" /> EventDesitnationBusy for a IVR port in a GVP integration throught IVR Server. - Genesys CTI User Forum
Author Topic: EventDesitnationBusy for a IVR port in a GVP integration throught IVR Server.  (Read 12054 times)
Offline kevinwang
It's a GVP integration mode throught IVR Server.
a IVR port can got eventringing, but after that, hang up, there is an EventDesitnationBusy error.
there are a lot of error msg "Unable to resolve number for DN:GVP"," Gateway for address '10.36.141.193', number 'GVP' is not found." in sip log.
Is this GVP DN a default DN? do I have to create it? does it have anything to do with the error "EventDesitnationBusy " ???
below is the related SIP log.
any thoughts?
thanks in advance.
11:08:57.852: $+NET:SIP::0:0
11:08:57.853: SIPTR: Received [0,UDP] 408 bytes from 10.36.141.193:5064 <<<<<
OPTIONS sip:10.36.141.192:5060 SIP/2.0
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK0000000019A774E0325309
[size=14pt][b]From: <sip:GVP@10.36.141.193:5064>;tag=21E60A5E-6099-4A94-D9A3-08BE55CA5CE4[/b][/size]
To: sip:10.36.141.192:5060
Max-Forwards: 70
CSeq: 510323 OPTIONS
Call-ID: 529C016A-4EF6-4846-C7A9-44741B8A0756-5064@10.36.141.193
Contact: <sip:GVP@10.36.141.193:5064>
Content-Length: 0
Supported: timer, uui
11:08:57.853: Unable to resolve number for DN:GVP
11:08:57.853: trunk ip addr 10.36.141.193
11:08:57.853 Std 52002 Gateway for address '10.36.141.193', number 'GVP' is not found.
11:08:57.853: Sending  [0,UDP] 327 bytes to 10.36.141.193:5064 >>>>>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK0000000019A774E0325309;received=10.36.141.193
Content-Length: 0
11:08:57.853: $-NET:SIP::0:511
11:08:58.846: $+NET:SIP::0:0
11:08:58.846: SIPTR: Received [0,UDP] 408 bytes from 10.36.141.193:5064 <<<<<
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK000000001A0F01E032530a
From: <sip:GVP@10.36.141.193:5064>;tag=D1970905-B329-4A08-4C83-838855EA3C4A
Max-Forwards: 70
CSeq: 510328 OPTIONS
Call-ID: 5C8D049F-03CA-49ED-6099-6D21C24A03A7-5064@10.36.141.193
Content-Length: 0
11:08:58.846: Unable to resolve number for DN:GVP
11:08:58.846: trunk ip addr 10.36.141.193
11:08:58.846 Std 52002 Gateway for address '10.36.141.193', number 'GVP' is not found.
11:08:58.846: Sending  [0,UDP] 327 bytes to 10.36.141.193:5064 >>>>>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK000000001A0F01E032530a;received=10.36.141.193
Content-Length: 0
11:08:58.846: $-NET:SIP::0:459
11:08:59.853: $+NET:SIP::0:0
11:08:59.853: SIPTR: Received [0,UDP] 408 bytes from 10.36.141.193:5064 <<<<<
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK000000001A0EF9A032530b
From: <sip:GVP@10.36.141.193:5064>;tag=A9445E71-5094-430E-8EAF-AE93A02A349D
Max-Forwards: 70
CSeq: 510333 OPTIONS
Call-ID: 5EFED0A2-D90A-4B67-68AD-65C04E3B6289-5064@10.36.141.193
Content-Length: 0
[b][size=12pt][color=red]11:08:59.853: Unable to resolve number for DN:GVP
11:08:59.853: Unable to resolve number for DN:GVP[/color][/size][/b]
11:08:59.853: trunk ip addr 10.36.141.193
[color=red][b]11:08:59.853 Std 52002 Gateway for address '10.36.141.193', number 'GVP' is not found.[/b][/color]
11:08:59.853: Sending  [0,UDP] 327 bytes to 10.36.141.193:5064 >>>>>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.36.141.193:5064;branch=z9hG4bK000000001A0EF9A032530b;received=10.36.141.193
Content-Length: 0
11:08:59.853: $-NET:SIP::0:469
11:09:00.732: $+NET:SIP::0:0
11:09:00.732: SIPTR: Received [0,UDP] 882 bytes from 10.36.141.193:5060 <<<<<
SIP/2.0 480 Temporarily Unavailable
Via: SIP/2.0/UDP 10.36.141.192:5060;branch=z9hG4bKFC41DA6E-D364-4C67-A458-FB5285D1C7A6-33
From: sip:4001@10.36.141.192:5060;tag=7D2A1C3D-D914-4610-B03A-F02556A1F858-26
To: <sip:12001@10.36.141.192:5060>;tag=456458A8-A689-4536-2DB5-A2EA038547BE
CSeq: 1 INVITE
Call-ID: 248C1375-1D32-4C37-9F7A-0E8A45D1C9F5-14@10.36.141.192
Contact: sip:CTIConnector@10.36.141.193:5080
Content-Length: 0
Record-Route: <sip:000000000D54F1B0@10.36.141.193:5060;lr;gvp.rm.datanodes=1;idtag=00000031>
X-Genesys-GVP-Session-ID: 18C214C9-FD60-4F6A-DFBF-069B3A3E52BF;gvp.rm.datanodes=1;gvp.rm.cti-call=1
X-Genesys-GVP-CDR: CALL-DISPOSITION=0;QUEUE-WAIT-TIME=0.000000
X-Genesys-CallInfo: routed
X-Genesys-CallUUID: E8OI3STMD150NCD4SM8SOM7A88000008
X-Genesys-GVP-Session-Data: callsession=18C214C9-FD60-4F6A-DFBF-069B3A3E52BF;1;0;;sip:10.36.141.193:5080;;;;
