" /> Problem when installing Knowledge Manager - Genesys CTI User Forum
Author Topic: Problem when installing Knowledge Manager  (Read 2662 times)
Offline Gohan
« on: September 14, 2015, 03:04:47 PM »
Hi all,
i am trying to install Knowledge Manager, when i do i get the following error:
Supported Sun's JRE version (higher than 1.6.1_26 and less than 1.7.0) was not found.The installation will continuewithout binding to java
Attached the screenshot.
The version of KM is 8.5.
I have jre 1.6 and 1.7 already installed, i have set the JAVA_HOME variable to jre 1.6 but i still have the problem.
Any idea please.
Thank you.
Offline raza990
Re: Problem when installing Knowledge Manager
« Reply #1 on: September 15, 2015, 07:34:53 AM »
Have you put JAVA path in KnowledgeManager.bat, under installation directory ?
Offline Gohan
« Reply #2 on: September 15, 2015, 07:41:11 AM »
Thank you for the answer.
no, i aborted the installation when i got the error message.
Should i continue and put the java path in the .bat file?
Offline Gohan
« Reply #3 on: September 15, 2015, 07:48:59 AM »
it works now.
i continued the installation and i put the java path as you indicated.
Thank you very much.
Offline raza990
« Reply #4 on: September 16, 2015, 07:15:35 AM »
[quote author=Gohan link=topic=9102.msg40824#msg40824 date=1442303339]
it works now.
Great  :)
