message.[/b]
Mon Mar 28 11:02:39 2011.863_I_I_025901e83fb4cd98 [09:05] >>>>>>>>>>>>resume interpretator(0)
request to 65218(FR_TServer_760) message RequestUpdateUserData
AttributeReferenceID 7021
AttributeUserData [17] 00 01 00 00..
'hierarchy' ' '
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_Hierarchy(LOCAL) <- STRING:
Mon Mar 28 11:02:39 2011.864 Int 22000 @@@@SDATA= .GQ
AttributeReferenceID 7022
AttributeUserData [103] 00 05 00 00..
'TEL' '0381479798'
'MAINPARTNER' '0001105849'
'COUNTRY' 'FR'
'DNIS' '5830732'
'CONNID' '025901e83fb4cd98'
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_SAV(LOCAL) <- INTEGER: 0
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_CED(LOCAL) <- STRING: 0
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_Timeout2(LOCAL) <- INTEGER: 25
    _I_I_025901e83fb4cd98 [09:04] ASSIGN: Var_VtoStaServer(LOCAL) <- STRING: FR_VTO@StatServer_Tz_EU-Wb.GP
    _I_I_025901e83fb4cd98 [01:07] treatment added: type=IVR, param1=FR_Menu_old, param2=FR_VTO@StatServer_Tz_EU-Wb.GP, tout=-1
Mon Mar 28 11:02:39 2011.865_I_I_025901e83fb4cd98 [07:07] HERE IS TARGETS
TARGETS: dummyagt.A
Mon Mar 28 11:02:39 2011.865_M_I_025901e83fb4cd98 [13:01] current virtual queue: 80000001025fbd20 id=15619, nVQ=15-8000000102155398, priority=3, time=1301302959.865
    _M_I_ [17:0f] VQ(80000001003de420) [at all 9 0] 1 target(s), flag=2a, guid: 0Resources||1|-1|1|0|""|||01StatTimeInReadyState|00{}[]dummyagt@StatServer_Tz_EU-Wb.A
Mon Mar 28 11:02:39 2011.865_M_I_025901e83fb4cd98 [13:03] call (virtual queue 80000001025fbd20, id=15619, priority 3, time 1301302959.865) waits for VQ 80000001003de420 (name="") now
    _M_I_025901e83fb4cd98 [17:0e] virtual queue ""(id=15619), VQ 80000001003de420 (1 targets): SELECT MAX by statistic StatTimeInReadyState(random )
    _M_I_025901e83fb4cd98 [17:0e] target dummyagt: empty(1-1 components) passed
    _M_I_025901e83fb4cd98 [17:0e] virtual queue ""(id=15619), VQ 80000001003de420: target for routing was NOT SELECTED (0 1 0 0)
    _I_I_025901e83fb4cd98 [07:0a] HERE IS WAIT (-1 sec)
    _I_I_025901e83fb4cd98 [07:0a] HERE IS WAIT (19 sec)
Mon Mar 28 11:02:39 2011.865_B_I_025901e83fb4cd98 [07:0a] delay treatments for 1000 msec
Mon Mar 28 11:02:39 2011.865_I_I_025901e83fb4cd98 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT), timers:11000
Mon Mar 28 11:02:39 2011.877_M_I_ [10:17] CHANGE OF STATE (tenant Resources object IT_A_6293 statserver StatServer_Tz_EU-Wb)
    _M_I_ [10:17] ready DN(switch IT_MilanoSIP, number 390264426293, type 1, time= 1301302959) for agent IT_A_6293, place IT_CCAuto_6293, status WaitForNextCall time= 1301302959
Mon Mar 28 11:02:39 2011.882_M_I_0000000000000000 [10:1b] blocking: agent IT_A_6293, place IT_CCAuto_6293, switch  dn  is blocked for 5 sec by 1000000001 expired 1301302964
Mon Mar 28 11:02:39 2011.882_M_I_0000000000000000 [10:1b] blocking: agent , place , switch IT_MilanoSIP dn 390264426293 is blocked for 5 sec by 1000000001 expired 1301302964
    _M_I_ [10:17] tenant Resources object IT_A_6293 statserver StatServer_Tz_EU-Wb: 1 ready DNs reported
Mon Mar 28 11:02:39 2011.882_M_I_ [10:15] check queue for statobject <IT_A_6293> type <Agent>
WAITING CALLS: 024f01e3ac69a719 024f01e3ac69a71e
    _M_I_0000000000000000 [10:20] try to route to agent "IT_A_6293" (place "IT_CCAuto_6293", 1 ready DNs reported)
    _M_I_ [10:0b] agent IT_A_6293, place IT_CCAuto_6293 is blocked absolutely
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventAttachedDataChanged
AttributeCallType 2
AttributeUserData [186] 00 09 00 00..
