" /> Stat server stopped need help - Genesys CTI User Forum
Author Topic: Stat server stopped need help  (Read 2115 times)
Offline Hara hara mahadev
« on: January 16, 2016, 02:59:19 PM »
Stat server has stopped for 3 hrs during business hours. Will I loose the reporting data for that stopped time. If no from where can I get it back.
Adam G
Re: Stat server stopped need help
« Reply #1 on: January 16, 2016, 08:08:41 PM »
Depends what Solution and which components your StatServer was serving;
[b]CCA[/b] - probably yes, you have lost the data for the period, [i]if [/i]the StatServer which had stopped was supposed to be collecting your reporting data for CCA.  How to get it back?  Mark this one down to experience... it's gone.
[b]InfoMart[/b] - no, because ICON collects reporting data.
Offline genesysnoob
« Reply #2 on: January 23, 2016, 09:15:10 PM »
is't your app on auto restart after certain time?
