" /> Genesys SIP server integration with verint recorder - Genesys CTI User Forum
Author Topic: Genesys SIP server integration with verint recorder  (Read 5864 times)
Offline gen_den
« on: November 19, 2013, 03:58:31 AM »
Hi Experts,
I am new to genesys and just figuring out, how to integrate the Genesys SIP server with Verint recording solution.
Can you please help me with some configuration steps or document which have detailed method?
which parameter i need to configure on SIP server side to make recording to happen on verint ?
Appreciate the response.
Ankush
Offline bublepaw
Re: Genesys SIP server integration with verint recorder
« Reply #1 on: November 19, 2013, 05:43:51 PM »
If this is passive recording there is no special configuration. If this is active or by Verint standard (DMS) type of recording good place to start is Genesys documentation http://docs.genesyslab.com/Documentation/GQM/latest/Solution/Welcome
Offline gen_den
« Reply #2 on: November 20, 2013, 02:18:36 AM »
hi ,
This is a passive recording only, where Verint recorder expecting a Span packets.
Can you please let me know anything i need to configure in CME, SIP server etc?
How i will make my Genesys server to know if it's connected to Verint and it has to send the Events to Verint to Start the recording?
Ankush
« Reply #3 on: November 20, 2013, 09:53:39 AM »
You mean SPAN port of course,so this is thing apart from Genesys solution and it is related to the network switch configuration.As Bublepaw wrote, on Genesys site is no special configuration for passive recording. May be just application dummy object for allowing Verint to connect to the Genesys. Verint is a client of T-Server (SIP) and has to connect to the SIP server and register for receiving requested events. From my point of view, you unfortunately does not know Genesys (may be Verint) clearly and mix things together.
Offline gen_den
« Reply #4 on: November 25, 2013, 06:08:48 AM »
Hi Kubig,
Thank you for your reply.
You are correct, i am very much new to Genesys hence might not be aware of the configurations.
But below make things clear.
really appreciate your help.
Ankush