'DNIS' '5830732'
'DNIS' '5830732'
'ANI' '0381479798'
'TelSAP' '0381479798'
'ACCOUNT' '0001105849'
'Subtypology' 'FCE'
'Company' 'PATRICK METZ BMW'
'hierarchy' '0001121430'
AttributeThirdPartyDN '732'
AttributeReferenceID 7020
AttributeTimeinuSecs 830000
attr_#148 000000000001bc62
    _T_I_025901e83fb4cd98 [14:32] EventAttachedDataChanged is received for tserver FR_TServer_760 (this dn=732)
AttributeCallType 2
AttributeUserData [177] 00 09 00 00..
'DNIS' '5830732'
'DNIS' '5830732'
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
AttributeTimeinuSecs 846000
attr_#148 000000000001bc63
AttributeCallType 2
AttributeUserData [246] 00 0C 00 00..
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
attr_#148 000000000001bc64
Mon Mar 28 11:02:40 2011.019_M_I_ [10:1d] PULSE (calls: 4(4)=3+0--1, targets=3, time=1301302959, mem=0,138930,3863,23,243,0)
Mon Mar 28 11:02:40 2011.879_B_I_025901e83fb4cd98 [07:09] start chain of treatments
    _T_I_025901e83fb4cd98 [14:27] treatment starting: type=IVR, param1=FR_Menu_old, param2=FR_VTO@StatServer_Tz_EU-Wb.GP, tout=-1
    _B_I_025901e83fb4cd98 [14:26] treatment starting - ok
    _B_I_025901e83fb4cd98 [14:24] IVRTreatment was started===========>TREATMENT_ASK_NUMBER
AttributeReferenceID 7023
AttributeUserData [45] 00 02 00 00..
'Myscript' '2351'
'ScriptName' 'FR_Menu_old'
Mon Mar 28 11:02:40 2011.879_M_I_025901e83fb4cd98 [13:01] current virtual queue: 800000010266a138 id=15620, nVQ=20000, priority=3, time=1301302960.879
Mon Mar 28 11:02:40 2011.880_M_I_ [17:0c] VQ(80000001003df6b0) created: type=0, tenant=Resources
    _M_I_ [17:06] VQ(80000001003df6b0) target 80000001023507a8 added: name=FR_VTO, location=StatServer_Tz_EU-Wb, type=GP, state=##state, activity=unknown
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources GroupPlaces <FR_VTO>: statistic ##content with server StatServer_Tz_EU-Wb <request=1, status=2> asked
    _M_I_ [17:05] VQ(80000001003df6b0) target (name=FR_VTO, location=StatServer_Tz_EU-Wb, type=GP) synchronizing
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources Place <FR_VTO_660>: statistic ##state with server StatServer_Tz_EU-Wb <request=3, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_660
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources Place <FR_VTO_661>: statistic ##state with server StatServer_Tz_EU-Wb <request=5, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_661
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources Place <FR_VTO_662>: statistic ##state with server StatServer_Tz_EU-Wb <request=7, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_662
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources Place <FR_VTO_663>: statistic ##state with server StatServer_Tz_EU-Wb <request=9, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_663
Mon Mar 28 11:02:40 2011.880_M_I_ [10:06] tenant Resources Place <FR_VTO_664>: statistic ##state with server StatServer_Tz_EU-Wb <request=11, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_664
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_665>: statistic ##state with server StatServer_Tz_EU-Wb <request=13, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_665
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_666>: statistic ##state with server StatServer_Tz_EU-Wb <request=15, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_666
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_667>: statistic ##state with server StatServer_Tz_EU-Wb <request=17, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_667
