" /> [Error code 1141] Request Complete Transfer rejected - Genesys CTI User Forum
Author Topic: [Error code 1141] Request Complete Transfer rejected  (Read 10049 times)
Offline genecool
« on: January 05, 2012, 11:46:28 AM »
I encounter an error 1141 when I try to perform a call tranfer :
[quote]
12:31:36.168 Trc 36002 Request rejected: error code 1141(CSTA error: operationalErrors : requestIncompatibleWithObject)
@12:31:36.1680 [0] 8.1.000.09 send_to_client: message EventError
(Request incompatible with object)
AttributeEventSequenceNumber 00000000000006a5
AttributeTimeinuSecs 168000
AttributeTimeinSecs 1325763096 (12:31:36)
AttributeErrorCode 1141
AttributeErrorMessage 'CSTA error: operationalErrors : requestIncompatibleWithObject'
AttributeConnID 006c01fff2906001
AttributeOtherDN '00165563155'
AttributeLocation ''
AttributeReason [2] 00 00..
AttributeExtensions [2] 00 00..
AttributeUserData [2] 00 00..
AttributeThisDN '3968615'
AttributeReferenceID 8
AttributeClientID 5
12:31:36.168 Int 04545 Interaction message "EventError" sent to 520 ("IW_3975615")
12:31:36.168 Trc 04542 EventError sent to [520] (00000005 IW_3975615 192.168.11.1:2248)
  -- deleted: CRequest@266d3ac RequestCompleteTransfer-IW_3975615[520]/8
  -- AckQueues(): CRequest@266d3ac RequestCompleteTransfer-IW_3975615[520]/8 1c017f0
  -- AckQueues(): CRequest@266d3ac RequestCompleteTransfer-IW_3975615[520]/8 1c7b448
Have you any idea to solve it ?
Offline Fra
Re: [Error code 1141] Request Complete Transfer rejected
« Reply #1 on: January 05, 2012, 02:31:27 PM »
1. Check the exact message coming from the CTI link.
2. Verify that that the type of transfer you are trying to perform is supported by the switch TServer is connected to.
Fra
Offline fnunezsa
« Reply #2 on: January 06, 2012, 01:11:02 AM »
seems like you're trying to complete the transfer but the call either does not exist any more or is not on hold any more. full TServer log will help to figure out what state is the call really in, including the message received from the switch
Offline genecool
« Reply #3 on: January 06, 2012, 12:22:36 PM »
Please find complete log file in attachment
I use T-Server for Alcatel A4400/OXE and I think that all types of call transfer are supported.
Offline fnunezsa
« Reply #4 on: January 06, 2012, 05:48:41 PM »
You have to get you OXE Admin to take a look into this one.
This is what I can see from the provided logs:
1) RequestSingleStep transfer is issued at 12:56:03
[color=red]12:56:03.819 Trc 04541 RequestSingleStepTransfer received from [516] (00000006 IW_5216615 192.168.20.1:2902)
message RequestSingleStepTransfer
AttributeThisDN '5266615'
AttributeOtherDN '00156715155'
AttributeConnID 006c020008041001
12:56:03.819 Int 04543 Interaction message "RequestSingleStepTransfer" received from 516 ("IW_5216615")
12:56:03.819  -- created: CRequest@27e2dac RequestSingleStepTransfer-IW_5216615[516]/8
12:56:03.819 +++ CIFace::Request +++
  -- new invoke
  -- replace substitution with real device
  -- thisCall by party
  -- replace group with real device
  Parsed: RequestSingleStepTransfer/RequestInitiateTransfer
  Numbers: +<5216615> -<00156715155>
  Calls: 27e2fd8:1 none
  Parties: 5216615.2803e98-27e2fd8:1
          none
  Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
[/color]
2) EventNetworkReached is received at 12:56:04
[color=red]
12:56:04.237 --- Input ---
12:56:04.237 +++ Input +++
  -- monitor: 5216615
  +++ CIFace::Event +++
    +++ Pre-event +++
      Type EventNetworkReached
      Devices: <5216615/5216615> <-/-> <-/->
      Calls: 4308/006c020008041001^4308.2803708/c:1/r:0['10 d4'H] 0/none
      Network ID: 53e1064fd4106300:0
      Parties: d5266615/5216615.2803bf0-2803708:2/l:1/r:0/Dialing,Active,Origination[c='10 d4'H d=dynamicID : '03 d3 01 00'H]
      X00156715155/00156715155.2803d38-2803708:2/l:2/r:0/Null,Destination[c='10 d4'H d=dynamicID : '06 1f 01 04'H]
      none
      ANI/DNIS: <none> <00156715155>
      Cause: NewCall/22, Info: 0
      Call type: Outbound/3
      Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=0
      PBX time stamp: 12:56:04.000
    --- Pre-event ---
    RSItched with CRequest@27e2dac RequestInitiateTransfer-IW_5216615[516]/8
    -- emulating single-step
    +++ NetworkReached +++
      SetNetworkReached: party 5216615^2803bf0-2803708:2, cause SingleStepTransfer
      -- party not bound: message cleared
    --- NetworkReached ---
    +++ Post-event +++
      Parties: d5266615/5216615.2803bf0-2803708:2/l:1/r:0/NetworkReached,Active,Origination[c='10 d4'H d=dynamicID : '03 d3 01 00'H]
      none
      Cause: SingleStepTransfer/52, Info: 0
[/color]
3) RequestCompleteTransfer (Internal message) is issued at 12:56:04
[color=red]
12:56:04.980 --- Input ---
12:56:05.234  Q state:RQ[0,0]
12:56:05.234 CIFace: Sent CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8
12:56:05.234 -- request was queued
12:56:05.234  -- RegisterQueue: CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8 1e2c678 RQ[0,1]
12:56:05.234  -- RegisterQueue: CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8 26653c0 RQ[0,1]
12:56:05.234 +++ Input +++
  CSTA2Server::Response(): RQ[0,1], sent: 1
  Response (1141): for CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8
  -- error reporting postponed
  FinishRequest CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8
  IFace stats: q=0 s=0
  -- recycled
  -- AckQueues(): CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8 26653c0
  -- AckQueues(): CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8 1e2c678
  -- DelayRequest: 250 msec
12:56:05.234 --- Input ---
12:56:05.484 +++ CIFace::Request +++
  -- new invoke
  Parsed: RequestSingleStepTransfer/RequestCompleteTransfer
  Calls: 27e2fd8:1 2803708:2
  -- validate
  -- state check: ok
  Q state:RQ[0,0]
  -- RegisterQueue: CRequest@27e2dac RequestCompleteTransfer-IW_5216615[516]/8 1db1848 RQ[0,1]
[/color]
4) At this point there seems to start some kind of loop: attribute "-- recycled" is seen from this point on until 12:56:11
5) At 12:56:11 " -- recycling limit reached!" is seen in logs
6) Request is rejected by OXE:
[color=red]
12:56:11.733 Trc 36002 Request rejected: error code 1141(CSTA error: operationalErrors : requestIncompatibleWithObject)
[/color]
OXE Admin should pay attention to the loop that last around 8 seconds
« Reply #5 on: January 07, 2012, 05:55:57 PM »
You are transferring to an external number, right?
On OXE you should check:
1. Connection Category for your agent and your Trunk
2. If you are using another trunk to do the transfer also check the parameter "DTO Join" set to true on the Trunk Groups.
This is absolutely an OXE issue
Regards
