" /> UCS does not want to start - Genesys CTI User Forum
Author Topic: UCS does not want to start  (Read 52096 times)
Offline brendanb
« on: July 22, 2016, 11:04:31 AM »
Hi
Hope I can get some assistance here with UCS that does not want to start
I have done a new installation of Genesys 8.5. The SQL is installed on the same server
When UCS starts it stops with the following error message
2016-07-22T11:47:51.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
2016-07-22T11:47:51.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
2016-07-22T11:47:51.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
2016-07-22T11:47:51.207 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Callback
2016-07-22T11:47:51.217 Std 29997 [Ucs-Main] Abnormal server exit, code:-1
When starting the application from the command line  the following error is seen before the applications stops
[err] Application init failed: null
java.lang.NullPointerException
        at com.genesyslab.icc.util.Server.getRunMode(Server.java:299)
        at com.genesyslab.icc.util.Server.isPrimary(Server.java:308)
        at com.genesyslab.icc.contactserver.maintenance.StartupOperations.initi
lizeDB(StartupOperations.java:100)
        at com.genesyslab.icc.contactserver.ContactServerEngine.initInstance(Co
tactServerEngine.java:576)
        at com.genesyslab.icc.contactserver.ContactServerEngine$4.run(ContactSe
verEngine.java:1395)
        at java.lang.Thread.run(Thread.java:745)
12:59:56.803 Std 29997 [Ucs-Main] Abnormal server exit, code:-1
The following has been checked
Configuration of the UCS dap
Dap is setup as a JDBC dap
Set to be main dap
Connecting on port 1433
On SQL logging in with the sa account that has full access rights on the DB
To make sure all access rights has been ticked for both config db and ucs db
It appears that the UCS can not access the database but the question is witch (config or ucs)
All settings has been checked and double checked by multiple engineers and appear to be correct
UCS version is 8.5.200.09
Re: UCS does not want to start
« Reply #1 on: July 22, 2016, 11:55:16 AM »
Try to configure UCS to start under any account with SuperAdministrator permission - like default :)
Offline brendanb
« Reply #2 on: July 22, 2016, 12:51:57 PM »
Hi
Forgot to add that part.
The UCS is configured to start with default account and not system.
I also created another account and assigned the super administrators users group then added the account to the tenant and granted full access rights.
However this did not resolve the problem as well
« Last Edit: July 22, 2016, 12:55:30 PM by brendanb »
« Reply #3 on: July 22, 2016, 01:11:52 PM »
Try to post whole log since startup up to unexpected termination
Offline hsujdik
« Reply #4 on: July 22, 2016, 01:46:02 PM »
Also, check the OS permissions for the OS user that is running LCA on this host. From this call stack, it was probably trying to communicate with LCA when the Exception happened.
Offline brendanb
« Reply #5 on: July 25, 2016, 10:40:04 AM »
UCS log below.
10:43:57: Current working folder:c:\GCTI\universalcontactserver
10:43:57: File type <log> name=c:\GCTI\universalcontactserver\ContactServerDriver_20160725_104357_972.log
10:43:57: File type <ini> name=c:\GCTI\universalcontactserver\ContactServerDriver.ini
10:43:57: Trying to initialize application logger...
10:43:57: Try to create log file:c:\GCTI\universalcontactserver\ContactServerDriver_20160725_104357_972.log
10:43:57: Starting logging to file ...
10:43:57: Current working folder=c:\GCTI\universalcontactserver
10:43:57: Starting application Java Server Starter. Version 8.4.000.01
10:43:57: Copyright (c) 2000-2014 Genesys Telecommunications Laboratories Inc.
10:43:57: Current date is 2016-07-25
10:43:57: Now will try to read the file c:\GCTI\universalcontactserver\ContactServerDriver.ini
10:43:57: Reading options from section [Service]
10:43:57: AppTitle=Genesys Universal Contact Server
10:43:57: AppVersion=8.5.200.09
10:43:57: JVMPath=C:\Java\jdk1.7.0_79\jre\bin\server\jvm.dll
10:43:57: MainClass=com/genesyslab/icc/contactserver/ContactServerEngine
10:43:57: StopMethod=shutdownServer
10:43:57: Reading args from section [JavaArgs]:
10:43:57: -server
10:43:57: -Xmx2048M
10:43:57: -Xbootclasspath/p:./lib/acsc.jar
10:43:57: -Djava.rmi.dgc.leaseValue=60000
10:43:57: -Djava.library.path=C:\Java\jdk1.7.0_79/lib
10:43:57: -Dtkv.multibytes=true
10:43:57: -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade
10:43:57: -Dorg.quartz.scheduler.skipUpdateCheck=true
10:43:57: -Dpsdk.config.tls=false
10:43:57: -Dcom.genesyslab.platform.commons.connection.factory.class=com.genesyslab.platform.commons.connection.impl.netty.NettyConnectionFactory
10:43:57: -XX:+UseConcMarkSweepGC
10:43:57: -XX:+UseParNewGC
10:43:57: -XX:+ExplicitGCInvokesConcurrent
10:43:57: Arg <-Djava.class.path> does NOT exists - will read section [Djava.class.path]:
10:43:57: ./lib/cal.jar
10:43:57: ./lib/ucsapi.jar
10:43:57: ./lib/ucs.jar
10:43:57: ./lib/iccutils.jar
10:43:57: ./lib/genesyslib/commonLib.jar
10:43:57: ./lib/genesyslib/dsw_api_java.jar
10:43:57: ./lib/genesyslib/kvlists.jar
10:43:57: ./lib/genesyslib/StatLib.jar
10:43:57: ./lib/genesys/statserver.jar
10:43:57: ./lib/antlr/antlr.jar
10:43:57: ./lib/javamail/mail.jar
10:43:57: ./lib/idn/libidn.jar
10:43:57: ./lib/lucene/lucene-core.jar
10:43:57: ./lib/lucene/lucene-analyzers.jar
10:43:57: ./lib/lucene/lucene-queryparser.jar
10:43:57: ./lib/lucene/lucene-queries.jar
10:43:57: ./lib/psdk/apptemplate.jar
10:43:57: ./lib/psdk/comappblock.jar
10:43:57: ./lib/psdk/commons.jar
10:43:57: ./lib/psdk/logging.jar
10:43:57: ./lib/psdk/configurationprotocol.jar
10:43:57: ./lib/psdk/connection.jar
10:43:57: ./lib/psdk/kvlistbinding.jar
10:43:57: ./lib/psdk/kvlists.jar
10:43:57: ./lib/psdk/managementprotocol.jar
10:43:57: ./lib/psdk/messagebrokerappblock.jar
10:43:57: ./lib/psdk/protocol.jar
10:43:57: ./lib/psdk/system.jar
10:43:57: ./lib/psdk/openmediaprotocol.jar
10:43:57: ./lib/psdk/protocolmanagerappblock.jar
10:43:57: ./lib/psdk/warmstandbyappblock.jar
10:43:57: ./lib/psdk/netty.jar
10:43:57: ./lib/quartz/quartz.jar
10:43:57: ./lib/db/pool/bonecp.jar
10:43:57: ./lib/db/pool/guava.jar
10:43:57: ./lib/db/oracle/ons.jar
10:43:57: ./lib/db/oracle/ucp.jar
10:43:57: ./lib/db/oracle/ojdbc6.jar
10:43:57: ./lib/db/microsoft/sqljdbc4.jar
10:43:57: ./lib/db/ibm/db2jcc4.jar
10:43:57: ./lib/db/postgresql/postgresql.jar
10:43:57: ./lib/log/log4j.jar
10:43:57: ./lib/log/slf4j-api.jar
10:43:57: ./lib/log/slf4j-log4j12.jar
10:43:57: ./lib/metrics/metrics-core.jar
10:43:57: ./lib/metrics/metrics-healthchecks.jar
10:43:57: ./lib/metrics/metrics-jvm.jar
10:43:57: ./lib/metrics/metrics-log4j.jar
10:43:57: ./lib/metrics/metrics-servlet.jar
10:43:57: ./lib/metrics/metrics-servlets.jar
10:43:57: ./lib/metrics/metrics-ganglia.jar
10:43:57: ./lib/metrics/gmetric4j.jar
10:43:57: ./lib/remotetea/classes/jrpcgen.jar
10:43:57: ./lib/remotetea/classes/oncrpc.jar
10:43:57: ./lib/remotetea/classes/portmap.jar
10:43:57: ./lib/spring/org.springframework.beans.jar
10:43:57: ./lib/spring/org.springframework.context.jar
10:43:57: ./lib/spring/org.springframework.core.jar
10:43:57: ./lib/spring/org.springframework.expression.jar
10:43:57: ./lib/spring/org.springframework.jdbc.jar
10:43:57: ./lib/spring/org.springframework.transaction.jar
10:43:57: ./lib/spring/org.springframework.aop.jar
10:43:57: ./lib/restlet/org.restlet.jar
10:43:57: ./lib/restlet/org.restlet.ext.json.jar
10:43:57: ./lib/restlet/org.restlet.ext.xml.jar
10:43:57: ./lib/restlet/org.restlet.ext.jetty.jar
10:43:57: ./lib/restlet/org.restlet.ext.slf4j.jar
10:43:57: ./lib/restlet/org.restlet.ext.ssl.jar
10:43:57: ./lib/restlet/org.restlet.ext.fileupload.jar
10:43:57: ./lib/restlet/org.restlet.ext.net.jar
10:43:57: ./lib/apache/commons-collections.jar
10:43:57: ./lib/apache/commons-logging.jar
10:43:57: ./lib/apache/commons-fileupload.jar
10:43:57: ./lib/apache/commons-pool.jar
10:43:57: ./lib/servlet/javax.servlet.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.ajp.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.continuations.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.http.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.io.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.server.jar
10:43:57: ./lib/servlet/org.eclipse.jetty.util.jar
10:43:57: ./lib/aop/aopalliance.jar
10:43:57: ./lib/aop/aspectj.weaver.jar
10:43:57: ./lib/aop/aspectjrt.jar
10:43:57: ./lib/processing/xml/xstream.jar
10:43:57: ./lib/processing/json/json.jar
10:43:57: ./lib/processing/csv/opencsv.jar
10:43:57: ./lib/processing/html/jericho-html.jar
10:43:57: Adding -Djava.class.path=-Djava.class.path=;./lib/cal.jar;./lib/ucsapi.jar;./lib/ucs.jar;./lib/iccutils.jar;./lib/genesyslib/commonLib.jar;./lib/genesyslib/dsw_api_java.jar;./lib/genesyslib/kvlists.jar;./lib/genesyslib/StatLib.jar;./lib/genesys/statserver.jar;./lib/antlr/antlr.jar;./lib/javamail/mail.jar;./lib/idn/libidn.jar;./lib/lucene/lucene-core.jar;./lib/lucene/lucene-analyzers.jar;./lib/lucene/lucene-queryparser.jar;./lib/lucene/lucene-queries.jar;./lib/psdk/apptemplate.jar;./lib/psdk/comappblock.jar;./lib/psdk/commons.jar;./lib/psdk/logging.jar;./lib/psdk/configurationprotocol.jar;./lib/psdk/connection.jar;./lib/psdk/kvlistbinding.jar;./lib/psdk/kvlists.jar;./lib/psdk/managementprotocol.jar;./lib/psdk/messagebrokerappblock.jar;./lib/psdk/protocol.jar;./lib/psdk/system.jar;./lib/psdk/openmediaprotocol.jar;./lib/psdk/protocolmanagerappblock.jar;./lib/psdk/warmstandbyappblock.jar;./lib/psdk/netty.jar;./lib/quartz/quartz.jar;./lib/db/pool/bonecp.jar;./lib/db/pool/guava.jar;./lib/db/oracle/ons.jar;./lib/db/oracle/ucp.jar;./lib/db/oracle/ojdbc6.jar;./lib/db/microsoft/sqljdbc4.jar;./lib/db/ibm/db2jcc4.jar;./lib/db/postgresql/postgresql.jar;./lib/log/log4j.jar;./lib/log/slf4j-api.jar;./lib/log/slf4j-log4j12.jar;./lib/metrics/metrics-core.jar;./lib/metrics/metrics-healthchecks.jar;./lib/metrics/metrics-jvm.jar;./lib/metrics/metrics-log4j.jar;./lib/metrics/metrics-servlet.jar;./lib/metrics/metrics-servlets.jar;./lib/metrics/metrics-ganglia.jar;./lib/metrics/gmetric4j.jar;./lib/remotetea/classes/jrpcgen.jar;./lib/remotetea/classes/oncrpc.jar;./lib/remotetea/classes/portmap.jar;./lib/spring/org.springframework.beans.jar;./lib/spring/org.springframework.context.jar;./lib/spring/org.springframework.core.jar;./lib/spring/org.springframework.expression.jar;./lib/spring/org.springframework.jdbc.jar;./lib/spring/org.springframework.transaction.jar;./lib/spring/org.springframework.aop.jar;./lib/restlet/org.restlet.jar;./lib/restlet/org.restlet.ext.json.jar;./lib/restlet/org.restlet.ext.xml.jar;./lib/restlet/org.restlet.ext.jetty.jar;./lib/restlet/org.restlet.ext.slf4j.jar;./lib/restlet/org.restlet.ext.ssl.jar;./lib/restlet/org.restlet.ext.fileupload.jar;./lib/restlet/org.restlet.ext.net.jar;./lib/apache/commons-collections.jar;./lib/apache/commons-logging.jar;./lib/apache/commons-fileupload.jar;./lib/apache/commons-pool.jar;./lib/servlet/javax.servlet.jar;10:43:58.360 Trc 29998 [Ucs-Main] java.net.preferIPv4Stack is set to false
