" /> send Outbound campaign as Email? - Genesys CTI User Forum
Author Topic: send Outbound campaign as Email?  (Read 11766 times)
Offline thinkb4umail
« on: August 04, 2011, 02:17:12 AM »
Hello All,
We want to send our outbound campaigns as emails to customers.
Please let me know if this is possible.
Ex: When we have new customers, and we send them progressive campaigns, we would also like to send those customers emails thanking them.
How can this be achieved?
Re: send Outbound campaign as Email?
« Reply #1 on: August 04, 2011, 08:10:29 PM »
Yes, outbound email campaigns are supported by Genesys Proactive Routing. Please look at Genesys 7.6 Proactive Routing Solution Guide where you can find all required details including sample strategies.
« Reply #2 on: August 05, 2011, 02:32:48 PM »
Thanks Rene. I checked the document and it has Genesys strategy details.
Offline Vino
« Reply #3 on: January 14, 2013, 09:38:41 PM »
Hello All
I am new to eservices and trying to implement outbound email campaign which does not involve agents. Please let me know what dialing mode should i use ?
« Last Edit: January 14, 2013, 10:13:22 PM by Vino »
« Reply #4 on: January 15, 2013, 01:26:56 AM »
Please read the documentation as René stated, it is all explained there.
Offline JTL
« Reply #5 on: April 29, 2013, 03:58:52 PM »
I have been investigating this also...
In the Use Cases section, regarding Outbound Email Campaigns, it states:
A Proactive Routing solution could be used for the following use case:
• Create a template for the outbound e-mail.
• Create an Outbound List with e-mail address as one of the record
attributes.
• Configure a Campaign for proactive interaction routing.
• Routing strategy does not route interactions to the Agent Desktop, but
instead sends outbound e-mails using integrated Genesys E-mail
capabilities.
Which looks to meet my needs. I'm comfortable with the OCS configuration, but not so with the first bullet point - the creation of the template for the outbound e-mail.
Is there a reference document for this, since it is not described in the Proactive routing.
We have eServices 8.1 licensed and installed, but not readily used by my team.
« Reply #6 on: April 29, 2013, 04:06:34 PM »
On OCS create a ESP port (config manager)
Then do connection between IXN and OCS
Now create a new template (check OCS Ref. Guide)
- Simply create a new one (Format) from the existing one and add the user fields you may need
Create a Table access
Create a calling list with this format and table access
Associate to a campaign
Go!
Offline JTL
« Reply #7 on: April 29, 2013, 08:24:24 PM »
[quote author=cavagnaro link=topic=6564.msg33815#msg33815 date=1367251594]
Go!
I will set something up to test... I'm sure I can get something done in OCS to create the email.
I see that connection between IXN and OCS, and setup of the ESP is described in the Proactive Contact Guide.
BTW I found the v8.0 of this document, and it deals only with GVP!
« Last Edit: April 29, 2013, 08:39:12 PM by JTL »
« Reply #8 on: April 29, 2013, 08:46:29 PM »
Search for Proactive Routing Solution 7.6, it is the same for 8
Offline JTL
« Reply #9 on: April 29, 2013, 09:02:34 PM »
[quote author=cavagnaro link=topic=6564.msg33818#msg33818 date=1367268389]
yes, I already have it... I was looking for a newer copy and found v8, and was surprised it no longer mentions anything about Email, and is a GVP document.
Surprised it didn't have a different name!
« Reply #10 on: April 29, 2013, 09:15:42 PM »
Dont confuse the Proactive Solution Guide with the Proactive Routing Guide...
Offline JTL
« Reply #11 on: April 29, 2013, 09:18:24 PM »
[quote author=cavagnaro link=topic=6564.msg33820#msg33820 date=1367270142]
D'oh. Perhaps I already did.  :'(
Offline JTL
« Reply #12 on: April 30, 2013, 03:26:04 PM »
Go!
Ok, all of this is in place, in terms of IXN / ESP etc.
So the outstanding question is, how do I define what the actual email itself looks like?
« Reply #13 on: April 30, 2013, 04:09:00 PM »
???? Knowledge Manager Sir...
Please read more docs before, if you don't have a clear idea of all the Multimedia solution is going to be complex.
And not asking you not to ask, but there are something that asked is not the same as understood and read deeply will be the same.
Read URS Strategies samples, Multimedia components definitions, all of it not just pieces
Offline JTL
« Reply #14 on: April 30, 2013, 09:44:28 PM »
[quote author=cavagnaro link=topic=6564.msg33828#msg33828 date=1367338140]
Yes, you're quite right...
We have eServices installed, and used only for a small handful of inbound email interactions, which the agents do not reply with... so it is safe to say we don't use it very much. However, I cannot break what we already have, so I don't really get the opportunity to "play"...
When I installed Knowledge Manager earlier, it was totally blank, and even with the default account, I apparently don't have permissions to do anything with it, so I really need to go back through the docs and find out what's not setup correctly.
Looks like a few fun days with the PDFs in front of me... time I really don't have when I have production issues to resolve too :(
But it is the right thing to do...
