" /> Missing Views/Objects/Extended Status Tabs from CCPulse 8.0.1 - Genesys CTI User Forum
Author Topic: Missing Views/Objects/Extended Status Tabs from CCPulse 8.0.1  (Read 4751 times)
Offline kateemail
« on: February 24, 2015, 10:28:04 PM »
my team is utilizing 8.0.1 right now, and we have this issue that keeps popping up.  Members when undocking can find that the options just disappear.  When i look at their CCPulse, I have tried the key command and selecting 'view/object/etc.' from the view menu and still nothing appears.
We have encountered a similar issue in previous versions and have only found that re-installing has corrected this, but I'm thinking there has to be a better way.  I've tried modifying their screen options in general to ensure everything is appearing correctly and it's not being cut off at all, no dice.  I tried looking at the config files for the users and found a bunch of discrepancies, so there was no real alignment to try as far as set up that i could see.
Has any one else found this issue?
Thanks!
Adam G
Re: Missing Views/Objects/Extended Status Tabs from CCPulse 8.0.1
« Reply #1 on: February 25, 2015, 11:53:49 AM »
Q: What do you mean "undocking"?
You might want to check your Persons/Agents Roles/Permissions within CME/CIM/GA, specifically for CCP+.  Just to make sure whoever is logged in has the necessary Access levels to see, make and do the actions you've described... but that's a pretty basic check.
« Reply #2 on: February 25, 2015, 02:09:24 PM »
Try to upgrade to last version and enable CCPulse logs.
Also post a screenshot of your issue to understand better
Offline kateemail
« Reply #3 on: February 25, 2015, 03:43:10 PM »
the users previously had the options of objects, view, and extended status in the bar on the left, so shouldn't be a permissions issue.  i've attached a link to screen shot that shows what I mean by docking....essentially the floating views bar in teh screen shot is now just gone for the users....it's like they have floated it away and it can't be retrieved...
[img width=640 height=398]http://i.imgur.com/fBXT8Lr.png[/img]
« Reply #4 on: February 25, 2015, 04:15:16 PM »
What Is View menu selected? Press F7 F8 and F9