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_668>: statistic ##state with server StatServer_Tz_EU-Wb <request=19, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_668
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_669>: statistic ##state with server StatServer_Tz_EU-Wb <request=21, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_669
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_670>: statistic ##state with server StatServer_Tz_EU-Wb <request=23, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_670
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_671>: statistic ##state with server StatServer_Tz_EU-Wb <request=25, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_671
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_672>: statistic ##state with server StatServer_Tz_EU-Wb <request=27, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_672
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_673>: statistic ##state with server StatServer_Tz_EU-Wb <request=29, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_673
Mon Mar 28 11:02:40 2011.881_M_I_ [10:06] tenant Resources Place <FR_VTO_675>: statistic ##state with server StatServer_Tz_EU-Wb <request=31, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_675
Mon Mar 28 11:02:40 2011.882_M_I_ [10:06] tenant Resources Place <FR_VTO_676>: statistic ##state with server StatServer_Tz_EU-Wb <request=33, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_676
Mon Mar 28 11:02:40 2011.882_M_I_ [10:06] tenant Resources Place <FR_VTO_677>: statistic ##state with server StatServer_Tz_EU-Wb <request=35, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_677
Mon Mar 28 11:02:40 2011.882_M_I_ [10:06] tenant Resources Place <FR_VTO_674>: statistic ##state with server StatServer_Tz_EU-Wb <request=37, status=2> asked
    _M_I_ [17:09] VQ(80000001003df6b0), target 80000001023507a8: GroupPlaces <FR_VTO> connected to state Place FR_VTO_674
Mon Mar 28 11:02:40 2011.882_M_I_025901e83fb4cd98 [13:02] entering virtual queue "__##IVR_VQ_NAME__"
    _M_I_ [17:0f] VQ(80000001003df6b0) [at all 10 0] 1 target(s), flag=800000010000000a, guid: 0Resources|__##IVR_VQ_NAME__|1|-1|1|0|""|||03|00{}[]FR_VTO@StatServer_Tz_EU-Wb.GP
Mon Mar 28 11:02:40 2011.882_M_I_025901e83fb4cd98 [13:03] call (virtual queue 800000010266a138, id=15620, priority 3, time 1301302960.879) waits for VQ 80000001003df6b0 (name="__##IVR_VQ_NAME__") now
    _M_I_025901e83fb4cd98 [17:0e] virtual queue "__##IVR_VQ_NAME__"(id=15620), VQ 80000001003df6b0 (1 targets): SELECT ANY by statistic NONE(random )
    _M_I_025901e83fb4cd98 [17:0b] VQ 80000001003df6b0 target "FR_VTO" (#1, 18-0 components): SELECT ANY by statistic StatAgentLoading(random)
    _M_I_025901e83fb4cd98 [10:0c] tenant Resources Place FR_VTO_660: dn 660(ready since 1301302768) is OK
    _M_I_025901e83fb4cd98 [17:0b] component #1 FR_VTO_660: statvalues: 0 1301302768 23182(S) the best
    _M_I_025901e83fb4cd98 [10:0c] tenant Resources Place FR_VTO_661: dn 661(ready since 1301302611) is OK
    _M_I_025901e83fb4cd98 [17:0b] component #2 FR_VTO_661: statvalues: 0 1301302611 1390(S) the best
    _M_I_025901e83fb4cd98 [17:0b] component #3 FR_VTO_662: statvalues: 0 1301302924 25054(S) pass
    _M_I_025901e83fb4cd98 [10:0c] tenant Resources Place FR_VTO_663: dn 663(ready since 1301302453) is OK
    _M_I_025901e83fb4cd98 [17:0b] component #4 FR_VTO_663: statvalues: 0 1301302453 16841(S) the best
    _M_I_025901e83fb4cd98 [17:0b] component #5 FR_VTO_664: statvalues: 0 1301302955 21493(S) pass
Mon Mar 28 11:02:40 2011.898_M_I_ [10:0a] object 665|FR_Paris| is unblocked
    _M_I_025901e83fb4cd98 [10:0c] tenant Resources Place FR_VTO_665: dn 665(ready since 1301302078) is OK