10:43:58.361 Trc 29998 [Ucs-Main] java.net.preferIPv6Addresses is set to false
10:43:58.361 Trc 29998 [Ucs-Main] GCTI_CONN_IPV6_ON is not present, using IPv6 previous values
10:43:58.365 Trc 04500 Connecting to CONFIG_SERVER '' at host 'demosrv', port 2020
10:43:58.443 Trc 29998 [Ucs-Main] CfgServer con client-side port:null binding-host:null
10:43:59.225 Trc 29998 [Ucs-Main] Connected to Configuration Server on host demosrv:2020 version 8.5.100.18 timeout=60000ms Dbid=99 backupDbid=0
10:43:59.354 Trc 29998 [Ucs-Main] No connection to cfg server found, creating connection to 'confserv' with dbId:99
10:43:59.366 Dbg 29999 [Ucs-Main] Configuring 'CONFIG_SERVER' connection
10:43:59.366 Dbg 29999 [Ucs-Main] Primary Warm Standby server CONFIG_SERVER is confserv
10:43:59.366 Std 29997 [Ucs-Main] Invalid reconnect timeout value '0' overriding to 30s
10:43:59.371 Dbg 29999 [Ucs-Main] Backup Warm Standby server not found CONFIG_SERVER : working in single-server mode
10:43:59.373 Dbg 29999 [Ucs-Main] Connection configured for CONFIG_SERVER
10:43:59.376 Std 29997 [Ucs-Main] WarmStandbyService can't update Endpoint on channel com.genesyslab.platform.configuration.protocol.ConfServerProtocol@43f66516@{confserv - tcp://demosrv:2020}: com.genesyslab.platform.commons.protocol.ChannelNotClosedException: Operation is not allowed on non closed channel
10:43:59.377 Dbg 29999 [warmstandby] WarmStandby state of 'conn-universalcontactserver-confserv' is 'Idle'
10:43:59.377 Std 04503 Connected to CONFIG_SERVER 'confserv - tcp://demosrv:2020' at host 'demosrv', port 2020
10:43:59.378 Std 05200 Ucs-Main. Version Config Server Path  8.5.100.18
10:43:59.378 Dbg 29999 [Ucs-Main] application named 'universalcontactserver' not found in cache, querying config server
10:43:59.383 Dbg 29999 [Ucs-Main] List of Applications of type 'CONTACT_SERVER' not found in cache, querying config server
10:43:59.395 Dbg 29999 [Ucs-Main] Subscribed on event CFGAccessGroup in configuration for tenant '1'
10:43:59.396 Dbg 29999 [Ucs-Main] Subscribed on event CFGEnumerator in configuration for tenant '1'
10:43:59.396 Dbg 29999 [Ucs-Main] Subscribed on event CFGEnumeratorValue in configuration for tenant '1'
10:43:59.397 Dbg 29999 [Ucs-Main] Subscribed on event CFGFolder in configuration for tenant '1'
10:43:59.397 Dbg 29999 [Ucs-Main] Subscribed on event CFGPerson in configuration for tenant '1'
10:43:59.398 Dbg 29999 [Ucs-Main] Subscribed on event CFGRole in configuration for tenant '1'
10:43:59.398 Dbg 29999 [Ucs-Main] Subscribed on event CFGApplication(123) in configuration for tenant '1'
10:43:59.399 Dbg 29999 [Ucs-Main] Subscribed on event CFGTenant in configuration for tenant '1'
10:43:59.399 Dbg 29999 [Ucs-Main] Registered to cfg events
10:43:59.399 Dbg 29999 [Ucs-Main] Loading cache from cfg server, attempt '1'.
10:43:59.402 Dbg 29999 [Ucs-Main] <26> requesting CFGTenant
10:43:59.402 Dbg 29999 [cal.evt.ivk] <26> done reading CFGTenant
10:43:59.403 Dbg 29999 [Ucs-Main] cache 'Tenant' has been cleared
10:43:59.403 Dbg 29999 [Ucs-Main] cache storing 'Tenant' 0 instances
10:43:59.407 Dbg 29999 [Ucs-Main] cache 'Application' has been cleared
10:43:59.407 Dbg 29999 [Ucs-Main] cache storing 'Application' 1 instances
10:43:59.407 Dbg 29999 [Ucs-Main] <28> requesting CFGFolder
10:43:59.409 Dbg 29999 [cal.evt.ivk] <28> CFGFolder read:62 remaining:62
10:43:59.436 Dbg 29999 [cal.evt.ivk] <28> done reading CFGFolder
10:43:59.436 Dbg 29999 [Ucs-Main] cache 'Folder' has been cleared
10:43:59.436 Dbg 29999 [Ucs-Main] cache storing 'Folder' 62 instances
10:43:59.437 Dbg 29999 [Ucs-Main] cache 'Person' has been cleared
10:43:59.437 Dbg 29999 [Ucs-Main] <29> requesting CFGPerson from tenant '1'
10:43:59.438 Dbg 29999 [cal.evt.ivk] <29> CFGPerson read:2 remaining:2
10:43:59.439 Dbg 29999 [cal.evt.ivk] <29> done reading CFGPerson
10:43:59.440 Dbg 29999 [Ucs-Main] cache storing 'Person' 2 instances
10:43:59.440 Dbg 29999 [Ucs-Main] cache 'Enumerator' has been cleared
10:43:59.440 Dbg 29999 [Ucs-Main] <30> requesting CFGEnumerator from tenant '1'
10:43:59.441 Dbg 29999 [cal.evt.ivk] <30> CFGEnumerator read:23 remaining:23
10:43:59.445 Dbg 29999 [cal.evt.ivk] <30> done reading CFGEnumerator
10:43:59.445 Dbg 29999 [Ucs-Main] cache storing 'Enumerator' 23 instances
10:43:59.445 Dbg 29999 [Ucs-Main] cache 'EnumeratorValue' has been cleared
10:43:59.446 Dbg 29999 [Ucs-Main] <31> requesting CFGEnumeratorValue from tenant '1'
10:43:59.447 Dbg 29999 [cal.evt.ivk] <31> CFGEnumeratorValue read:73 remaining:73
10:43:59.457 Dbg 29999 [cal.evt.ivk] <31> done reading CFGEnumeratorValue
10:43:59.457 Dbg 29999 [Ucs-Main] cache storing 'EnumeratorValue' 73 instances
10:43:59.457 Dbg 29999 [Ucs-Main] cache 'rolesIdByUserByTenants' has been cleared
10:43:59.457 Dbg 29999 [Ucs-Main] cache 'Role' already empty
10:43:59.458 Dbg 29999 [Ucs-Main] <32> requesting CFGAccessGroup from tenant '1'
10:43:59.459 Dbg 29999 [cal.evt.ivk] <32> CFGAccessGroup read:5 remaining:5
10:43:59.460 Dbg 29999 [cal.evt.ivk] <32> done reading CFGAccessGroup
10:43:59.461 Dbg 29999 [Ucs-Main] cache storing 'Role' 5 instances
10:43:59.461 Dbg 29999 [Ucs-Main] Cache loaded
10:43:59.461 Dbg 29999 [Ucs-Main] host dbid='101' not found in cache, querying config server
10:43:59.503 Dbg 29999 [Ucs-Main] Configuring 'MESSAGE_SERVER' connection
10:43:59.504 Dbg 29999 [Ucs-Main] Primary Warm Standby server MESSAGE_SERVER is messageserver
10:43:59.505 Dbg 29999 [Ucs-Main] Backup Warm Standby server not found MESSAGE_SERVER : working in single-server mode
10:43:59.505 Dbg 29999 [Ucs-Main] Connection configured for MESSAGE_SERVER
10:43:59.513 Std 29997 [Ucs-Main] IPv6 is not enabled, ip-version value will be ignored
10:43:59.514 Dbg 29999 [.msg.ha.ivk] WarmStandby state of 'conn-universalcontactserver-messageserver' is 'Idle'
10:43:59.514 Std 05060 Application started
10:43:59.515 Std 05201 Copyright (c) 2003-2015 Genesys Telecommunications Laboratories, Inc.
10:43:59.515 Std 20002 [Ucs-Main] Running 'universalcontactserver' with Config Server running on host 'demosrv', port 2020
10:43:59.516 Std 05200 Configuration Access Layer. Version 8.5.200.09 Path  ./lib/cal.jar
10:43:59.516 Std 05200 Universal Contact Server API. Version 8.5.100.16 Path  ./lib/ucsapi.jar
10:43:59.517 Std 05200 Universal Contact Server. Version 8.5.200.09 Path  ./lib/ucs.jar
10:43:59.517 Std 05200 ICC Utils. Version 8.5.200.09 Path  ./lib/iccutils.jar
10:43:59.518 Std 05200 CommonLib package. Version 7.1.000.07 Path  ./lib/genesyslib/commonLib.jar
10:43:59.518 Std 05200    "Genesys MCR SSJE DSW API". Version "7.5.000.00" Path  ./lib/genesyslib/dsw_api_java.jar
10:43:59.519 Std 05200 kvlists package. Version 7.1.000.02 Path  ./lib/genesyslib/kvlists.jar
10:43:59.519 Std 05200 JavaStatLib. Version 7.0.100.07 Path  ./lib/genesyslib/StatLib.jar
10:43:59.520 Std 05200    "StatServer Java SDK Classes". Version "1.0" Path  ./lib/genesys/statserver.jar
10:43:59.521 Std 05200 antlr.jar. Version not available Path  ./lib/antlr/antlr.jar
10:43:59.531 Std 05200 JavaMail(TM) API Design Specification. Version 1.4 Path  ./lib/javamail/mail.jar
10:43:59.531 Std 05200 libidn.jar. Version not available Path  ./lib/idn/libidn.jar
10:43:59.532 Std 05200 Lucene Search Engine: core. Version 4.5.1 1533280 - mark - 2013-10-17 21:37:01 Path  ./lib/lucene/lucene-core.jar
10:43:59.533 Std 05200 Lucene Search Engine: analyzers-common. Version 4.5.1 1533280 - mark - 2013-10-17 21:37:21 Path  ./lib/lucene/lucene-analyzers.jar
10:43:59.533 Std 05200 Lucene Search Engine: queryparser. Version 4.5.1 1533280 - mark - 2013-10-17 21:37:35 Path  ./lib/lucene/lucene-queryparser.jar
10:43:59.533 Std 05200 Lucene Search Engine: queries. Version 4.5.1 1533280 - mark - 2013-10-17 21:37:35 Path  ./lib/lucene/lucene-queries.jar
10:43:59.534 Std 05200 Genesys Application Template AB. Version 8.1.400.04 Path  ./lib/psdk/apptemplate.jar
10:43:59.535 Std 05200 Genesys Configuration Object Model API AB. Version 8.1.400.04 Path  ./lib/psdk/comappblock.jar
10:43:59.535 Std 05200 CommonUtilsJava package. Version 8.1.400.04 Path  ./lib/psdk/commons.jar
10:43:59.535 Std 04503 Connected to CFGMessageServer 'conn-universalcontactserver-messageserver' at host 'demosrv', port 5150
10:43:59.536 Std 05200 Logging package. Version 8.1.400.04 Path  ./lib/psdk/logging.jar
10:43:59.536 Std 05200 ConfigurationProtocols package. Version 8.1.400.04 Path  ./lib/psdk/configurationprotocol.jar
10:43:59.537 Std 05200 CommonsProtocolsConnectionJava package. Version 8.1.400.04 Path  ./lib/psdk/connection.jar
10:43:59.537 Std 05200 keyvaluebinding package. Version 8.1.400.04 Path  ./lib/psdk/kvlistbinding.jar
10:43:59.538 Std 05200 kvlists package. Version 8.1.400.04 Path  ./lib/psdk/kvlists.jar
10:43:59.538 Std 05200 ManagementProtocols package. Version 8.1.400.04 Path  ./lib/psdk/managementprotocol.jar
10:43:59.539 Std 05200 Message Broker Application Block package. Version 8.1.400.04 Path  ./lib/psdk/messagebrokerappblock.jar
10:43:59.539 Std 05200 CommonsJava package. Version 8.1.400.04 Path  ./lib/psdk/protocol.jar
10:43:59.541 Std 05200 SystemJava package. Version 8.1.400.04 Path  ./lib/psdk/system.jar
10:43:59.541 Std 05200 Open Media Platform SDK for Java package. Version 8.1.400.04 Path  ./lib/psdk/openmediaprotocol.jar
10:43:59.542 Std 05200 Protocol Manager Application Block package. Version 8.1.400.04 Path  ./lib/psdk/protocolmanagerappblock.jar
10:43:59.542 Std 05200 Warm Standby Application Block package. Version 8.1.400.04 Path  ./lib/psdk/warmstandbyappblock.jar
10:43:59.543 Std 05200 netty.jar. Version not available Path  ./lib/psdk/netty.jar
10:43:59.543 Std 05200 quartz.jar. Version not available Path  ./lib/quartz/quartz.jar
10:43:59.544 Std 05200 bonecp.jar. Version not available Path  ./lib/db/pool/bonecp.jar
10:43:59.544 Std 05200 guava.jar. Version not available Path  ./lib/db/pool/guava.jar
10:43:59.545 Std 05200 ons.jar. Version not available Path  ./lib/db/oracle/ons.jar
10:43:59.545 Std 21297 [Ucs-Main] unable to read jar file './lib/db/oracle/ucp.jar' : file not found.
