" /> Composer Debugger NOT Working. - Genesys CTI User Forum
Author Topic: Composer Debugger NOT Working.  (Read 6266 times)
Offline kevinwang
« on: August 01, 2012, 06:30:49 PM »
My Composer Debugger suddenly stop Working, used to work.
error msg is unable to fetch content, but I can access to this vxml link from host where MCP installed.
fetch_end Fail (Unable to fetch content):http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
any thoughts?
following is the related log:
2012-08-01T14:21:24.327 Std 20004 EROR 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:667 Request failed: uri=http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml?session%2econnection%2ecallidref=74d8fe80e7c3d3890d6f6d81866f01a3%4010%2e8%2e142%2e147&session%2econnection%2elocal%2euri=sip%3adialog%4010%2e36%2e141%2e193%3a5070%3bvoicexml%3dhttp%3a%2f%2f10%2e8%2e142%2e147%3a8080%2fHelloWorld%252Fsrc%2dgen%252FMain%2evxml%3bgvp%2edebug%3dtrue&session%2econnection%2eoriginator=remote&session%2econnection%2eremote%2euri=sip%3a4001%4010%2e8%2e142%2e147%3a50601, result=7
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:769 HTTP request completed
2012-08-01 14:21:24.327 DBUG 00000000-00000000 3444 01F00000 FMResponseData.cxx:405 Received fetch completed, response code=0
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:1416 Response is not cacheable
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMUserRequest.cxx:468 Request completed, sending RequestCompleteNotify.
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:1179 Processing ReleaseRequest
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMUserRequest.cxx:127 Deleting Request
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1888 ProcessEvents() Started
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1905 ProcessEvents() Event type [1], session id: [00E90101-10003A99]
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1319 HandleFetchEvent(): Process state: 6, response code: 0, error: Unable to fetch content, uri: http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
2012-08-01T14:21:24.327 Int 50043 00E90101-10003A99 4460 fetch_end Fail (Unable to fetch content):http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
2012-08-01T14:21:24.327 Std 40027 EROR 00E90101-10003A99 4460 0C0003F9 Fetch error on url http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml, reason Unable to fetch content, callid 00E90101-10003A99
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1894 ProcessEvents() Event queue was empty
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4340 0C000000 AppEventBase.h:61 app.VXML-NG AMEVENT_VXML_DIALOG_PREPARED - failed fetch document
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4340 0C000000 AppCallLeg.h:125 Call Leg CallInReject
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4992 01C00000 CMMsgBase.h:183 cmapi.msg:  CM_MSG_CALLLEG_INB_REJECT - CallObjID == 00E90101-10003A99; Binding State == 1
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4992 01C00000 CMCallLeg.C:2317 CMCallLeg::DisconnectLine - pszDiscContentType=, pszDiscContent=
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIP.C:1429 In CallDisconnect
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIP.C:1471 LMCallSIP::CallDisconnect - strContentType=, strContent=
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIPStack.C:203 LMCallSIP::SendResponse for ID Headers
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIPStack.C:225 LMCallSIP::SendResponse - X-Genesys-GVP-Session-ID: FF06AD46-33A8-40FC-3F90-F7CF6E7AB1F0
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4880 08500000 VGSIPTransportMgr.cxx:3443 VGSIPTransportMgr::ResolveDNS for 10.8.142.147:50601
2012-08-01T14:21:24.327 Trc 33009 INFO 00000000-00000000 4880 02800FA1 Response sent: SIP/2.0 500 Server Internal Error
Via: SIP/2.0/TCP 10.8.142.147:50601;branch=z9hG4bK-353730-808ef3c9be399b53315fd88cf86c15a4
From: "Debugger" <sip:4001@10.8.142.147:50601>;tag=JLG1yz3nZnV1
To: "dialog" <sip:dialog@10.36.141.193:5070;voicexml=http://10.8.142.147:8080/HelloWorld%2Fsrc-gen%2FMain.vxml;gvp.debug=true>;tag=8C7EF499-FCAD-4035-9ABE-6B410CA97910
CSeq: 1 INVITE
Re: Composer Debugger NOT Working.
« Reply #1 on: August 02, 2012, 09:05:10 AM »
Develop Tomcat is started? Composer has integrated Tomcat which have provided debug calls of VXML files on app srv.
Offline kevinwang
« Reply #2 on: August 02, 2012, 12:14:59 PM »
Yes,  as I said  I can access to this vxml link from host where MCP installed.
Tomcat is the one installed by default when Composer was installed.
« Reply #3 on: August 02, 2012, 12:31:49 PM »
What version of MCP do you use?
Release 8.1.4 and lower contained a "bug",which causes failure of fetching
« Last Edit: August 02, 2012, 12:38:18 PM by Kubig »
Offline kevinwang
« Reply #4 on: August 02, 2012, 01:47:27 PM »
8.1.504.86, latest one.
« Reply #5 on: August 02, 2012, 02:16:23 PM »
And can you open/access VXML URI from other host? I mean that is a network trouble maybe
Offline kevinwang
« Reply #6 on: August 02, 2012, 02:54:20 PM »
Yes,  it looks like it's network issue. but I did try to access to vxml link from other hosts.
But My understanding is it's enough that VXML can be accessed from MCP host, for MCP is vxml intepreter.
