" /> Stream Manager VOIP Service DN is OOS - Genesys CTI User Forum
Author Topic: Stream Manager VOIP Service DN is OOS  (Read 3655 times)
Offline ajayku14
« on: July 29, 2015, 03:31:32 AM »
Hi All,
We are planning to migrate from 2003 windows servers to 2008 servers.We have stream managers(7.6 Version) installed on the 2003 servers. I installed the SM in 2008 server but in the sip logs I am able to see Still out of Service message is showing for VOIP service DN.
In 2003 server configuration the SM are working fine. For 2003 host two IP's(175.x.y.z,175.x.y.y) are configured one  Ip(175.x.y.z) which we can able to login through MSTSC. In the application of SM under the contact section the RTP address is mentioned as other IP(175.x.y.y) of 2003 host.But for 2008 server only one IP address is configured when I put the same IP address(175.x.y.y) of 2003 host initially the RTP error came and SM was not started, so I changed the IP address of 2008 then RTP error is resolved and application is started but in the SIP logs STILL out of server message is coming for the VOIP(treatement,application) service DN.
We have SIP server in redundancy, for the sip servers also we two IP address(175.z.z.z,175.y.y.y) are configured one IP(175.y.y.y) is using for the SIP address under Tserver Section. For both primary and backup the same IP(175.y.y.y) address we are using for redundancy. When I pinged from 2008 host to SIP address(175.y.y.y) RTO is coming. When I check the same ping request from the 2003 host, reply is coming for the SIP address(175.y.y.y).
I checked in the sip logs when the SM installed in the 2003 host first the OPTIONS messages is going to that particular 2003 host(175.x.y.y) from SIP server and then 200 OK acknowledgement is coming from 2003 host(175.x.y.y). But when I check the same when I installed the SM in 2008 host, only OPTIONS messages is going to 2008 host from SIP server but 200 OK Message is not coming from 2008 host in the SIP server logs and the message is going in frequency of interval after two secs,four secs and then finally STILL our of SERVICE message is showing in logs.
Can anyone confirm me, VOIP service DN is going OOS because of from 2008 host not able to ping to the SIP address.
Ajay
Re: Stream Manager VOIP Service DN is OOS
« Reply #1 on: July 29, 2015, 03:57:21 AM »
Like magic balls doesn't work since 1700 so so...now we use logs. So post a few and mark your DN
Enviado de meu C6602 usando Tapatalk
Offline seiha
« Reply #2 on: July 29, 2015, 07:46:57 AM »
I agree with the post. ;D ;D ;D ;D ;D ;D
[color=#F5F5F5]คาสิโนออนไลน์ ในรูปแบบใหม่ล่าสุดจาก ปอยเปต คาสิโน รีสอร์ท ได้ที่นี่[/color] [url=https://www.royal-1688.net][color=#F5F5F5]royal1688[/color][/url]
Offline ajayku14
« Reply #3 on: July 29, 2015, 05:25:54 PM »
HI,
Thanks for the quick response. I will post the logs tomorrow as I don't have access now.
Could you please confirm, from Stream Manager host the SIP address should be ping-able or not.
Below mentioned  are the scenario's for ping results from Stream Manager host to the SIP server address, when the application is in 2003 host as well as 2008 host.
1) When ever the reply is coming from the SIP server to Stream Manager host(This scenario in 2003 Host) no OOS error messages for treatment VOIP DN. 2) But when ever RTO is coming from the sip server to the Stream Manager(This scenario is in 2008 Host) OOS error messages are coming in the SIP server logs for treatment VOIP DN.
Ajay
Offline genesysbasha
« Reply #4 on: July 30, 2015, 12:24:56 PM »
Please cross check that windows firewall enabled on your windows 2008 Host..
« Last Edit: July 30, 2015, 12:27:41 PM by genesysbasha »