10:43:59.546 Std 05200 JDBC. Version 11.2.0.4.0 Path  ./lib/db/oracle/ojdbc6.jar
10:43:59.548 Std 05200 sqljdbc4.jar. Version not available Path  ./lib/db/microsoft/sqljdbc4.jar
To be continued
Offline brendanb
« Reply #6 on: July 25, 2016, 10:41:55 AM »
continued ....
10:43:59.548 Std 05200 db2jcc4.jar. Version not available Path  ./lib/db/ibm/db2jcc4.jar
10:43:59.549 Std 05200 postgresql.jar. Version not available Path  ./lib/db/postgresql/postgresql.jar
10:43:59.549 Std 05200 log4j.jar. Version 1.2.16 Path  ./lib/log/log4j.jar
10:43:59.550 Std 05200 slf4j-api.jar. Version 1.6.6 Path  ./lib/log/slf4j-api.jar
10:43:59.550 Std 05200 slf4j-log4j12.jar. Version 1.6.6 Path  ./lib/log/slf4j-log4j12.jar
10:43:59.550 Std 05200 metrics-core.jar. Version 3.0.2 Path  ./lib/metrics/metrics-core.jar
10:43:59.551 Std 05200 metrics-healthchecks.jar. Version 3.0.2 Path  ./lib/metrics/metrics-healthchecks.jar
10:43:59.551 Std 05200 metrics-jvm.jar. Version 3.0.2 Path  ./lib/metrics/metrics-jvm.jar
10:43:59.552 Std 05200 metrics-log4j.jar. Version 3.0.2 Path  ./lib/metrics/metrics-log4j.jar
10:43:59.552 Std 05200 metrics-servlet.jar. Version 3.0.2 Path  ./lib/metrics/metrics-servlet.jar
10:43:59.553 Std 05200 metrics-servlets.jar. Version 3.0.2 Path  ./lib/metrics/metrics-servlets.jar
10:43:59.553 Std 05200 metrics-ganglia.jar. Version 3.0.2 Path  ./lib/metrics/metrics-ganglia.jar
10:43:59.554 Std 05200 gmetric4j.jar. Version not available Path  ./lib/metrics/gmetric4j.jar
10:43:59.554 Std 05200 jrpcgen.jar. Version not available Path  ./lib/remotetea/classes/jrpcgen.jar
10:43:59.555 Std 05200 oncrpc.jar. Version not available Path  ./lib/remotetea/classes/oncrpc.jar
10:43:59.555 Std 05200 portmap.jar. Version not available Path  ./lib/remotetea/classes/portmap.jar
10:43:59.556 Std 05200 org.springframework.beans.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.beans.jar
10:43:59.557 Std 05200 org.springframework.context.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.context.jar
10:43:59.557 Std 05200 org.springframework.core.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.core.jar
10:43:59.558 Std 05200 org.springframework.expression.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.expression.jar
10:43:59.558 Std 05200 org.springframework.jdbc.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.jdbc.jar
10:43:59.559 Std 05200 org.springframework.transaction.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.transaction.jar
10:43:59.559 Std 05200 org.springframework.aop.jar. Version 3.2.1.RELEASE Path  ./lib/spring/org.springframework.aop.jar
10:43:59.560 Std 05200 org.restlet.jar. Version not available Path  ./lib/restlet/org.restlet.jar
10:43:59.560 Std 05200 org.restlet.ext.json.jar. Version not available Path  ./lib/restlet/org.restlet.ext.json.jar
10:43:59.561 Std 05200 org.restlet.ext.xml.jar. Version not available Path  ./lib/restlet/org.restlet.ext.xml.jar
10:43:59.561 Std 05200 org.restlet.ext.jetty.jar. Version not available Path  ./lib/restlet/org.restlet.ext.jetty.jar
10:43:59.561 Std 05200 org.restlet.ext.slf4j.jar. Version not available Path  ./lib/restlet/org.restlet.ext.slf4j.jar
10:43:59.562 Std 05200 org.restlet.ext.ssl.jar. Version not available Path  ./lib/restlet/org.restlet.ext.ssl.jar
10:43:59.562 Std 05200 org.restlet.ext.fileupload.jar. Version not available Path  ./lib/restlet/org.restlet.ext.fileupload.jar
10:43:59.563 Std 05200 org.restlet.ext.net.jar. Version not available Path  ./lib/restlet/org.restlet.ext.net.jar
10:43:59.563 Std 05200 commons-collections.jar. Version 2.1 Path  ./lib/apache/commons-collections.jar
10:43:59.564 Std 05200 Jakarta Commons Logging. Version 1.1.1 Path  ./lib/apache/commons-logging.jar
10:43:59.564 Std 05200 Commons FileUpload. Version 1.2.2 Path  ./lib/apache/commons-fileupload.jar
10:43:59.564 Std 05200 Commons Pool. Version 1.5.6 Path  ./lib/apache/commons-pool.jar
10:43:59.565 Std 05200 javax.servlet.jar. Version not available Path  ./lib/servlet/javax.servlet.jar
10:43:59.566 Std 05200 org.eclipse.jetty.ajp.jar. Version 8.1.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.ajp.jar
10:43:59.566 Std 05200 org.eclipse.jetty.continuations.jar. Version 7.6.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.continuations.jar
10:43:59.567 Std 05200 org.eclipse.jetty.http.jar. Version 8.1.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.http.jar
10:43:59.567 Std 05200 org.eclipse.jetty.io.jar. Version 8.1.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.io.jar
10:43:59.568 Std 05200 org.eclipse.jetty.server.jar. Version 8.1.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.server.jar
10:43:59.568 Std 05200 org.eclipse.jetty.util.jar. Version 8.1.5.v20120716 Path  ./lib/servlet/org.eclipse.jetty.util.jar
10:43:59.569 Std 05200 aopalliance.jar. Version not available Path  ./lib/aop/aopalliance.jar
10:43:59.569 Std 05200 AspectJ Weaver Classes. Version 1.6.8 Path  ./lib/aop/aspectj.weaver.jar
10:43:59.570 Std 05200 AspectJ Runtime Classes . Version 1.6.5 Path  ./lib/aop/aspectjrt.jar
10:43:59.570 Std 05200 xstream.jar. Version not available Path  ./lib/processing/xml/xstream.jar
10:43:59.571 Trc 29998 [Ucs-Main] Jar './lib/processing/json/json.jar' has no manifest
10:43:59.571 Std 05200 opencsv.jar. Version 2.3 Path  ./lib/processing/csv/opencsv.jar
10:43:59.572 Std 05200 jericho-html.jar. Version not available Path  ./lib/processing/html/jericho-html.jar
10:43:59.572 Std 20040 [Ucs-Main] Java: version 1.7.0_79 (Oracle Corporation).
10:43:59.572 Std 20041 [Ucs-Main] Java Runtime Environment: Java(TM) SE Runtime Environment, version 1.7.0_79-b15.
10:43:59.581 Std 20003 [Ucs-Main] Java Virtual Machine: Java HotSpot(TM) 64-Bit Server VM release 24.79-b02 (Oracle Corporation) - mixed mode.
10:43:59.581 Std 20004 [Ucs-Main] JVM default encoding: 'Cp1252'.
10:43:59.581 Trc 20007 [Ucs-Main] System information: 'Windows Server 2008 R2 version 6.1 (level Service Pack 1) - Platform amd64 (64 bits)'.
10:43:59.584 Trc 20008 [Ucs-Main] System locale: 'English (South Africa)'.
10:43:59.584 Trc 20009 [Ucs-Main] System timezone: 'Central African Time (Africa/Harare) / GMT+02:00'.
10:43:59.585 Std 29997 [Ucs-Main] Configured tenants:1 for application 'universalcontactserver'
10:43:59.585 Dbg 29999 [Ucs-Main] Server channel configuration (default)
10:43:59.586 Dbg 29999 [Ucs-Main] GCTI_CONN_IPV6_ON is not set, using configured value for port 6130
10:43:59.587 Dbg 29999 [Ucs-Main] Server channel configured (default) done.
10:43:59.587 Dbg 29999 [Ucs-Main] Using port 6130 for ESP Protocol
10:43:59.609 Dbg 29999 [Ucs-Main] GCTI_CONN_IPV6_ON is not set, Connection to LCA will use JVM options : java.net.preferIPv4Stack=false java.net.preferIPv6Addresses=false
10:43:59.615 Std 29997 [Ucs-Main] Can't setup LCA: Only loopback (localhost or ::1) connection is supported
com.genesyslab.platform.commons.protocol.ProtocolException: Only loopback (localhost or ::1) connection is supported
at com.genesyslab.platform.management.protocol.LocalControlAgentProtocol.<init>(LocalControlAgentProtocol.java:104)
at com.genesyslab.icc.util.localcontrolagent.LocalControlAgentPSDK.<init>(LocalControlAgentPSDK.java:131)
at com.genesyslab.icc.util.Server.setupLCA(Server.java:279)
at com.genesyslab.icc.contactserver.ContactServerEngine.initInstance(ContactServerEngine.java:523)
at com.genesyslab.icc.contactserver.ContactServerEngine$4.run(ContactServerEngine.java:1395)
10:43:59.617 Dbg 29999 [Ucs-Main] Registering DataAccessPoint 'dapucs' with role 'Main'
10:43:59.622 Std 29997 [Ucs-Main] Ignoring invalid value 'null' for max-connections
10:43:59.624 Std 29997 [Ucs-Main] 'universalcontactserver' on 'dapucs' properties: (dbcase=any) (dbengine=mssql) (port=1433) (dbname=gen_ucs) (appname='universalcontactserver' on 'dapucs') (role=Main) (username=sa) (dbserver=demosrv) (Role=Main) (jdbc-debug=FALSE) (password=****) (query-timeout=15)
10:43:59.645 Std 29997 [Ucs-Main] DataSource(com.microsoft.sqlserver.jdbc.SQLServerDataSource) properties: (portnumber=1433) (databasename=gen_ucs) (applicationname='universalcontactserver' on 'dapucs') (servername=demosrv) (user=sa) (password=****)
10:43:59.692 Std 29997 [Ucs-Main] ConnectionPool(com.jolbox.bonecp.BoneCPDataSource) properties: (minconnectionsperpartition=1) (idleconnectiontestperiodinminutes=1) (maxconnectionsperpartition=40) (partitioncount=1) (jdbcurl=jdbc:sqlserver://demosrv:1433;databaseName=gen_ucs;) (poolname=Main) (acquireincrement=5) (disableconnectiontracking=true) (password=****) (statementscachesize=0) (username=sa) (connectionteststatement=select 1) (idlemaxageinminutes=5) (connectiontimeoutinms=30000) (user=sa)
10:43:59.692 Std 21136 [Ucs-Main] Using '7200' for transaction timeout to be consistent with query and long query timeout.
