" /> [SOLVED] Searching for a method to dinamically add/remove agents from vq target - Genesys CTI User Forum
Author Topic: [SOLVED] Searching for a method to dinamically add/remove agents from vq target  (Read 9266 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi everyone, hope all fine out there; I'm studying a method to dinamically change the agents the selectdn can choose from, when building the target.
I was thinking about something related to skills, where a certain skill inside a certain group of agents can be selected, instead of others. So, the idea is SelectDN[VQ,GroA,GroA1,GroAx] where skill in (Skill1,Skill2,Skillx).
Could it be done?
Best regards,
Gef.
« Last Edit: July 04, 2016, 07:31:29 AM by Gef Buneri »
You do have very weird requests my friend. ;)
Offline Gef Buneri
Of course, Cav; easy things aren't for me :D
The goal is to dinamically remove from target, agents who are near workshift's end, so they're cannot be selected as target an amount of time before the end of the workshift.
And why the VQ?
VQ is a stat parameter only.
I do remember a post about dynamic target creation using ExpandGroup I think. But there was a solution already
Offline terry
Do you mean something like that:
x= CreateSkillGroup['', GroA, 'Skill1>0 & Skill2>0 & SkillX>0']
y= CreateSkillGroup['', Gro1, 'Skill1>0 & Skill2>0 & SkillX>0']
z= CreateSkillGroup['', GroAx, 'Skill1>0 & Skill2>0 & SkillX>0']
SelectDN[VQ,x,y,z]
Offline Dionysis
You know you can route based on the actual schedule right?  So you can deliver interactions based on the activity that's scheduled rather than skills etc.
[quote author=terry link=topic=9672.msg43777#msg43777 date=1466531936]
SelectDN[VQ,x,y,z]
That one Terry :D
Offline Gef Buneri
Yes Terry, that's it. So fine 'til the CreateSkillGroup function, then I should put the result in a var and use the var as a .GA value in the SelectDN; got it right? Ok, it should work fine... now the last step: how to assign skill to agent, from ird, using a var?
Thanks Dionysis, I know, but here the point is to dinamically change skill basing on a pre-assigned value that represents the agent's workshift. So, basing on a table containing the cross reference between agent id and his workshift, the scheduling have to change dinamically and agents belonging to the same group should become selectable or not, as targets, from time to time. The trick is that agents belong to the same agent group, so I can't no longer use the whole group as the single target, but I must partialize what the group contains.
« Last Edit: June 22, 2016, 08:57:21 AM by Gef Buneri »
You don't assign a skill to an agent, skills are queries. You search for agents who meet a criteria. Why would you want to assign a skill? You already know who they are...
Why not better create skills with the values being their work hours?
Offline Gef Buneri
Sure Cav, this point is quite clear to me, but it will not satisfy the needing, the way I think it; 'cause the goal is to remove agents from targeting a bit earlier than the workshift end hour, just to know the duration of the workshift isn't enough. My idea is to create a table with the skill association in where I'll assign a skill to mark them as selectable/not selectable basing on a schedule, to make the agent not selectable 10 minutes before his workshift's end.
To make the long short, I would like to be sure the system does no longer select the agent even if he is in ready state, to avoid the routing of calls on that agent, if he is near the workshift's end. I can't apply a schedule to the whole group.
It can be done as you're suggesting, creating some logic like "during this interval, don't select these skills", where the skill represents the workshift, but workshifts change frequently in the week, for the same agent.
« Last Edit: June 22, 2016, 01:15:41 PM by Gef Buneri »
Offline Tambo
do it via total logged in time , but that will work if they all on same shift length
Offline Gef Buneri
I'm pointing to a possible solution (not working at the moment). Trying to use a stored procedure to dinamically update CFG_SKILL_LEVEL table @config DB, but it seems changes done directly in the table are not considered by URS, letting the level set in skill level value inside the person proprerties in cme to be the significant value. I mean:
I create a skill in cme, assign that skill with a specific level through person properties in cme, so I have a record in config db indicating person dbid/skill/Skill level. I change the level value in the db's record, but nothing changes; CreateSkillGroup still selecting agent using CME skill value, instead of db's changed value.
Any clues?
Offline Tambo
use skill level from CME then in strategy use -5 etc so that skill level used for routing is 5 less than CME , that does work as i've used it before
Offline Gef Buneri
Hi Tambo, thank you for the reply. Got the logic, but can't figure out how to use it. I mean, the goal is to make urs to createskillgroup using the skill level on db instead of the one in cme.
Following your logic I should use an expression like "skillname = (x - y)" where x is the CME value and (x - y) is the config db value?
Offline Tambo
no no need for DB skill level, use current skill level then assign new skill level in the strategy