11:09:00.732: Sending  [0,UDP] 451 bytes to 10.36.141.193:5060 >>>>>
ACK sip:30019@10.36.141.193:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 69
User-Agent: X-Lite release 1100l stamp 47546
Content-Length: 0
11:09:00.732: SipDialog: event CALLING_RESREJECT, t=1694, s=9, r=5, m=00000000040a0788
11:09:00.732 SIPCONN(30019): HandleSipDialogEvent(CALLING_RESREJECT)
11:09:00.732 SIPCONN(30019): 1pcc event CALLING_RESREJECT
11:09:00.732 SIPCONN(30019): ConvertResponse: 480
11:09:00.732 SIPCONN(30019): ConvertResponse: no conversion configured for 480
11:09:00.733 SIPCONN(30019): state e:4,p:2,s:6,c:10,rc:480,m:1
11:09:00.733 SIPPARTY(30019): 24 verify update of party-connection state A-F
11:09:00.733 SIPPARTY(30019): 24 update party-connection state A-F
11:09:00.733 +++ CIFace::Event +++
  +++ Pre-event +++
    Type EventDestinationBusy
    Devices: <4001/4001> <30019/30019> <-/->
    Calls: 8/00700212bebaa008/8.04016330/c:2/r:1 0/none
    Parties:    D4001/4001.03f10af0-04016330:1/l:1/r:0/Dialing,Active,Origination
                D30019/30019.035548a0-04016330:1/l:2/r:0/Alerting,DNull,Destination
                none
    Cause: Busy/3, Info: 0
    Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=1
  --- Pre-event ---
  +++ DestBusy +++
    -- target state not compatible at line 1174
    SetFailed: party 4001.03f10af0-04016330:1, cause Busy
@11:09:00.7330 [0] 8.1.000.79 [size=12pt][b]distribute_event: message EventDestinationBusy[/b][/size]
        AttributeEventSequenceNumber    000000000000124a
        AttributeTimeinuSecs    733000
        AttributeTimeinSecs    1345475340 (11:09:00)
        AttributeExtensions    [23] 00 01 01 00..
                'BusinessCall'  0
        AttributeOtherDNRole    2
        AttributeOtherDN        '30019'
        AttributeThisDNRole    1
        AttributeThisDN '4001'
        AttributeCustomerID    'Resources'
        AttributeDNIS  '12001'
        AttributeUserData      [567] 00 17 00 00..
                'userdata1'    'test1'
Hi Kevin,
The error message 52002 (Gateway for address...) is caused by missing Trunk DN object in Genesys configuration with IP address 10.36.141.193.
Your issue is caused by 480 Temporarily Unavailable error that is returned as response to original INVITE. I assume this error is returned by Resource Manager but it could be error from CTI Connector as well.
[quote]11:09:00.732: SIPTR: Received [0,UDP] 882 bytes from 10.36.141.193:5060 <<<<<
CSeq: 1 INVITE
Content-Length: 0
X-Genesys-GVP-Session-Data: callsession=18C214C9-FD60-4F6A-DFBF-069B3A3E52BF;1;0;;sip:10.36.141.193:5080;;;;[/quote]
PS. Sorry for no-reply on your PM. I simply forgot :-(
Offline kevinwang
[quote author=René link=topic=7368.msg31503#msg31503 date=1345490082]
Hi Kevin,
CSeq: 1 INVITE
Content-Length: 0
Rene, Thank you very much, I need to check RM log more carefully.
Offline kevinwang
Hi Kevin,
CSeq: 1 INVITE
Content-Length: 0
I have the all the related logs for one specific call and exported CFG DB, can you help take a quick look?
Kevin.
Try to create Voice over IP Service which is called "GVP",pointed to RM and is set like an application (service-type=application).
I have this settings in my LAB and all works fine
Offline kevinwang
[quote author=Kubig link=topic=7368.msg31519#msg31519 date=1345559864]
Thanks you for  sharing your experience.
I just tried, still got EventDestinationBusy.
Kevin
Offline kevinwang
Hi Kevin,
CSeq: 1 INVITE
Content-Length: 0
forgot to tell, Cfg DB is oracle.
Offline Fra
That DN is used for a behind SIP Server implementation, this one is instead via IVR Server.
Fra
Offline bublepaw
Hi Kevin,
As mentioned at some other threads - do You really need integration through IVR server? Integration through SIP is much easier to configure and debug.
Pawel
[quote author=Fra link=topic=7368.msg31529#msg31529 date=1345626586]
Fra
Sure, you're right. I noticed,that this is a IVR and not SIP,later.
Offline kevinwang
[quote author=bublepaw link=topic=7368.msg31541#msg31541 date=1345640856]
Hi Kevin,
Pawel
YOu are totally right, INtegration through sipserver is easier and more straightforward,,,easy for debug....
but I migrated from a legacy system, the integration mode of which is through IVR Server.
