" /> gplus-analytics-id - Genesys CTI User Forum
Author Topic: gplus-analytics-id  (Read 2501 times)
Offline H@l
gplus-analytics-id
« on: April 10, 2012, 09:22:43 AM »
Goodday,
We use GPlus Adapters for "SAP analytics" and "ICI Multi-Channel". (Voice only).
In order to 3-way link a SAP interaction record, a SAP BW record and a Genesys ICON record, the field "gplus-analytics-id" is used. If I understand it correctly this ID is generated when a telephony interaction is sent from Genesys to SAP ICI (EIC/CRM) via the "GPlus Adapter for ICI Multi-Channel".
The content is for example:  "-22252cdd:1365dcfae9d:-7ff7".
Question: where is the format and the content defined?
I can't find a configuration option within the Genesys world.
If possible I'd like to use the ConnId for its value.
Please advise. Thanks in advance.
Offline aj
Re: gplus-analytics-id
« Reply #1 on: April 11, 2012, 12:34:17 PM »
Not amazing helpful but perhaps provide some insight: http://solutionsearch.genesyslab.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=11489&sliceId=1&docTypeID=DT_SOLUTION_1_1&dialogID=21406968&stateId=0%200%2021408401
I guess in theory you could over-ride the Java class etc etc but I'm 100% sure it wouldn't be supported and almost as sure that it wouldn't be worth the effort.
