" /> Interaction Workspace - enabling channels - Genesys CTI User Forum
Author Topic: Interaction Workspace - enabling channels  (Read 13316 times)
Offline JestTakiWiatr
« on: July 17, 2015, 12:18:25 PM »
how do you enable particular channel on the interaction workspace? Is it Interaction Workspace options or agent roles? Or maybe something different.
thanks
Re: Interaction Workspace - enabling channels
« Reply #1 on: July 17, 2015, 12:29:00 PM »
On the Roles you select what the agent assigned to that Role can do.
On IWS you just define how that channel will behave wiith its rules.
« Reply #2 on: July 17, 2015, 12:39:13 PM »
Thanks for such a quick reply.
Currently, no channels are availalbe for my agent (IWS starts with an empty channels list).
I've created a role with all 'Interaction Workspace Voice Priviliges' and assigned it to my user.
I don't quite understand 'On IWS you just define how that channel will behave wiith its rules.'. Can you explain?
thank you
« Reply #3 on: July 17, 2015, 12:47:05 PM »
Empty channel list? What you mean? You want your agent to select each channel individually?
In IWS you configure for example, for Emails which queue will be used as default queue, which for Outbound queue, which Business Data will use to toast on agent screen, etc.
Enviado de meu C6602 usando Tapatalk
« Reply #4 on: July 17, 2015, 12:47:50 PM »
I mean there are no channel available. I'd like to have voice channel.
« Reply #5 on: July 17, 2015, 12:48:08 PM »
The role based access is used just with disabled option "security.disable-rbac" (ie with value "false"). With this settings the permission for particular performs/actions within IWS is controled by this configuration. What channel should be available depends on configuration of IWS objects (IWS connections, etc.) and of course of the used place. Try to check your configuration together with logs of IWS on DEBUG level
« Reply #6 on: July 20, 2015, 07:46:08 AM »
This is what I found in the logs:
15-07-20 09:44:30.572 [            1] DEBUG andardResponseModule - StandardResponseModule()
15-07-20 09:44:30.577 [            1] INFO  dows.LoginController - Module StandardResponseModule initialized in 0.032 seconds
15-07-20 09:44:30.584 [            1] DEBUG InteractionWorkspace - CreateChildLogger InteractionWorkspace.Voice.EvaluateVoiceParty
15-07-20 09:44:30.585 [            1] DEBUG InteractionWorkspace - CreateChildLogger InteractionWorkspace.Voice.MediaVoiceExtension
15-07-20 09:44:30.587 [            1] DEBUG InteractionWorkspace - CreateChildLogger InteractionWorkspace.OpenMedia.MediaOpenMediaExtension
15-07-20 09:44:30.588 [            1] DEBUG InteractionWorkspace - CreateChildLogger InteractionWorkspace.OpenMedia.MediaBundleOpenMediaExtension
15-07-20 09:44:30.590 15-07-20 09:44:31.204 [            1] ERROR Workspace.Core.Agent - Not Found Possible Media
15-07-20 09:44:31.328 [            1] ERROR Workspace.Core.Agent - No Initialized media on the place.
« Reply #7 on: July 20, 2015, 08:13:35 AM »
Have your IWS object connection to the required "servers"? Is your place configured properly (linked to the physical DN, etc.)?
« Reply #8 on: July 20, 2015, 09:21:05 AM »
IWS does have a connection to T-Server. My place does a have configured DN.
« Reply #9 on: July 20, 2015, 09:23:34 AM »
Try to check permissions of your person and the options within IWS object related to the voice.* part.
« Reply #10 on: July 20, 2015, 09:29:52 AM »
Environment \ Administrators - Access Group - Full Control
Environment \ SYSTEM - Access Group - Special Access(XR)
Environment \ Super Administrators - Access Group - Full Control
Environment \ Users - Access Group - Special Access(XR)
Environment \ default - User - Full Control
interaction-workspace/active-recording.voice.recording-type
NETANN
interaction-workspace/interaction-workspace/contact.lookup.voice.enable
true
interaction-workspace/intercommunication.voice.routing-points
2222@SIP_Switch
interaction-workspace/login.voice.available-queues
2272
interaction-workspace/login.voice.can-unactivate-channel
true
interaction-workspace/login.voice.is-auto-ready
false
interaction-workspace/login.voice.prompt-dn-less-phone-number
true
interaction-workspace/voice.auto-answer
voice.auto-answer
false
interaction-workspace/voice.enable
voice.enable
true
interaction-workspace/voice.ringing-bell
voice.ringing-bell
Sounds\Ring.mp3|10|-1
interaction-workspace/workbin.vmail.VoiceMailWorkbin
LastAgentAndVoiceMail.voicemail.VMailWorkbin
interaction-workspace/workbin.vmail.VoiceMailWorkbin.displayed-columns
Subject,Received
« Reply #11 on: July 20, 2015, 09:38:40 AM »
Just for the test try to use person with "Super administrator" privileges. In other hand, check your IWS version (strongly recommend to use the latest version from the current release). If it will not work with the latest version, it points to the some mis-configuration or type in settings.
« Reply #12 on: July 20, 2015, 09:46:20 AM »
Adding super administrator privileges did not help.
Interaction Workspace versions is 8.1.401.50, all other applications are also 8.1.x, so I wouldn't suspect any version mismatch.
« Reply #13 on: July 20, 2015, 09:48:22 AM »
So, all pointed to the some misconfiguration as a root-cause. Try to follow entire doc describing the deployment process again.
« Reply #14 on: July 20, 2015, 09:52:34 AM »
Thanks for your effort Kubig. Can you drop me link me to the document?
