" /> Change style of case information in interaction window - Genesys CTI User Forum
Author Topic: Change style of case information in interaction window  (Read 2666 times)
Offline alaint
« on: November 06, 2012, 02:40:30 PM »
I have to change de text color of some case information in Interaction Window.  But, I dont want to replace the complete view by a custom view.  I want to know if someone know how to do that?
Tkx.
Alain
Re: Change style of case information in interaction window
« Reply #1 on: November 06, 2012, 03:00:31 PM »
If you want to change only color of case data,you can use option on IWS object in CME. For other cases you have to make this via own code(PSDK).
Offline alaint
« Reply #2 on: November 06, 2012, 04:32:55 PM »
My need Is : by exemple, I have 4 case data show in the case information section of Interaction Window.  I want to change the font color of only one of these and only if the value of this case data equal a predefined value.