10:43:59.692 Trc 29998 [Ucs-Main] JDBC debug is off
10:43:59.693 Std 29997 [Ucs-Main] Checking DB schema for 'dapucs' with role 'Main'
10:43:59.693 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:43:59.694 Dbg 29999 [Ucs-Main] JDBC URL = jdbc:sqlserver://demosrv:1433;databaseName=gen_ucs;, Username = sa, partitions = 1, max (per partition) = 40, min (per partition) = 1, idle max age = 5 min, idle test period = 1 min, strategy = DEFAULT
10:43:59.886 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (425099819@txn-null) from pool in 191 ms
10:43:59.933 Trc 29998 [Ucs-Main] Datasource configured with driver 'Microsoft JDBC Driver 4.0 for SQL Server' (4.0.2206.100) on 'Microsoft SQL Server' (10.00.1600) with txn isolation level 'TRANSACTION_READ_COMMITTED' as sa
10:43:59.934 Trc 29998 [Ucs-Main] NLS Parameters Dump:
10:43:59.946 Dbg 29999 [Ucs-Main] Executing request: SELECT convert(varchar(100), DATABASEPROPERTYEX (?, 'Collation'))
10:43:59.959 Trc 29998 [Ucs-Main] Collation used for non unicode character columns:Latin1_General_CI_AS
10:43:59.962 Dbg 29999 [Ucs-Main] Listing tables:
10:43:59.973 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Attachment'
10:43:59.976 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Callback'
10:43:59.980 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Category'
10:43:59.983 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryAttribute'
10:43:59.987 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryRoot'
10:43:59.989 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryStructure'
10:43:59.992 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryStructureData'
10:43:59.995 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Chat'
10:43:59.997 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CoBrowseURL'
10:44:00.000 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Contact'
10:44:00.005 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactArchiveSynchro'
10:44:00.008 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactAttribute'
10:44:00.014 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactAttributeMetaData'
10:44:00.018 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Document'
10:44:00.020 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmailIn'
10:44:00.023 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmailOut'
10:44:00.026 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmRoute'
10:44:00.030 Dbg 29999 [Ucs-Main] Retrieving schema of table 'FieldCode'
10:44:00.032 Dbg 29999 [Ucs-Main] Retrieving schema of table 'FieldValue'
10:44:00.035 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IdGenerator'
10:44:00.037 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IdSequences'
10:44:00.039 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IndexEvent'
10:44:00.041 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IntegrityReport'
10:44:00.046 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Interaction'
10:44:00.056 Dbg 29999 [Ucs-Main] Retrieving schema of table 'InteractionMergeHistory'
10:44:00.059 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnAttributeMetaData'
10:44:00.064 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnContent'
10:44:00.066 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnContentSentReceived'
10:44:00.069 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnExtensionMetaData'
10:44:00.076 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_CategoryStatistics'
10:44:00.085 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_ConfusionMatrix'
10:44:00.116 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_EmailClassificationResult'
10:44:00.125 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_FAQObject'
10:44:00.134 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_FAQObjectCategories'
10:44:00.143 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_GlobalStatistics'
10:44:00.153 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_Model'
10:44:00.163 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TestingResult'
10:44:00.179 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingDataObject'
10:44:00.188 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingEmail'
10:44:00.198 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingJob'
10:44:00.208 Dbg 29999 [Ucs-Main] Retrieving schema of table 'LookupTableMetaData'
10:44:00.210 Dbg 29999 [Ucs-Main] Retrieving schema of table 'MergeHistory'
10:44:00.213 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PhoneCall'
10:44:00.216 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIGroup'
10:44:00.220 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIGroupContent'
10:44:00.222 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIRegEx'
10:44:00.224 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIRule'
10:44:00.226 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIITestMessage'
10:44:00.228 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ProfileExtensionMetaData'
10:44:00.231 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ResourceProperty'
10:44:00.233 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SchemaHistory'
10:44:00.235 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceCompleted'
10:44:00.237 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceExtensionMetaData'
10:44:00.239 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceStarted'
10:44:00.242 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceStartedAnonymous'
10:44:00.245 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SNRelation'
10:44:00.247 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SNRelationAction'
10:44:00.249 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponse'
10:44:00.253 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponseFavorite'
10:44:00.254 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponseUsage'
10:44:00.256 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateCompleted'
10:44:00.258 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateExtensionMetaData'
10:44:00.260 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateStarted'
10:44:00.263 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SubTenantMetaData'
10:44:00.265 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SystemParam'
10:44:00.267 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskCompleted'
10:44:00.270 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskExtensionMetaData'
10:44:00.272 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskStarted'
10:44:00.277 Dbg 29999 [Ucs-Main]
Id nvarchar(16) nullable:false
DocumentId nvarchar(16) nullable:false
EntityId nvarchar(16) nullable:false
EntityTypeId tinyint(3) nullable:false
  PK_ATTACHMENT on Id  Attachment_EntityId_I on EntityId  Attachment_EntType_I on EntityTypeId  IsAttached_FK on DocumentId
Callback:
CallBackStatus int(10) nullable:true
DetailedDescription ntext(1073741823) nullable:true
CustomData ntext(1073741823) nullable:true
DesiredResponseType int(10) nullable:false
StartTime datetime(23) nullable:false
EndTime datetime(23) nullable:true
CustomerNumber varchar(32) nullable:false
Attempts int(10) nullable:false
DN varchar(32) nullable:true
Location nvarchar(32) nullable:true
CallbackServerID varchar(256) nullable:true
CallResult tinyint(3) nullable:true
TheType tinyint(3) nullable:true
  PK_CALLBACK on Id
Category:
TheName nvarchar(254) nullable:false
OwnerId int(10) nullable:false
ModifiedDate datetime(23) nullable:false
Status varchar(64) nullable:false
TheType tinyint(3) nullable:false
Description nvarchar(254) nullable:true
  PK_CATEGORY on Id  Category_TheName_I on TheName
CategoryAttribute:
CategoryId nvarchar(16) nullable:true
TheName nvarchar(256) nullable:false
StrValue nvarchar(256) nullable:true
LongStrValue ntext(1073741823) nullable:true
BinValue image(2147483647) nullable:true
IntValue int(10) nullable:true
IdValue nvarchar(16) nullable:true
  PK_CATEGORYATTRIBUTE on Id  HasAttribute_FK on CategoryId
CategoryRoot:
CategoryId nvarchar(16) nullable:false
TenantId int(10) nullable:false
SubTenantId int(10) nullable:true
Lang varchar(64) nullable:false
  PK_CATEGORYROOT on Id  IsRootCategory_FK on CategoryId
CategoryStructure:
CategoryParentId nvarchar(16) nullable:false
CategoryChildId nvarchar(16) nullable:false
  PK_CATEGORYSTRUCTURE on Id  CategoryStructure_CategoryChildId_I on CategoryChildId  CategoryStructure_CategoryParentId_I on CategoryParentId
CategoryStructureData:
OwnerId nvarchar(16) nullable:false
ObjectClassName varchar(256) nullable:false
ObjectId nvarchar(16) nullable:false
  PK_CATEGORYSTRUCTUREDATA on Id  CategoryStructureData_ObjectId_I on ObjectId  CategoryStructureData_OwnerId_I on OwnerId
Chat:
EstablishedDate datetime(23) nullable:true
ReleasedDate datetime(23) nullable:true
  PK_CHAT on Id
CoBrowseURL:
InteractionId nvarchar(16) nullable:false
URL varchar(255) nullable:false
VisitedDate datetime(23) nullable:false
  PK_COBROWSEURL on Id  Includes_FK on InteractionId
Contact:
IsExternalResource bit(1) nullable:true
StrAttribute1 nvarchar(256) nullable:true
StrAttribute2 nvarchar(256) nullable:true
StrAttribute3 nvarchar(256) nullable:true
StrAttribute4 nvarchar(256) nullable:true
StrAttribute5 nvarchar(256) nullable:true
StrAttribute6 nvarchar(256) nullable:true
StrAttribute7 nvarchar(256) nullable:true
StrAttribute8 nvarchar(256) nullable:true
StrAttribute9 nvarchar(256) nullable:true
StrAttribute10 nvarchar(256) nullable:true
DateAttribute1 datetime(23) nullable:true
DateAttribute2 datetime(23) nullable:true
DateAttribute3 datetime(23) nullable:true
CreatedDate datetime(23) nullable:true
ModifiedDate datetime(23) nullable:true
MergeId nvarchar(16) nullable:true
  PK_CONTACT on Id
ContactArchiveSynchro:
OperationDate datetime(23) nullable:false
Operation smallint(5) nullable:false
SrcContactId nvarchar(16) nullable:true
DestinationContactId nvarchar(16) nullable:true
  PK_CONTACTARCHIVESYNCHRO on Id  DestinationContactId_I on DestinationContactId  MergeId_I on MergeId  OperationDate_I on OperationDate  SrcContactId_I on SrcContactId
ContactAttribute:
AttributeId nvarchar(16) nullable:true
AttributeName nvarchar(256) nullable:true
MimeType varchar(256) nullable:true
StrValueLowerCase nvarchar(256) nullable:true
DateValue datetime(23) nullable:true
Description nvarchar(256) nullable:true
IsPrimary bit(1) nullable:false
  PK_CONTACTATTRIBUTE on Id  ContactAttribute_StrValue_I on StrValue  ContactAttribute_StrValueLowerCase_I on StrValueLowerCase  HasAttrib_FK on ContactId
ContactAttributeMetaData:
DisplayName nvarchar(256) nullable:true
Active bit(1) nullable:false
Format nvarchar(256) nullable:true
IsSearchable bit(1) nullable:false
IsCaseSensitive bit(1) nullable:false
IsSortable bit(1) nullable:false
MappingColumnName varchar(20) nullable:true
SearchLevel tinyint(3) nullable:true
Cardinality tinyint(3) nullable:true
  PK_CONTACTATTRIBUTEMETADATA on Id
Document:
MimeType varchar(256) nullable:false
TheSize int(10) nullable:false
Content image(2147483647) nullable:true
  PK_DOCUMENT on Id
EmailIn:
FromAddress nvarchar(256) nullable:true
FromPersonal nvarchar(256) nullable:true
ReplyToAddress nvarchar(256) nullable:true
ToAddresses ntext(1073741823) nullable:true
CcAddresses ntext(1073741823) nullable:true
BccAddresses ntext(1073741823) nullable:true
SentDate datetime(23) nullable:true
Mailbox nvarchar(256) nullable:false
WhichRuleMatched nvarchar(16) nullable:true
EmailOutId nvarchar(16) nullable:true
Header image(2147483647) nullable:true
  PK_EMAILIN on Id
EmailOut:
Forward int(10) nullable:false
ReferenceId varchar(255) nullable:true
ReviewerId int(10) nullable:true
StandardResponseId nvarchar(16) nullable:true
  PK_EMAILOUT on Id
EmRoute:
AddressesToMatch ntext(1073741823) nullable:true
Description nvarchar(254) nullable:false
IsEnabled bit(1) nullable:false
MatchText ntext(1073741823) nullable:true
MatchTextInHeader bit(1) nullable:false
MatchTextInBody bit(1) nullable:false
MatchTextInSubject bit(1) nullable:false
TheOrder int(10) nullable:false
LogicalRule varchar(254) nullable:false
  PK_EMROUTE on Id
FieldCode:
TheName nvarchar(128) nullable:false
Value nvarchar(1024) nullable:false
TheComment nvarchar(256) nullable:true
