" /> WfM Web Supervisor.... - Genesys CTI User Forum
Author Topic: WfM Web Supervisor....  (Read 4254 times)
Adam G
« on: July 15, 2011, 06:53:46 AM »
Yep - another WfM question... :)
IN WfM Configuration Utility I've set up a series of [i]Activities [/i]against a single Unit - each Activity contains Skills, Stats and Agents.
On the WfM Web Supervisor I have tried to apply the [i]Activities [/i]to the Unit on a [i]Forecast [/i]Template - but the [i]Activities [/i]are not (pre)listed when I try to create a [i]New Forecast Template [/i]against the Unit.
The Environment was restarted yesterday evening to see if it would clear the problem but it doesn't seem to have had any effect.
Has anyone come across this before?  Is there maybe a step I need to complete that I am missing...?
Thanks everyone!
[i]WfM Config Utility = 7.6.101.04
WfM Web Supervisor = 7.6.100.57[/i]
« Last Edit: July 15, 2011, 07:40:05 AM by tonytillyer »
Adam G
Re: WfM Web Supervisor....
« Reply #1 on: July 15, 2011, 09:16:48 AM »
  • Ha - another "undocumented feature" within WfM.... :)
    If you name the Business Unit with the [b]same name[/b] as the Sub-Unit, WfM calls for "Virtual" Activities instead of calling for actual Actvities.
    If you name the Business Unit with a suffix of (for example) "[b]NAME_[/b][i]UNIT[/i]" and the Sub-Unit (for example) "[b]NAME[/b]", then WfM calls for the "Virutal" Activities at the Sub-Unit level and they will appear on your list, when setting up a Template.
    Thanks Joris! :)