    _M_I_025901e83fb4cd98 [17:0b] component #6 FR_VTO_665: statvalues: 0 1301302078 14912(S) the best
    _M_I_025901e83fb4cd98 [17:0b] component #7 FR_VTO_666: statvalues: 0 1301302935 26150(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #8 FR_VTO_667: statvalues: 0 1301302592 25375(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #9 FR_VTO_668: statvalues: 0 1301302586 24658(S) pass
Mon Mar 28 11:02:40 2011.940_M_I_ [10:0a] object 669|FR_Paris| is unblocked
    _M_I_025901e83fb4cd98 [10:0c] tenant Resources Place FR_VTO_669: dn 669(ready since 1301302056) is OK
    _M_I_025901e83fb4cd98 [17:0b] component #10 FR_VTO_669: statvalues: 0 1301302056 1058(S) the best
    _M_I_025901e83fb4cd98 [17:0b] component #11 FR_VTO_670: statvalues: 0 1301302511 3374(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #12 FR_VTO_671: statvalues: 0 1301302355 9947(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #13 FR_VTO_672: statvalues: 0 1301302248 14465(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #14 FR_VTO_673: statvalues: 0 1301302924 5703(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #15 FR_VTO_675: statvalues: 0 1301302797 10120(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #16 FR_VTO_676: statvalues: 0 1301302060 27789(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #17 FR_VTO_677: statvalues: 0 1301302258 25072(S) pass
    _M_I_025901e83fb4cd98 [17:0b] component #18 FR_VTO_674: statvalues: 0 1301302443 4026(S) pass
    _M_I_025901e83fb4cd98 [17:0b] VQ 80000001003df6b0 target "FR_VTO": component FR_VTO_669 was SELECTED
    _M_I_025901e83fb4cd98 [17:0e] target FR_VTO: statvalue: 6.7384868923e-07(N) the best
    _M_I_025901e83fb4cd98 [17:0e] virtual queue "__##IVR_VQ_NAME__"(id=15620), VQ 80000001003df6b0: target "FR_VTO" for route was SELECTED
    _M_I_025901e83fb4cd98 [01:0d] attempt to route (0)
    _T_I_025901e83fb4cd98 [0E:19] check call routing states: state=4 delivery=0 treatment=1 held=0 reserving=0 - true
========== DN Information ===========
DN Number 669
Agent Name
Place Name FR_VTO_669
Agent Login
Switch Name FR_Paris
DN Type 7
====================== Target Information =====================
Target Name    < FR_VTO >
Target Location < StatServer_Tz_EU-Wb >
Target Type    < GP >
STATE MAPPING INFO - STATISTIC < ##state >:
Stat Server DN info available
Modelling Statistic  : NOT available
    _I_I_025901e83fb4cd98 [01:0f] binding with target 80000001023507a8
    _I_I_025901e83fb4cd98 [0E:11] HERE IS ROUTE_IVR
    _I_I_025901e83fb4cd98 [0E:03] NO TRANSLATION for this call
Mon Mar 28 11:02:40 2011.941_T_I_025901e83fb4cd98 [14:19] send to tserver FR_TServer_760 RequestRouteCall to dn 669 on  (dnis= )
request to 65218(FR_TServer_760) message RequestRouteCall
AttributeReferenceID 7024
AttributeRouteType 0 (RouteTypeUnknown)
AttributeExtensions [196] 00 0A 00 00..
'DEFAULT#' '5830000'
'CUSTOMER_ID' 'Resources'
'VQ' '__##IVR_VQ_NAME__'
'AGENT' ''
'PLACE' 'FR_VTO_669'
'DN' '669'
'ACCESS' '669'
'SWITCH' 'FR_Paris'
'NVQ' 20000
'TARGET' 'FR_VTO@StatServer_Tz_EU-Wb.GP'
AttributeOtherDN '669'
    _A_I_025901e83fb4cd98 [0E:04] ----------->ARRIVAL
    _B_I_025901e83fb4cd98 [0E:11] IVRTreatment was continued===========>TREATMENT_REQUEST
Mon Mar 28 11:02:40 2011.941_M_I_0000000000000000 [10:1b] blocking: agent , place FR_VTO_669, switch FR_Paris dn 669 is blocked for 45 sec by 1000000001 expired 1301303005
    _I_I_025901e83fb4cd98 [01:06] treatment moved: type=IVR, param1=FR_Menu_old, param2=FR_VTO@StatServer_Tz_EU-Wb.GP, tout=-1
AttributeCallType 2
AttributeUserData [289] 00 0E 00 00..
