" /> GAD From Adress Drop down - Genesys CTI User Forum
Author Topic: GAD From Adress Drop down  (Read 2674 times)
Offline gzooby
  • Software Engineer at Telefax S.A.
« on: September 13, 2013, 06:10:36 PM »
I have defined a pop client and smtp client in email server and it`s working fine. However, I need, when agents answering an email interaction to have 2 addresses in FROM drop down list, but both using the same pop- client
My pop and smtp client address : callcenter@anda.com.uy
But I want to have an additional address for the agents to have in GAD , noreply@anda.com.uy so if they dont want the clients to reply them.
Is this possible??
Thanks!!!
Re: GAD From Adress Drop down
« Reply #1 on: September 13, 2013, 07:33:53 PM »
If not wrong you can add it under Business Attributes. Not in my head right now the name but on GAD deployment is a reference.
« Reply #2 on: September 14, 2013, 06:43:41 AM »
Cav is right, I think that the option/business attribute has name "Email Address" or something like that
Offline catanirex
« Reply #3 on: September 30, 2013, 07:55:47 AM »
You can also create a dummy pop-client with the no-reply address and set it to not enabled.
Just be sure you use an unique username even if its not gonna be used.
I have used that appproach several times.