  PK_FIELDCODE on Id
FieldValue:
IsConstant bit(1) nullable:false
DoubleValue float(53) nullable:true
  PK_FIELDVALUE on Id  FieldValue_TheName_I on TheName
IdGenerator:
Ordinal int(10) nullable:false
  PK_IDGENERATOR on Id
IdSequences:
Seed numeric(18) nullable:false
IndexEvent:
IndexName nvarchar(20) nullable:false
EventDate datetime(23) nullable:false
Operation tinyint(3) nullable:false
ProcessedPri bit(1) nullable:false
ProcessedBck bit(1) nullable:false
  PK_Index_Event on Id
IntegrityReport:
IssueId tinyint(3) nullable:false
DetectionDate datetime(23) nullable:false
CorrectionDate datetime(23) nullable:true
FirstId nvarchar(16) nullable:false
SecondId nvarchar(16) nullable:true
Status bit(1) nullable:false
SessionId int(10) nullable:false
  PK_INTEGRITYREPORT on Id  IR_Composite_1 on FirstId  IR_Composite_1 on IssueId  IR_Composite_2 on IssueId  IR_Composite_2 on TenantId  IR_Composite_2 on Status  IR_Composite_3 on SecondId  IR_Composite_3 on IssueId
Interaction:
Status tinyint(3) nullable:false
MediaTypeId nvarchar(32) nullable:false
SubtypeId nvarchar(32) nullable:true
ExternalId nvarchar(256) nullable:true
OwnerId int(10) nullable:true
ParentId nvarchar(16) nullable:true
StartDate datetime(23) nullable:false
EndDate datetime(23) nullable:true
ThreadId nvarchar(16) nullable:true
Timeshift smallint(5) nullable:true
Subject nvarchar(512) nullable:true
StructuredText ntext(1073741823) nullable:true
StructTextMimeType varchar(256) nullable:true
TheComment ntext(1073741823) nullable:true
ThreadHash int(10) nullable:true
CanBeParent bit(1) nullable:false
CreatorAppId int(10) nullable:false
QueueName nvarchar(64) nullable:true
AllAttributes image(2147483647) nullable:true
IntAttribute1 int(10) nullable:true
IntAttribute2 int(10) nullable:true
IntAttribute3 int(10) nullable:true
IntAttribute4 int(10) nullable:true
IntAttribute5 int(10) nullable:true
IsSpam bit(1) nullable:true
WebSafeEmailStatus nvarchar(32) nullable:true
IsCategoryApproved bit(1) nullable:true
StoppedReason nvarchar(64) nullable:true
Lang varchar(64) nullable:true
  PK_INTERACTION on Id  Assigned_FK on ContactId  Interaction_ExternalId_I on ExternalId  Interaction_ThreadHash_I on ThreadHash  Interaction_ThreadId_I on ThreadId  IsParent_FK on ParentId  Ixn_Composite_1 on Status  Ixn_Composite_1 on EntityTypeId  Ixn_Composite_1 on TypeId  Ixn_Composite_1 on CreatorAppId  Ixn_Composite_1 on MediaTypeId  Ixn_Composite_1 on StartDate  Ixn_Composite_1 on TenantId  Ixn_Composite_Arch1 on EndDate  Ixn_Composite_Arch1 on Status  Ixn_Composite_Arch1 on TenantId  Ixn_Composite_Arch1 on ParentId  Ixn_Composite_KM1 on EndDate  Ixn_Composite_KM1 on CategoryId  Ixn_Composite_KM1 on IsCategoryApproved  Ixn_OwnerId on OwnerId  Ixn_OwnerId on Status  Ixn_OwnerId on StartDate
InteractionMergeHistory:
MergeId nvarchar(16) nullable:false
  PK_INTERACTIONMERGEHISTORY on Id  InteractionId_I on InteractionId  MergeHistoryHasInteraction_FK on MergeId
IxnAttributeMetaData:
  PK_IXNATTRIBUTEMETADATA on Id
IxnContent:
Content image(2147483647) nullable:false
  PK_IXNCONTENT on Id
IxnContentSentReceived:
  PK_IXNCONTENTSENTRECEIVED on Id
IxnExtensionMetaData:
ExtensionName varchar(32) nullable:false
ExtensionType varchar(32) nullable:false
ExtensionLength int(10) nullable:true
AttributeName varchar(32) nullable:false
AttributeType varchar(32) nullable:false
AttributeDefault varchar(32) nullable:true
AttributeLength int(10) nullable:false
AttributeEncrypt bit(1) nullable:false
AttributeUnique bit(1) nullable:false
AttributeNullable bit(1) nullable:false
kt_CategoryStatistics:
TestingResultId nvarchar(16) nullable:false
ConfidenceLevel float(53) nullable:false
ClassificationCategoryId nvarchar(16) nullable:false
ValueName varchar(64) nullable:false
Value float(53) nullable:false
  PK_KT_CATEGORYSTATISTICS on Id  TestingResultHasCatStatistics_FK on TestingResultId
kt_ConfusionMatrix:
ClassificationCategoryId1 nvarchar(16) nullable:false
ClassificationCategoryId2 nvarchar(16) nullable:false
TheSize float(53) nullable:false
  PK_KT_CONFUSIONMATRIX on Id  TestingResultHasConfusionMatrix_FK on TestingResultId
kt_EmailClassificationResult:
TrainingEmailId nvarchar(16) nullable:false
ConfidenceLevel float(53) nullable:true
  PK_KT_EMAILCLASSIFICATIONRESUL on Id  TestingResultHasEmailClassificationResult_FK on TestingResultId
kt_FAQObject:
FAQName nvarchar(16) nullable:false
RootCategoryId nvarchar(16) nullable:false
CreationDate datetime(23) nullable:false
TOId nvarchar(16) nullable:true
ModelId nvarchar(16) nullable:true
Info nvarchar(255) nullable:true
  PK_KT_FAQOBJECT on Id
kt_FAQObjectCategories:
FAQId nvarchar(16) nullable:false
  PK_KT_FAQOBJECTCATEGORIES on Id
kt_GlobalStatistics:
TheType varchar(64) nullable:false
  PK_KT_GLOBALSTATISTICS on Id  TestingResultHasGlobalStatistics_FK on TestingResultId
kt_Model:
TheName nvarchar(255) nullable:false
Model image(2147483647) nullable:false
TrainingDataObjectId nvarchar(16) nullable:false
IsActive bit(1) nullable:false
ModelSize int(10) nullable:true
RunDate datetime(23) nullable:true
RunDurationSec int(10) nullable:true
AppName varchar(64) nullable:true
Engine varchar(64) nullable:true
PersonId int(10) nullable:true
Params varchar(255) nullable:true
RootName nvarchar(255) nullable:true
AdvancedParams image(2147483647) nullable:true
  PK_KT_MODEL on Id  TrainingDataObjectHasModel_FK on TrainingDataObjectId
kt_TestingResult:
CreationTime datetime(23) nullable:false
ModelId nvarchar(16) nullable:false
  PK_KT_TESTINGRESULT on Id  TestingResultHasModel_FK on ModelId  TrainingDataObjectHasTestingResult_FK on TrainingDataObjectId
kt_TrainingDataObject:
EndTime datetime(23) nullable:false
RootName nvarchar(255) nullable:false
  PK_KT_TRAININGDATAOBJECT on Id
kt_TrainingEmail:
Subject nvarchar(512) nullable:false
AgentId int(10) nullable:true
ReceivedDate datetime(23) nullable:false
Text ntext(1073741823) nullable:false
ResponseText ntext(1073741823) nullable:true
  PK_KT_TRAININGEMAIL on Id  TrainingDataHasEmail_FK on TrainingDataObjectId  TrainingEmailHasCategory_FK on CategoryId
kt_TrainingJob:
Status int(10) nullable:false
ErrorMsg varchar(255) nullable:true
ModelName nvarchar(64) nullable:false
TestingResultName nvarchar(255) nullable:false
PersonId int(10) nullable:false
InternalService nvarchar(255) nullable:true
  PK_KT_TRAININGJOB on Id  TestingResultHasTrainingJob_FK on TestingResultId  TrainingDataObjectHasTrainingJob_FK on TrainingDataObjectId
LookupTableMetaData:
KeyName varchar(32) nullable:false
ColumnName varchar(32) nullable:false
ColumnDataType varchar(32) nullable:false
ColumnFunction varchar(32) nullable:false
ColumnIndex int(10) nullable:false
ColumnSource varchar(32) nullable:false
MergeHistory:
MergeDate datetime(23) nullable:false
SourceContactId nvarchar(16) nullable:true
SrcContactContent image(2147483647) nullable:false
DstContactContent image(2147483647) nullable:false
Validated bit(1) nullable:false
Reason nvarchar(512) nullable:true
Description nvarchar(512) nullable:true
  PK_MERGEHISTORY on Id  DstContactId_I on DestinationContactId  SourceContactId_I on SourceContactId
PhoneCall:
Duration int(10) nullable:true
Outcome varchar(100) nullable:true
PhoneNumber nvarchar(30) nullable:true
TConnectionId nvarchar(16) nullable:true
  PK_PHONECALL on Id  TConnId_I on TConnectionId
PIIGroup:
Type nvarchar(16) nullable:false
  PK_PIIGroup on Id
PIIGroupContent:
PIIGroupId nvarchar(16) nullable:false
PIIRuleId nvarchar(16) nullable:false
PIIRuleStatus nvarchar(254) nullable:false
PIIRulePriority int(10) nullable:false
  PK_PIIGroupContent on Id
PIIRegEx:
Properties ntext(1073741823) nullable:true
Expression ntext(1073741823) nullable:false
  PK_PIIRegEx on Id
PIIRule:
RegExId nvarchar(16) nullable:false
ReplacementPattern ntext(1073741823) nullable:true
Actions ntext(1073741823) nullable:true
  PK_PIIRule on Id
PIITestMessage:
RelatedObjectId nvarchar(16) nullable:false
RelatedObjectType nvarchar(64) nullable:false
  PK_PIITestMessage on Id
ProfileExtensionMetaData:
ResourceProperty:
TheKey nvarchar(256) nullable:false
IsString bit(1) nullable:false
  PK_RESOURCEPROPERTY on Id
SchemaHistory:
Timestamp datetime(23) nullable:false
Version char(11) nullable:false
Description varchar(256) nullable:true
  PK_SCHEMAHISTORY on Id
ServiceCompleted:
ServiceId numeric(19) nullable:false
ApplicationId numeric(18) nullable:true
ApplicationType int(10) nullable:true
ResourceId numeric(18) nullable:true
ResourceType int(10) nullable:true
InteractionId nvarchar(50) nullable:true
MediaType int(10) nullable:true
SessionId nvarchar(32) nullable:true
Disposition int(10) nullable:true
DispositionDescription nvarchar(64) nullable:true
  PK_SERVICECOMPLETED on ServiceId
ServiceExtensionMetaData:
ServiceStarted:
EstimatedDuration int(10) nullable:true
ServiceType int(10) nullable:false
CustomerId nvarchar(16) nullable:false
StartedAnonymousFlag tinyint(3) nullable:false
  PK_SERVICESTARTED on ServiceId  ServiceStarted_CustomerId_I on CustomerId
ServiceStartedAnonymous:
ContactKey nvarchar(16) nullable:false
  PK_SERVICESTARTEDANONYMOUS on ServiceId  ServiceStartedA_ContactKey_I on ContactKey
SNRelation:
SocialNetwork nvarchar(20) nullable:false
ServiceAccount nvarchar(100) nullable:false
ClientAccount nvarchar(100) nullable:false
Relation nvarchar(20) nullable:false
Source nvarchar(100) nullable:false
UpdatedAt datetime(23) nullable:false
  PK_SNRelation on Id  SNRCLTAccountI on ClientAccount
SNRelationAction:
Action nvarchar(20) nullable:false
Actor nvarchar(100) nullable:false
StartedAt datetime(23) nullable:false
FinishedAt datetime(23) nullable:true
Progress nvarchar(50) nullable:true
  PK_SNRelationAction on Id
StandardResponse:
StandardResponseId nvarchar(16) nullable:false
Body ntext(1073741823) nullable:true
StructuredBody ntext(1073741823) nullable:true
AckUsageType tinyint(3) nullable:false
AutoRespUsageType tinyint(3) nullable:false
AgentDesktopUsageType tinyint(3) nullable:false
WSSUsageType tinyint(3) nullable:false
EmailOutUsageType tinyint(3) nullable:false
VoiceAutoRespUsageType tinyint(3) nullable:false
Version smallint(5) nullable:false
Status varchar(80) nullable:false
ExpirationDate datetime(23) nullable:true
StartDate datetime(23) nullable:true
CustomFieldCodes ntext(1073741823) nullable:true
AreFieldCodesParsed bit(1) nullable:false
  PK_STANDARDRESPONSE on Id  StandardResponse_StdRespId_I on StandardResponseId
StandardResponseFavorite:
  PK_STANDARDRESPONSEFAVORITE on Id  CanBeA_FK on StandardResponseId
StandardResponseUsage:
  PK_STANDARDRESPONSEUSAGE on Id
StateCompleted:
StateId int(10) nullable:false
  StateCompleted_ServiceId_I on ServiceId
StateExtensionMetaData:
StateStarted:
StateType int(10) nullable:false
PreviousStateId int(10) nullable:true
  StateStarted_ServiceId_I on ServiceId
SubTenantMetaData:
SubTenantId int(10) nullable:false
Id nvarchar(256) nullable:false
FolderName nvarchar(256) nullable:true
  PK_SUBTENANTEMETADATA on Id  PK_SUBTENANTEMETADATA on TenantId
SystemParam:
KeyName nvarchar(256) nullable:false
Value nvarchar(1024) nullable:true
  PK_SYSTEMPARAM on KeyName
TaskCompleted:
TaskId int(10) nullable:false
  TaskCompleted_ServiceId_I on ServiceId
TaskExtensionMetaData:
TaskStarted:
TaskType int(10) nullable:false
  TaskStarted_ServiceId_I on ServiceId
10:44:00.278 Dbg 29999 [Ucs-Main] Released connection (425099819@txn-null) to pool
10:44:00.278 Dbg 29999 [Ucs-Main] Additional Columns are allowed
10:44:00.278 Dbg 29999 [Ucs-Main] Missing Indexes are allowed
10:44:00.278 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.279 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (480493110@txn-null) from pool in 0 ms
10:44:00.281 Trc 21103 [Ucs-Main] Schema information : [id: 8.5.200.09, timestamp: 2016-07-21T22:00:00Z, version: 8.5.200.00 , description: ]
10:44:00.282 Dbg 29999 [Ucs-Main] Released connection (480493110@txn-null) to pool
10:44:00.282 Trc 29998 [Ucs-Main] Checking tables and columns on 'dapucs'
10:44:00.282 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.282 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (375957857@txn-null) from pool in 0 ms
To be continued .....
Offline brendanb
« Reply #7 on: July 25, 2016, 10:42:53 AM »
continued ....
