" /> Mapping T-Lib to the SIP messages - Genesys CTI User Forum
Author Topic: Mapping T-Lib to the SIP messages  (Read 5672 times)
« on: May 28, 2013, 12:09:13 PM »
Hi Folks,
has anybody experience with mapping of T-Lib events to the SIP messages? Actually I am solving the issue with transferring calls to the IVR from an agent, so for this scenario is necesarry to fill history-info header in SIP message, which was received by GVP to correct mapping of IVR profile. Does anybody know how to map these information? I have read the doc and chapter about it, but without success.
many thanks in advance
Offline Grand_Master
Re: Mapping T-Lib to the SIP messages
« Reply #1 on: May 29, 2013, 01:00:17 AM »
Sipspan2?
« Reply #2 on: May 29, 2013, 06:56:45 AM »
SipSpan2 is not providing what I need. Why do you think so? I need standard SIP server function mapping T-Lib events to the SIP messages, which is unfortunately few described in doc and all my attempts failed.
« Reply #3 on: May 29, 2013, 07:05:05 AM »
I suggested sipspan2 because one of the examples in the doc in it's main folder specifically describes a sip+tlib callflow extraction.  Pity that it does not provide what you require.
« Reply #4 on: May 29, 2013, 07:12:40 AM »
You do not understand me. I need map T-Lib events during the call for GVP purposes, not for debug or post-analyse. Pleas, if you want to help me, read the topic clearly or read about the mapping funcionality before. But thx for your effort to help
« Reply #5 on: May 29, 2013, 07:38:36 AM »
Hi Kubig,
You didn't write how transfer to GVP is made... Does agent transfer call to Routing Point or it is direct transfer to number that is routed by SIP Server to GVP (via trunk)?
It is important to know as TLib->SIP mapping works for the RequestRouteCall request only.
Would it be possible to modify your IVR application to use other key?
« Reply #6 on: May 29, 2013, 07:56:54 AM »
Yep, sorry. The transfer is made via RP with routing to the PlaceGroup with VTP ports. So, currently is not possible or is not easy to change anything in routing or in GVP application. So, I need and I am quite wondering how the mapping works and how to configure it. Do you have any experience with it, René?
« Reply #7 on: May 29, 2013, 08:44:53 AM »
Hi Kubig,
It's a good message that transfer is made via routing strategy (RP) :)
It will be necessary to modify the strategy to support mapping. You must attach the keys below to AttributeExtensions before call is routed to place group:
ExtensionUpdate['SIP_HEADERS','History-Info']
ExtensionUpdate['History-Info','<required value>']
« Reply #8 on: May 29, 2013, 01:15:49 PM »
Very strange, if I add Extension update or attach, it is not necessary now, the reqeust RequestRouteCall end with error on SIP site. If I remove these extension update, all works fine. René, did you try it anytime in practice?
« Reply #9 on: May 29, 2013, 02:44:46 PM »
Hi Kubig,
I did quick test and it worked. However, my lab is not configured to support direct calls to GVP. So I tested just 'redirect' to RM and checked logs to verify that History-Info header is present in the INVITE message.
It would be great if you can show me your SIP Server log and especially the error.
PS. PM me if you can't post the log here due to size.
PPS. Muzes psat cesky ;D
« Reply #10 on: May 31, 2013, 08:18:47 AM »
Hi René,
you are right, it worked. I did a restart of my lab server and then all works fine.
Thanks for your help
PS: Cesky umim, alespon si procvicim anglictinu  ;D
