" /> SIP Endpoint and Citrix capacity - Genesys CTI User Forum
Author Topic: SIP Endpoint and Citrix capacity  (Read 3801 times)
Offline Allan
« on: May 20, 2013, 09:35:31 AM »
I am struggling to find the capacity requirements on Citrix Xenapp 6.5 environment for SIP Endpoint in a 8.1 environment.
Any pointers appreciated.
Allan
Re: SIP Endpoint and Citrix capacity
« Reply #1 on: May 20, 2013, 10:32:00 AM »
What capacity req. do you mean? I have installed a few installation with SIP on Citrix and I never solve any capacity. Citrix is only a  layer on OS and the capacity for SIP comm is necessary to compute/solve on OS site.
Offline Allan
« Reply #2 on: May 20, 2013, 11:59:30 AM »
Thanks for the response. There is capacity from the data centres to the call centres via a WAN link with QOS. If we use IP turrets then there is only IWS that will be run over Citrix. If I use SIP end points instead of IP turrets, I need to understand what additional capacity/infra-structure would be required on the Citrix infra-structure to support SRTP running over lca session.
Is that clearer?
« Reply #3 on: May 20, 2013, 01:48:09 PM »
It depends on many things like a used codec for IP communication, count of call per day, simultaneous calls, etc.
« Reply #4 on: May 24, 2013, 01:03:00 PM »
Hi Allan,
FYI - Genesys SIP Endpoint is not officially supported on any virtual environment...