10:44:00.286 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Attachment'
10:44:00.287 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Callback'
10:44:00.288 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Category'
10:44:00.290 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryAttribute'
10:44:00.291 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryRoot'
10:44:00.293 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryStructure'
10:44:00.294 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryStructureData'
10:44:00.295 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Chat'
10:44:00.296 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CoBrowseURL'
10:44:00.297 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Contact'
10:44:00.299 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactArchiveSynchro'
10:44:00.300 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactAttribute'
10:44:00.301 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactAttributeMetaData'
10:44:00.303 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Document'
10:44:00.304 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmailIn'
10:44:00.305 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmailOut'
10:44:00.307 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmRoute'
10:44:00.308 Dbg 29999 [Ucs-Main] Retrieving columns of table 'FieldCode'
10:44:00.309 Dbg 29999 [Ucs-Main] Retrieving columns of table 'FieldValue'
10:44:00.312 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IdGenerator'
10:44:00.313 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IdSequences'
10:44:00.314 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IndexEvent'
10:44:00.315 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IntegrityReport'
10:44:00.317 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Interaction'
10:44:00.320 Dbg 29999 [Ucs-Main] Retrieving columns of table 'InteractionMergeHistory'
10:44:00.321 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnAttributeMetaData'
10:44:00.323 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnContent'
10:44:00.324 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnContentSentReceived'
10:44:00.325 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnExtensionMetaData'
10:44:00.327 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_CategoryStatistics'
10:44:00.335 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_ConfusionMatrix'
10:44:00.343 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_EmailClassificationResult'
10:44:00.351 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_FAQObject'
10:44:00.359 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_FAQObjectCategories'
10:44:00.367 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_GlobalStatistics'
10:44:00.375 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_Model'
10:44:00.383 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TestingResult'
10:44:00.391 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingDataObject'
10:44:00.400 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingEmail'
10:44:00.408 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingJob'
10:44:00.416 Dbg 29999 [Ucs-Main] Retrieving columns of table 'LookupTableMetaData'
10:44:00.418 Dbg 29999 [Ucs-Main] Retrieving columns of table 'MergeHistory'
10:44:00.419 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PhoneCall'
10:44:00.420 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIGroup'
10:44:00.421 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIGroupContent'
10:44:00.422 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIRegEx'
10:44:00.424 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIRule'
10:44:00.426 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIITestMessage'
10:44:00.427 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ProfileExtensionMetaData'
10:44:00.429 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ResourceProperty'
10:44:00.430 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SchemaHistory'
10:44:00.431 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceCompleted'
10:44:00.433 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceExtensionMetaData'
10:44:00.435 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceStarted'
10:44:00.437 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceStartedAnonymous'
10:44:00.439 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SNRelation'
10:44:00.441 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SNRelationAction'
10:44:00.442 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponse'
10:44:00.444 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponseFavorite'
10:44:00.445 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponseUsage'
10:44:00.446 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateCompleted'
10:44:00.448 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateExtensionMetaData'
10:44:00.449 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateStarted'
10:44:00.451 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SubTenantMetaData'
10:44:00.452 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SystemParam'
10:44:00.453 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskCompleted'
10:44:00.454 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskExtensionMetaData'
10:44:00.456 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskStarted'
10:44:00.460 Dbg 29999 [Ucs-Main] Released connection (375957857@txn-null) to pool
10:44:00.460 Trc 29998 [Ucs-Main] Tables check finished
10:44:00.461 Trc 29998 [Ucs-Main] Checking indexes on 'dapucs'
10:44:00.461 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.461 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1439327782@txn-null) from pool in 0 ms
10:44:00.464 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Attachment'
10:44:00.466 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Callback'
10:44:00.467 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Category'
10:44:00.467 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryAttribute'
10:44:00.468 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryRoot'
10:44:00.470 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryStructure'
10:44:00.472 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryStructureData'
10:44:00.473 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Chat'
10:44:00.474 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CoBrowseURL'
10:44:00.476 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Contact'
10:44:00.479 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactArchiveSynchro'
10:44:00.480 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactAttribute'
10:44:00.481 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactAttributeMetaData'
10:44:00.481 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Document'
10:44:00.482 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmailIn'
10:44:00.483 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmailOut'
10:44:00.484 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmRoute'
10:44:00.484 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'FieldCode'
10:44:00.485 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'FieldValue'
10:44:00.486 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IdGenerator'
10:44:00.486 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IdSequences'
10:44:00.487 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IndexEvent'
10:44:00.488 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IntegrityReport'
10:44:00.489 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Interaction'
10:44:00.490 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'InteractionMergeHistory'
10:44:00.491 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnAttributeMetaData'
10:44:00.492 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnContent'
10:44:00.493 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnContentSentReceived'
10:44:00.493 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnExtensionMetaData'
10:44:00.494 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_CategoryStatistics'
10:44:00.495 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_ConfusionMatrix'
10:44:00.496 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_EmailClassificationResult'
10:44:00.497 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_FAQObject'
10:44:00.498 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_FAQObjectCategories'
10:44:00.499 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_GlobalStatistics'
10:44:00.500 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_Model'
10:44:00.500 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TestingResult'
10:44:00.501 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingDataObject'
10:44:00.502 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingEmail'
10:44:00.503 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingJob'
10:44:00.504 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'LookupTableMetaData'
10:44:00.505 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'MergeHistory'
10:44:00.506 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PhoneCall'
10:44:00.507 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIGroup'
10:44:00.508 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIGroupContent'
10:44:00.508 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIRegEx'
10:44:00.509 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIRule'
10:44:00.511 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIITestMessage'
10:44:00.512 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ProfileExtensionMetaData'
10:44:00.513 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ResourceProperty'
10:44:00.515 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SchemaHistory'
10:44:00.517 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceCompleted'
10:44:00.518 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceExtensionMetaData'
10:44:00.519 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceStarted'
10:44:00.520 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceStartedAnonymous'
10:44:00.521 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SNRelation'
10:44:00.521 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SNRelationAction'
10:44:00.522 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponse'
10:44:00.523 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponseFavorite'
10:44:00.523 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponseUsage'
10:44:00.524 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateCompleted'
10:44:00.525 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateExtensionMetaData'
10:44:00.526 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateStarted'
10:44:00.526 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SubTenantMetaData'
10:44:00.527 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SystemParam'
10:44:00.528 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskCompleted'
10:44:00.529 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskExtensionMetaData'
10:44:00.530 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskStarted'
10:44:00.531 Dbg 29999 [Ucs-Main] Released connection (1439327782@txn-null) to pool
10:44:00.531 Trc 29998 [Ucs-Main] Index check finished
10:44:00.533 Dbg 29999 [Ucs-Main] Registering KPI counters on [Main DS]  connection
10:44:00.533 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.534 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1268582882@txn-null) from pool in 0 ms
10:44:00.541 Dbg 29999 [Ucs-Main] Released connection (1268582882@txn-null) to pool
10:44:00.541 Dbg 29999 [Ucs-Main] Registering DataAccessPoint 'dapucsarchive' with role 'Archive'
10:44:00.542 Std 29997 [Ucs-Main] Ignoring invalid value 'null' for max-connections
10:44:00.542 Std 29997 [Ucs-Main] 'universalcontactserver' on 'dapucsarchive' properties: (dbcase=any) (dbengine=mssql) (port=1433) (dbname=gen_ucsarc) (appname='universalcontactserver' on 'dapucsarchive') (role=Archive) (username=genesys) (dbserver=demosrv) (Role=Archive) (jdbc-debug=FALSE) (password=****) (query-timeout=15)
10:44:00.546 Std 29997 [Ucs-Main] DataSource(com.microsoft.sqlserver.jdbc.SQLServerDataSource) properties: (portnumber=1433) (databasename=gen_ucsarc) (applicationname='universalcontactserver' on 'dapucsarchive') (servername=demosrv) (user=genesys) (password=****)
10:44:00.556 Std 29997 [Ucs-Main] ConnectionPool(com.jolbox.bonecp.BoneCPDataSource) properties: (minconnectionsperpartition=1) (idleconnectiontestperiodinminutes=1) (maxconnectionsperpartition=40) (partitioncount=1) (jdbcurl=jdbc:sqlserver://demosrv:1433;databaseName=gen_ucsarc;) (poolname=Archive) (acquireincrement=5) (disableconnectiontracking=true) (password=****) (statementscachesize=0) (username=genesys) (connectionteststatement=select 1) (idlemaxageinminutes=5) (connectiontimeoutinms=30000) (user=genesys)
10:44:00.559 Std 21136 [Ucs-Main] Using '7200' for transaction timeout to be consistent with query and long query timeout.
10:44:00.560 Trc 29998 [Ucs-Main] JDBC debug is off
10:44:00.560 Std 29997 [Ucs-Main] Checking DB schema for 'dapucsarchive' with role 'Archive'
10:44:00.560 Dbg 29999 [Ucs-Main] [Arch DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.560 Dbg 29999 [Ucs-Main] JDBC URL = jdbc:sqlserver://demosrv:1433;databaseName=gen_ucsarc;, Username = genesys, partitions = 1, max (per partition) = 40, min (per partition) = 1, idle max age = 5 min, idle test period = 1 min, strategy = DEFAULT
10:44:00.593 Dbg 29999 [Ucs-Main] [Arch DS] Acquired new connection (701818179@txn-null) from pool in 33 ms
10:44:00.594 Trc 29998 [Ucs-Main] Datasource configured with driver 'Microsoft JDBC Driver 4.0 for SQL Server' (4.0.2206.100) on 'Microsoft SQL Server' (10.00.1600) with txn isolation level 'TRANSACTION_READ_COMMITTED' as genesys
10:44:00.594 Trc 29998 [Ucs-Main] NLS Parameters Dump:
10:44:00.594 Dbg 29999 [Ucs-Main] Executing request: SELECT convert(varchar(100), DATABASEPROPERTYEX (?, 'Collation'))
10:44:00.595 Trc 29998 [Ucs-Main] Collation used for non unicode character columns:Latin1_General_CI_AS
10:44:00.600 Dbg 29999 [Ucs-Main] Listing tables:
10:44:00.603 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Attachment'
10:44:00.606 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Callback'
10:44:00.618 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Category'
10:44:00.622 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryAttribute'
10:44:00.626 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryRoot'
10:44:00.629 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryStructure'
10:44:00.632 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CategoryStructureData'
10:44:00.635 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Chat'
10:44:00.636 Dbg 29999 [Ucs-Main] Retrieving schema of table 'CoBrowseURL'
10:44:00.638 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Contact'
10:44:00.641 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactArchiveSynchro'
10:44:00.643 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactAttribute'
10:44:00.645 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ContactAttributeMetaData'
10:44:00.647 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Document'
10:44:00.649 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmailIn'
10:44:00.651 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmailOut'
10:44:00.653 Dbg 29999 [Ucs-Main] Retrieving schema of table 'EmRoute'
10:44:00.656 Dbg 29999 [Ucs-Main] Retrieving schema of table 'FieldCode'
10:44:00.658 Dbg 29999 [Ucs-Main] Retrieving schema of table 'FieldValue'
10:44:00.660 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IdGenerator'
10:44:00.662 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IdSequences'
10:44:00.664 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IndexEvent'
10:44:00.666 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IntegrityReport'
10:44:00.670 Dbg 29999 [Ucs-Main] Retrieving schema of table 'Interaction'
10:44:00.676 Dbg 29999 [Ucs-Main] Retrieving schema of table 'InteractionMergeHistory'
10:44:00.678 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnAttributeMetaData'
10:44:00.680 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnContent'
10:44:00.682 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnContentSentReceived'
10:44:00.683 Dbg 29999 [Ucs-Main] Retrieving schema of table 'IxnExtensionMetaData'
10:44:00.685 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_CategoryStatistics'
10:44:00.695 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_ConfusionMatrix'
10:44:00.703 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_EmailClassificationResult'
10:44:00.712 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_FAQObject'
10:44:00.721 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_FAQObjectCategories'
10:44:00.730 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_GlobalStatistics'
10:44:00.738 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_Model'
10:44:00.748 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TestingResult'
10:44:00.756 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingDataObject'
10:44:00.766 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingEmail'
10:44:00.775 Dbg 29999 [Ucs-Main] Retrieving schema of table 'kt_TrainingJob'
10:44:00.784 Dbg 29999 [Ucs-Main] Retrieving schema of table 'LookupTableMetaData'
10:44:00.786 Dbg 29999 [Ucs-Main] Retrieving schema of table 'MergeHistory'
10:44:00.789 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PhoneCall'
10:44:00.790 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIGroup'
10:44:00.792 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIGroupContent'
10:44:00.794 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIRegEx'
10:44:00.796 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIIRule'
10:44:00.797 Dbg 29999 [Ucs-Main] Retrieving schema of table 'PIITestMessage'
10:44:00.799 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ProfileExtensionMetaData'
10:44:00.801 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ResourceProperty'
10:44:00.803 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SchemaHistory'
10:44:00.804 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceCompleted'
10:44:00.806 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceExtensionMetaData'
10:44:00.808 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceStarted'
10:44:00.810 Dbg 29999 [Ucs-Main] Retrieving schema of table 'ServiceStartedAnonymous'
10:44:00.812 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SNRelation'
10:44:00.814 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SNRelationAction'
10:44:00.816 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponse'
10:44:00.819 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponseFavorite'
10:44:00.821 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StandardResponseUsage'
10:44:00.828 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateCompleted'
10:44:00.830 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateExtensionMetaData'
10:44:00.832 Dbg 29999 [Ucs-Main] Retrieving schema of table 'StateStarted'
10:44:00.835 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SubTenantMetaData'
10:44:00.837 Dbg 29999 [Ucs-Main] Retrieving schema of table 'SystemParam'
10:44:00.839 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskCompleted'
10:44:00.842 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskExtensionMetaData'
10:44:00.844 Dbg 29999 [Ucs-Main] Retrieving schema of table 'TaskStarted'
10:44:00.847 Dbg 29999 [Ucs-Main]
Callback:
  PK_CALLBACK on Id
Category:
CategoryAttribute:
CategoryRoot:
CategoryStructure:
Chat:
  PK_CHAT on Id
CoBrowseURL:
Contact:
  PK_CONTACT on Id
ContactAttribute:
Document:
  PK_DOCUMENT on Id
EmailIn:
  PK_EMAILIN on Id
EmailOut:
  PK_EMAILOUT on Id
EmRoute:
  PK_EMROUTE on Id
FieldCode:
  PK_FIELDCODE on Id
FieldValue:
IdGenerator:
IdSequences:
IndexEvent:
IntegrityReport:
Interaction:
IxnContent:
  PK_IXNCONTENT on Id
kt_ConfusionMatrix:
kt_FAQObject:
kt_Model:
kt_TestingResult:
kt_TrainingEmail:
kt_TrainingJob:
MergeHistory:
PhoneCall:
PIIGroup:
  PK_PIIGroup on Id
PIIGroupContent:
PIIRegEx:
  PK_PIIRegEx on Id
PIIRule:
  PK_PIIRule on Id
PIITestMessage:
ResourceProperty:
SchemaHistory:
ServiceCompleted:
ServiceStarted:
SNRelation:
SNRelationAction:
StandardResponse:
StateCompleted:
StateStarted:
SubTenantMetaData:
SystemParam:
TaskCompleted:
TaskStarted:
10:44:00.848 Dbg 29999 [Ucs-Main] Released connection (701818179@txn-null) to pool
10:44:00.848 Dbg 29999 [Ucs-Main] Additional Columns are allowed
10:44:00.848 Dbg 29999 [Ucs-Main] Missing Indexes are allowed
10:44:00.848 Dbg 29999 [Ucs-Main] [Arch DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.849 Dbg 29999 [Ucs-Main] [Arch DS] Acquired new connection (806882873@txn-null) from pool in 0 ms
10:44:00.850 Trc 21103 [Ucs-Main] Schema information : [id: 8.5.200.09, timestamp: 2016-07-21T22:00:00Z, version: 8.5.200.00 , description: ]
10:44:00.850 Dbg 29999 [Ucs-Main] Released connection (806882873@txn-null) to pool
10:44:00.850 Trc 29998 [Ucs-Main] Checking tables and columns on 'dapucsarchive'
10:44:00.850 Dbg 29999 [Ucs-Main] [Arch DS] Acquiring new connection from pool (queue size: 1 )
10:44:00.851 Dbg 29999 [Ucs-Main] [Arch DS] Acquired new connection (869780941@txn-null) from pool in 1 ms
10:44:00.854 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Attachment'
10:44:00.855 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Callback'
10:44:00.857 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Category'
10:44:00.858 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryAttribute'
10:44:00.860 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryRoot'
10:44:00.861 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryStructure'
10:44:00.863 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CategoryStructureData'
10:44:00.865 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Chat'
10:44:00.866 Dbg 29999 [Ucs-Main] Retrieving columns of table 'CoBrowseURL'
10:44:00.867 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Contact'
10:44:00.869 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactArchiveSynchro'
10:44:00.870 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactAttribute'
10:44:00.872 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ContactAttributeMetaData'
To be continued
Offline brendanb
Re: UCS does not want to start
« Reply #8 on: July 25, 2016, 10:44:00 AM »
continued ....