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
AttributeTimeinSecs 1301302960 (11:02:40)
AttributeTimeinuSecs 924000
attr_#148 000000000001bc65
Mon Mar 28 11:02:41 2011.131_M_I_ [10:17] CHANGE OF STATE (tenant Resources object FR_5010 statserver StatServer_Tz_EU-Wb)
    _M_I_ [10:17] tenant Resources object FR_5010 statserver StatServer_Tz_EU-Wb: 0 ready DNs reported
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventRinging
AttributeThisTrunk 516
AttributeCallType 2
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
'GCTI_GLOB_CID' bin: 0F 4F 90 4D.. (len=8)
AttributeThisDN '669'
AttributeTimeinSecs 1301302961 (11:02:41)
AttributeTimeinuSecs 408000
attr_#148 000000000001bc69
Mon Mar 28 11:02:41 2011.455 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:41 2011.456_T_I_025901e83fb4cd98 [14:0c] EventRinging is received for tserver FR_TServer_760 (this dn=669)
    _T_I_025901e83fb4cd98 [14:09] add DN FR_TServer_760 669 <669@FR_Paris> (IVR 60 025901e83fb4cd98) to the call 5757-8000000102630dd0 truly
Mon Mar 28 11:02:41 2011.463_M_I_ [10:17] CHANGE OF STATE (tenant Resources object FR_VTO_669 statserver StatServer_Tz_EU-Wb)
    _M_I_ [10:17] tenant Resources object FR_VTO_669 statserver StatServer_Tz_EU-Wb: 0 ready DNs reported
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventRouteUsed
AttributeThirdPartyDN '669'
AttributeThirdPartyDNRole 2
AttributeThirdPartyTrunk 516
AttributeCallType 2
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
AttributeExtensions [227] 00 07 01 00..
'GCTI_OLD_GLOB_CID' bin: 0F 4F 90 4D.. (len=8)
AttributeTimeinuSecs 627000
attr_#148 000000000001bc6a
Mon Mar 28 11:02:41 2011.671 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:41 2011.671_T_I_025901e83fb4cd98 [14:0c] EventRouteUsed(normal) is received for tserver FR_TServer_760 (this dn=732)
    _T_I_025901e83fb4cd98 [14:0a] del DN (FR_TServer_760 732) truly(ref.id=7024)
    _I_I_025901e83fb4cd98 [01:0f] binding with target 0
Mon Mar 28 11:02:41 2011.671_M_I_025901e83fb4cd98 [13:03] call (virtual queue 800000010266a138, id=15620, priority 3) doesn't wait for VQ 80000001003df6b0 (name="__##IVR_VQ_NAME__") now
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventDiverted
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
AttributeCallType 2
attr_#148 000000000001bc6b
Mon Mar 28 11:02:41 2011.677 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:41 2011.677_T_I_025901e83fb4cd98 [14:0c] EventDiverted is received for tserver FR_TServer_760 (this dn=732)
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventOffHook
attr_#148 000000000001bc6c
received from 65218(FR_TServer_760)APP011FR:3000(fd=22) message EventEstablished
AttributeThirdPartyQueue '732'
AttributeCallType 2
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
attr_#148 000000000001bc6d
Mon Mar 28 11:02:41 2011.682 Std 04546 Invalid TLib message received from 65218(FR_TServer_760), wrong type of AttributeNetworkCallID
Mon Mar 28 11:02:41 2011.682_T_I_025901e83fb4cd98 [14:0c] EventEstablished is received for tserver FR_TServer_760 (this dn=669)
    _T_I_025901e83fb4cd98 [14:09] add DN FR_TServer_760 669 <669@FR_Paris> (IVR 64 025901e83fb4cd98) to the call 5757-8000000102630dd0 truly
Mon Mar 28 11:02:41 2011.682_A_I_025901e83fb4cd98 [14:0d] <-----------ARRIVAL
    _B_I_025901e83fb4cd98 [14:21] treatment applied===========>TREATMENT_APPLIED
Mon Mar 28 11:02:41 2011.682_M_I_025901e83fb4cd98 [10:1f] pulse for one call
    _T_I_025901e83fb4cd98 [0E:19] check call routing states: state=4 delivery=0 treatment=3 held=0 reserving=0 - true
Mon Mar 28 11:02:41 2011.711_M_I_ [10:17] CHANGE OF STATE (tenant Resources object FR_VTO_669 statserver StatServer_Tz_EU-Wb)
AttributeCallType 2
AttributeUserData [301] 00 0F 00 00..
'ANI' '0381479798'
'Subtypology' 'FCE'
'hierarchy' ' '
'TEL' '0381479798'
'COUNTRY' 'FR'
'DNIS' '5830732'
'Myscript' '2351'
'EAP' '2351'
AttributeTimeinuSecs 940000
attr_#148 000000000001bc6f
    _T_I_025901e83fb4cd98 [14:32] EventAttachedDataChanged is received for tserver FR_TServer_760 (this dn=669)
Mon Mar 28 11:02:42 2011.019_M_I_ [10:1d] PULSE (calls: 4(4)=4+0-0, targets=20, time=1301302961, mem=0,138945
[b]I stop the log hear because I see other call for Italia and Spania.
This call on next stop was block and I see only this step who repeat[/b]
« Last Edit: March 29, 2011, 04:53:40 AM by catvrom01 »
