" /> Reg:Debugging strategies - Genesys CTI User Forum
Author Topic: Reg:Debugging strategies  (Read 4869 times)
Offline JJR
« on: December 18, 2011, 04:30:48 AM »
Hi
I have created a strategy and loaded. I would like to debug it but i am not seeing the debug option. I am able to see the trace options. Anyone help me out on this.
Thanks - JJR
Offline BenTaylor
Re: Reg:Debugging strategies
« Reply #1 on: December 19, 2011, 09:39:07 AM »
Are all the lights at the bottom green?
Offline JJR
« Reply #2 on: December 19, 2011, 03:50:29 PM »
Yes.. All the buttons are green. Still the option is not appearing.
« Reply #3 on: December 19, 2011, 04:05:00 PM »
Check both URS and IRD have connection to MessageServer
Offline kubikle
« Reply #4 on: December 19, 2011, 07:20:59 PM »
Is it only Debug option or Tracing related options too? Which IRD version is used?  (they was some problem with Debug option in few versions on 8.0.1 or 8.1). Do you able to see Trace view if just double click on strategy?
Offline JJR
« Reply #5 on: December 20, 2011, 08:55:23 PM »
Yes...Trace option is working. We are using the 7.0.001.04 version of IRD. I am not seeing the debug option. Earlier long back it was working.
Offline kubikle
« Reply #6 on: December 21, 2011, 06:26:56 AM »
On assumption version of URS matches (7.01.something) and IRD has just one Message server and if you make real calls then it is reflected in monitoring view (counters over strategy obejcts are increased) - no idea what can be wrong with debuging.
« Reply #7 on: December 21, 2011, 01:54:23 PM »
Just noted I have same issue at customer site... :S
IRD version buggy?
Offline fnunezsa
« Reply #8 on: December 23, 2011, 06:12:26 PM »
Are you looking for the debug option in the Monitoring section/tab or in the Design View (while editing the strategy)? The debug option is only available in the Design View