10:44:00.873 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Document'
10:44:00.874 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmailIn'
10:44:00.876 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmailOut'
10:44:00.877 Dbg 29999 [Ucs-Main] Retrieving columns of table 'EmRoute'
10:44:00.879 Dbg 29999 [Ucs-Main] Retrieving columns of table 'FieldCode'
10:44:00.880 Dbg 29999 [Ucs-Main] Retrieving columns of table 'FieldValue'
10:44:00.881 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IdGenerator'
10:44:00.883 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IdSequences'
10:44:00.884 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IndexEvent'
10:44:00.885 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IntegrityReport'
10:44:00.886 Dbg 29999 [Ucs-Main] Retrieving columns of table 'Interaction'
10:44:00.890 Dbg 29999 [Ucs-Main] Retrieving columns of table 'InteractionMergeHistory'
10:44:00.891 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnAttributeMetaData'
10:44:00.893 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnContent'
10:44:00.894 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnContentSentReceived'
10:44:00.895 Dbg 29999 [Ucs-Main] Retrieving columns of table 'IxnExtensionMetaData'
10:44:00.897 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_CategoryStatistics'
10:44:00.905 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_ConfusionMatrix'
10:44:00.915 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_EmailClassificationResult'
10:44:00.923 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_FAQObject'
10:44:00.932 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_FAQObjectCategories'
10:44:00.940 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_GlobalStatistics'
10:44:00.950 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_Model'
10:44:00.958 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TestingResult'
10:44:00.966 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingDataObject'
10:44:00.974 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingEmail'
10:44:00.982 Dbg 29999 [Ucs-Main] Retrieving columns of table 'kt_TrainingJob'
10:44:00.990 Dbg 29999 [Ucs-Main] Retrieving columns of table 'LookupTableMetaData'
10:44:00.992 Dbg 29999 [Ucs-Main] Retrieving columns of table 'MergeHistory'
10:44:00.993 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PhoneCall'
10:44:00.994 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIGroup'
10:44:00.995 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIGroupContent'
10:44:00.996 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIRegEx'
10:44:00.997 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIIRule'
10:44:00.998 Dbg 29999 [Ucs-Main] Retrieving columns of table 'PIITestMessage'
10:44:00.999 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ProfileExtensionMetaData'
10:44:01.000 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ResourceProperty'
10:44:01.001 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SchemaHistory'
10:44:01.002 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceCompleted'
10:44:01.003 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceExtensionMetaData'
10:44:01.005 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceStarted'
10:44:01.006 Dbg 29999 [Ucs-Main] Retrieving columns of table 'ServiceStartedAnonymous'
10:44:01.007 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SNRelation'
10:44:01.008 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SNRelationAction'
10:44:01.010 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponse'
10:44:01.012 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponseFavorite'
10:44:01.014 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StandardResponseUsage'
10:44:01.016 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateCompleted'
10:44:01.018 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateExtensionMetaData'
10:44:01.020 Dbg 29999 [Ucs-Main] Retrieving columns of table 'StateStarted'
10:44:01.022 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SubTenantMetaData'
10:44:01.023 Dbg 29999 [Ucs-Main] Retrieving columns of table 'SystemParam'
10:44:01.024 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskCompleted'
10:44:01.025 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskExtensionMetaData'
10:44:01.027 Dbg 29999 [Ucs-Main] Retrieving columns of table 'TaskStarted'
10:44:01.030 Dbg 29999 [Ucs-Main] Released connection (869780941@txn-null) to pool
10:44:01.030 Trc 29998 [Ucs-Main] Tables check finished
10:44:01.030 Trc 29998 [Ucs-Main] Checking indexes on 'dapucsarchive'
10:44:01.030 Dbg 29999 [Ucs-Main] [Arch DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.031 Dbg 29999 [Ucs-Main] [Arch DS] Acquired new connection (185728194@txn-null) from pool in 0 ms
10:44:01.033 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Attachment'
10:44:01.034 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Callback'
10:44:01.035 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Category'
10:44:01.036 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryAttribute'
10:44:01.037 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryRoot'
10:44:01.038 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryStructure'
10:44:01.039 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CategoryStructureData'
10:44:01.039 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Chat'
10:44:01.040 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'CoBrowseURL'
10:44:01.041 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Contact'
10:44:01.041 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactArchiveSynchro'
10:44:01.042 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactAttribute'
10:44:01.043 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ContactAttributeMetaData'
10:44:01.044 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Document'
10:44:01.044 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmailIn'
10:44:01.045 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmailOut'
10:44:01.046 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'EmRoute'
10:44:01.047 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'FieldCode'
10:44:01.048 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'FieldValue'
10:44:01.048 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IdGenerator'
10:44:01.049 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IdSequences'
10:44:01.050 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IndexEvent'
10:44:01.050 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IntegrityReport'
10:44:01.051 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'Interaction'
10:44:01.053 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'InteractionMergeHistory'
10:44:01.054 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnAttributeMetaData'
10:44:01.054 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnContent'
10:44:01.055 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnContentSentReceived'
10:44:01.056 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'IxnExtensionMetaData'
10:44:01.056 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_CategoryStatistics'
10:44:01.057 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_ConfusionMatrix'
10:44:01.058 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_EmailClassificationResult'
10:44:01.058 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_FAQObject'
10:44:01.059 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_FAQObjectCategories'
10:44:01.060 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_GlobalStatistics'
10:44:01.060 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_Model'
10:44:01.061 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TestingResult'
10:44:01.062 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingDataObject'
10:44:01.062 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingEmail'
10:44:01.063 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'kt_TrainingJob'
10:44:01.064 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'LookupTableMetaData'
10:44:01.064 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'MergeHistory'
10:44:01.065 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PhoneCall'
10:44:01.066 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIGroup'
10:44:01.066 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIGroupContent'
10:44:01.067 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIRegEx'
10:44:01.068 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIIRule'
10:44:01.069 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'PIITestMessage'
10:44:01.070 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ProfileExtensionMetaData'
10:44:01.071 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ResourceProperty'
10:44:01.072 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SchemaHistory'
10:44:01.073 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceCompleted'
10:44:01.074 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceExtensionMetaData'
10:44:01.075 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceStarted'
10:44:01.076 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'ServiceStartedAnonymous'
10:44:01.077 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SNRelation'
10:44:01.078 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SNRelationAction'
10:44:01.079 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponse'
10:44:01.080 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponseFavorite'
10:44:01.081 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StandardResponseUsage'
10:44:01.082 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateCompleted'
10:44:01.083 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateExtensionMetaData'
10:44:01.084 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'StateStarted'
10:44:01.085 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SubTenantMetaData'
10:44:01.086 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'SystemParam'
10:44:01.087 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskCompleted'
10:44:01.088 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskExtensionMetaData'
10:44:01.089 Dbg 29999 [Ucs-Main] Retrieving indexes of table 'TaskStarted'
10:44:01.090 Dbg 29999 [Ucs-Main] Released connection (185728194@txn-null) to pool
10:44:01.090 Trc 29998 [Ucs-Main] Index check finished
10:44:01.090 Dbg 29999 [Ucs-Main] Registering KPI counters on [Arch DS]  connection
10:44:01.090 Dbg 29999 [Ucs-Main] [Arch DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.091 Dbg 29999 [Ucs-Main] [Arch DS] Acquired new connection (1460297432@txn-null) from pool in 0 ms
10:44:01.107 Dbg 29999 [Ucs-Main] Released connection (1460297432@txn-null) to pool
10:44:01.107 Dbg 29999 [Ucs-Main] Data sources successfully initialized
10:44:01.108 Trc 29998 [Ucs-Main] init Persistent Managers from: ContactServerEngine.Manager.properties
10:44:01.109 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryStructureManager
10:44:01.121 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStructure
10:44:01.123 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.123 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (938693467@txn-null) from pool in 0 ms
10:44:01.127 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.127 Dbg 29999 [Ucs-Main] Column categoryparentid Mapped to ColumnMetaData CategoryParentId
10:44:01.127 Dbg 29999 [Ucs-Main] Column categorychildid Mapped to ColumnMetaData CategoryChildId
10:44:01.128 Dbg 29999 [Ucs-Main] Released connection (938693467@txn-null) to pool
10:44:01.128 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStructure
10:44:01.129 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructure#Id Mapped to column Id
10:44:01.129 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructure#CategoryParentId Mapped to column CategoryParentId
10:44:01.129 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructure#CategoryChildId Mapped to column CategoryChildId
10:44:01.133 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CategoryStructure
10:44:01.133 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.MergeHistoryManager
10:44:01.134 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.MergeHistory
10:44:01.135 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.135 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (773110290@txn-null) from pool in 0 ms
10:44:01.153 Trc 29998 [MemoryMon] Threads:29 Memory:29/58MB 50% max=2080MB
10:44:01.153 Std 21287 [Ucs-Timer] An uncaught exception occurred for thread: Thread[Ucs-Timer,5,UCS-Threads]. Exception details:
java.lang.NullPointerException
at com.genesyslab.icc.util.Server.getRunMode(Server.java:299)
at com.genesyslab.icc.util.Server.isPrimary(Server.java:308)
at com.genesyslab.icc.contactserver.ContactServerEngine$LogDSFlowRateTask.run(ContactServerEngine.java:1539)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
10:44:01.153 Std 21287 [Ucs-Timer] An uncaught exception occurred for thread: Ucs-Timer. Exception details:
10:44:01.158 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.158 Dbg 29999 [Ucs-Main] Column agentid Mapped to ColumnMetaData AgentId
10:44:01.158 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.158 Dbg 29999 [Ucs-Main] Column mergedate Mapped to ColumnMetaData MergeDate
10:44:01.158 Dbg 29999 [Ucs-Main] Column sourcecontactid Mapped to ColumnMetaData SourceContactId
10:44:01.159 Dbg 29999 [Ucs-Main] Column destinationcontactid Mapped to ColumnMetaData DestinationContactId
10:44:01.159 Dbg 29999 [Ucs-Main] Column srccontactcontent Mapped to ColumnMetaData SrcContactContent
10:44:01.159 Dbg 29999 [Ucs-Main] Column dstcontactcontent Mapped to ColumnMetaData DstContactContent
10:44:01.159 Dbg 29999 [Ucs-Main] Column validated Mapped to ColumnMetaData Validated
10:44:01.159 Dbg 29999 [Ucs-Main] Column reason Mapped to ColumnMetaData Reason
10:44:01.160 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.160 Dbg 29999 [Ucs-Main] Released connection (773110290@txn-null) to pool
10:44:01.160 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.MergeHistory
10:44:01.160 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#Id Mapped to column Id
10:44:01.160 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#TenantId Mapped to column TenantId
10:44:01.161 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#AgentId Mapped to column AgentId
10:44:01.161 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#MergeDate Mapped to column MergeDate
10:44:01.161 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#SourceContactId Mapped to column SourceContactId
10:44:01.161 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#DestinationContactId Mapped to column DestinationContactId
10:44:01.161 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#SrcContactContent Mapped to column SrcContactContent
10:44:01.162 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#DstContactContent Mapped to column DstContactContent
10:44:01.162 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#Validated Mapped to column Validated
10:44:01.162 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#Reason Mapped to column Reason
10:44:01.163 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.MergeHistory#Description Mapped to column Description
10:44:01.163 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.MergeHistory
10:44:01.163 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.SystemParamManager
10:44:01.164 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.SystemParam
10:44:01.164 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.165 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (780384769@txn-null) from pool in 1 ms
10:44:01.166 Dbg 29999 [Ucs-Main] Column keyname Mapped to ColumnMetaData KeyName
10:44:01.166 Dbg 29999 [Ucs-Main] Column value Mapped to ColumnMetaData Value
10:44:01.166 Dbg 29999 [Ucs-Main] Released connection (780384769@txn-null) to pool
10:44:01.166 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.SystemParam
10:44:01.166 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SystemParam#KeyName Mapped to column KeyName
10:44:01.167 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SystemParam#Value Mapped to column Value
10:44:01.167 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.SystemParam
10:44:01.167 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.SubTenantMetaDataManager
10:44:01.168 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData
10:44:01.169 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.169 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1985755874@txn-null) from pool in 0 ms
10:44:01.169 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.170 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.170 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.170 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.170 Dbg 29999 [Ucs-Main] Column foldername Mapped to ColumnMetaData FolderName
10:44:01.170 Dbg 29999 [Ucs-Main] Column active Mapped to ColumnMetaData Active
10:44:01.171 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.171 Dbg 29999 [Ucs-Main] Released connection (1985755874@txn-null) to pool
10:44:01.171 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData
10:44:01.171 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#Id Mapped to column Id
10:44:01.171 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#TenantId Mapped to column TenantId
10:44:01.172 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#SubTenantId Mapped to column SubTenantId
10:44:01.172 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#TheName Mapped to column TheName
10:44:01.172 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#FolderName Mapped to column FolderName
