" /> Installation of Gplus adapter for SAP ERP - Genesys CTI User Forum
Author Topic: Installation of Gplus adapter for SAP ERP  (Read 2421 times)
Offline adarsh agrawal
« on: May 22, 2015, 12:12:55 PM »
HI,
Have installed the Gplus for SAP ERP version 7.5 (IP_GplusAforSAPR3_7500018b1_ENU_windows) but when trying to start the application its giving the below error message
Error message: Application popup: sapr3adapter.exe - System Error : The program can't start because LIBRFC32.dll is missing from your computer. Try reinstalling the program to fix this problem.
Though LIBRFC32u.dll exist under C:\Windows\SYSWow64 and have copied the same file on GCTI installation folder too.
Please let us know what could be the missing step or suggested action.
Re: Installation of Gplus adapter for SAP ERP
« Reply #1 on: May 22, 2015, 12:22:41 PM »
As it is a 32bit software on a 64bit you need the 32bit library on System32 folder
« Reply #2 on: May 22, 2015, 12:23:28 PM »
Also, I don't think 7.5 has support for 64bit platforms. Remember you will be out of support even from us.
« Reply #3 on: May 26, 2015, 06:23:03 AM »
Thanks. I have moved the file (librfc32u.dll) under the path (C:\Windows\System32) but still receiving the same error message.
If its going to be out of date so is there any latest version available that would be supported on 64 bit operating system? The last version of available GPlus for SAP ERP available on the support site is 7.5 only.
« Reply #4 on: May 26, 2015, 12:15:31 PM »
No, there will not. Integrations are being migrated to a IWS plug-in based one. So all integration happens on IWS rather than on a server. This happened already with MS Dynamics.
Ask Genesys what are plans for SAP and when.
Easier would be to ask a 32bit os like Windows 2008 32.