10:44:01.172 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#Active Mapped to column Active
10:44:01.172 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData#ModifiedDate Mapped to column ModifiedDate
10:44:01.173 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.SubTenantMetaData
10:44:01.173 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.FAQObjectManager
10:44:01.174 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.FAQObject
10:44:01.174 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.175 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1604771137@txn-null) from pool in 0 ms
10:44:01.175 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.176 Dbg 29999 [Ucs-Main] Column faqname Mapped to ColumnMetaData FAQName
10:44:01.176 Dbg 29999 [Ucs-Main] Column rootcategoryid Mapped to ColumnMetaData RootCategoryId
10:44:01.176 Dbg 29999 [Ucs-Main] Column creationdate Mapped to ColumnMetaData CreationDate
10:44:01.176 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.177 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.177 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.177 Dbg 29999 [Ucs-Main] Column toid Mapped to ColumnMetaData TOId
10:44:01.177 Dbg 29999 [Ucs-Main] Column modelid Mapped to ColumnMetaData ModelId
10:44:01.177 Dbg 29999 [Ucs-Main] Column info Mapped to ColumnMetaData Info
10:44:01.178 Dbg 29999 [Ucs-Main] Released connection (1604771137@txn-null) to pool
10:44:01.178 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.FAQObject
10:44:01.178 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#Id Mapped to column Id
10:44:01.178 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#TenantId Mapped to column TenantId
10:44:01.178 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#FAQName Mapped to column FAQName
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#RootCategoryId Mapped to column RootCategoryId
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#CreationDate Mapped to column CreationDate
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#OwnerId Mapped to column OwnerId
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#TenantId Mapped to column TenantId
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#Lang Mapped to column Lang
10:44:01.179 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#TOId Mapped to column TOId
10:44:01.180 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#ModelId Mapped to column ModelId
10:44:01.180 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObject#Info Mapped to column Info
10:44:01.180 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.FAQObject
10:44:01.180 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PhoneCallManager
10:44:01.186 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PhoneCall
10:44:01.187 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.187 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (2076101692@txn-null) from pool in 0 ms
10:44:01.188 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.188 Dbg 29999 [Ucs-Main] Column duration Mapped to ColumnMetaData Duration
10:44:01.189 Dbg 29999 [Ucs-Main] Column outcome Mapped to ColumnMetaData Outcome
10:44:01.189 Dbg 29999 [Ucs-Main] Column phonenumber Mapped to ColumnMetaData PhoneNumber
10:44:01.189 Dbg 29999 [Ucs-Main] Column tconnectionid Mapped to ColumnMetaData TConnectionId
10:44:01.189 Dbg 29999 [Ucs-Main] Released connection (2076101692@txn-null) to pool
10:44:01.190 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PhoneCall
10:44:01.190 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Id Mapped to column Id
10:44:01.190 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Duration Mapped to column Duration
10:44:01.190 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Outcome Mapped to column Outcome
10:44:01.190 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#PhoneNumber Mapped to column PhoneNumber
10:44:01.190 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#TConnectionId Mapped to column TConnectionId
10:44:01.191 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Id Mapped to column Id
10:44:01.191 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.191 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#TenantId Mapped to column TenantId
10:44:01.191 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.191 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#MediaTypeId Mapped to column MediaTypeId
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#TypeId Mapped to column TypeId
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#SubtypeId Mapped to column SubtypeId
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.192 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#ExternalId Mapped to column ExternalId
10:44:01.193 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.193 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#OwnerId Mapped to column OwnerId
10:44:01.193 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.193 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Status Mapped to column Status
10:44:01.193 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StartDate Mapped to column StartDate
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#ThreadId Mapped to column ThreadId
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#EndDate Mapped to column EndDate
10:44:01.194 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.195 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Timeshift Mapped to column Timeshift
10:44:01.195 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.195 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Subject Mapped to column Subject
10:44:01.195 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.195 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Text Mapped to column Text
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StructTextMimeType Mapped to column StructTextMimeType
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StructuredText Mapped to column StructuredText
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.196 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#TheComment Mapped to column TheComment
10:44:01.197 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.197 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#ThreadHash Mapped to column ThreadHash
10:44:01.197 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.197 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#CanBeParent Mapped to column CanBeParent
10:44:01.197 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IsCategoryApproved Mapped to column IsCategoryApproved
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StoppedReason Mapped to column StoppedReason
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#ContactId Mapped to column ContactId
10:44:01.198 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.199 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#ParentId Mapped to column ParentId
10:44:01.199 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.199 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#CategoryId Mapped to column CategoryId
10:44:01.199 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.199 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#Lang Mapped to column Lang
10:44:01.200 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.200 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#QueueName Mapped to column QueueName
10:44:01.200 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.200 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#CreatorAppId Mapped to column CreatorAppId
10:44:01.200 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#EntityTypeId Mapped to column EntityTypeId
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#AllAttributes Mapped to column AllAttributes
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IsSpam Mapped to column IsSpam
10:44:01.201 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.202 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#WebSafeEmailStatus Mapped to column WebSafeEmailStatus
10:44:01.202 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.202 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute1 Mapped to column StrAttribute1
10:44:01.202 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.202 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute2 Mapped to column StrAttribute2
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute3 Mapped to column StrAttribute3
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute4 Mapped to column StrAttribute4
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.203 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute5 Mapped to column StrAttribute5
10:44:01.204 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.204 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute6 Mapped to column StrAttribute6
10:44:01.204 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.204 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute7 Mapped to column StrAttribute7
10:44:01.204 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.205 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute8 Mapped to column StrAttribute8
10:44:01.205 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.205 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute9 Mapped to column StrAttribute9
10:44:01.205 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.205 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#StrAttribute10 Mapped to column StrAttribute10
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IntAttribute1 Mapped to column IntAttribute1
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IntAttribute2 Mapped to column IntAttribute2
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.206 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IntAttribute3 Mapped to column IntAttribute3
10:44:01.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IntAttribute4 Mapped to column IntAttribute4
10:44:01.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#IntAttribute5 Mapped to column IntAttribute5
10:44:01.207 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PhoneCall#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.208 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Interaction#SubTenantId Mapped to column SubTenantId
10:44:01.208 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PhoneCall
10:44:01.208 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ChatManager
10:44:01.209 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Chat
10:44:01.210 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.210 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1682645240@txn-null) from pool in 0 ms
10:44:01.211 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.211 Dbg 29999 [Ucs-Main] Column establisheddate Mapped to ColumnMetaData EstablishedDate
10:44:01.211 Dbg 29999 [Ucs-Main] Column releaseddate Mapped to ColumnMetaData ReleasedDate
10:44:01.211 Dbg 29999 [Ucs-Main] Released connection (1682645240@txn-null) to pool
10:44:01.211 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Chat
10:44:01.211 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Id Mapped to column Id
10:44:01.212 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#EstablishedDate Mapped to column EstablishedDate
10:44:01.212 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ReleasedDate Mapped to column ReleasedDate
10:44:01.212 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.217 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.218 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.219 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.220 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.221 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.222 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.223 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.223 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.223 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.223 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.224 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Chat#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.224 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Chat
10:44:01.224 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.AttachmentManager
10:44:01.225 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Attachment
10:44:01.225 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.225 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (469060185@txn-null) from pool in 0 ms
10:44:01.226 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.226 Dbg 29999 [Ucs-Main] Column documentid Mapped to ColumnMetaData DocumentId
10:44:01.227 Dbg 29999 [Ucs-Main] Column entityid Mapped to ColumnMetaData EntityId
10:44:01.227 Dbg 29999 [Ucs-Main] Column entitytypeid Mapped to ColumnMetaData EntityTypeId
10:44:01.227 Dbg 29999 [Ucs-Main] Released connection (469060185@txn-null) to pool
10:44:01.227 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Attachment
10:44:01.228 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Attachment#Id Mapped to column Id
10:44:01.272 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Attachment#DocumentId Mapped to column DocumentId
10:44:01.272 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Attachment#EntityId Mapped to column EntityId
10:44:01.272 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Attachment#EntityTypeId Mapped to column EntityTypeId
10:44:01.272 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Attachment
10:44:01.272 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ConfusionMatrixManager
10:44:01.273 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix
10:44:01.273 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.274 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1636209617@txn-null) from pool in 0 ms
10:44:01.276 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.276 Dbg 29999 [Ucs-Main] Column testingresultid Mapped to ColumnMetaData TestingResultId
10:44:01.276 Dbg 29999 [Ucs-Main] Column classificationcategoryid1 Mapped to ColumnMetaData ClassificationCategoryId1
10:44:01.276 Dbg 29999 [Ucs-Main] Column classificationcategoryid2 Mapped to ColumnMetaData ClassificationCategoryId2
10:44:01.276 Dbg 29999 [Ucs-Main] Column value Mapped to ColumnMetaData Value
10:44:01.276 Dbg 29999 [Ucs-Main] Column thesize Mapped to ColumnMetaData TheSize
10:44:01.277 Dbg 29999 [Ucs-Main] Released connection (1636209617@txn-null) to pool
10:44:01.277 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix
10:44:01.277 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#Id Mapped to column Id
10:44:01.277 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#TestingResultId Mapped to column TestingResultId
10:44:01.277 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#ClassificationCategoryId1 Mapped to column ClassificationCategoryId1
10:44:01.277 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#ClassificationCategoryId2 Mapped to column ClassificationCategoryId2
10:44:01.277 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#Value Mapped to column Value
10:44:01.278 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix#TheSize Mapped to column TheSize
10:44:01.278 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.ConfusionMatrix
10:44:01.278 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.InteractionMergeHistoryManager
10:44:01.279 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory
10:44:01.279 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.279 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1463365289@txn-null) from pool in 0 ms
10:44:01.280 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.280 Dbg 29999 [Ucs-Main] Column mergeid Mapped to ColumnMetaData MergeId
10:44:01.280 Dbg 29999 [Ucs-Main] Column interactionid Mapped to ColumnMetaData InteractionId
10:44:01.280 Dbg 29999 [Ucs-Main] Released connection (1463365289@txn-null) to pool
10:44:01.280 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory
10:44:01.281 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory#Id Mapped to column Id
10:44:01.281 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory#MergeId Mapped to column MergeId
10:44:01.281 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory#InteractionId Mapped to column InteractionId
10:44:01.281 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.InteractionMergeHistory
10:44:01.281 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryStructureDataManager
10:44:01.282 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData
10:44:01.282 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.283 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1504808685@txn-null) from pool in 0 ms
10:44:01.283 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.283 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.283 Dbg 29999 [Ucs-Main] Column objectclassname Mapped to ColumnMetaData ObjectClassName
10:44:01.284 Dbg 29999 [Ucs-Main] Column objectid Mapped to ColumnMetaData ObjectId
10:44:01.284 Dbg 29999 [Ucs-Main] Released connection (1504808685@txn-null) to pool
10:44:01.284 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData
10:44:01.284 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData#Id Mapped to column Id
10:44:01.284 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData#OwnerId Mapped to column OwnerId
10:44:01.284 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData#ObjectClassName Mapped to column ObjectClassName
10:44:01.284 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData#ObjectId Mapped to column ObjectId
10:44:01.285 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CategoryStructureData
10:44:01.285 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.TestingResultManager
10:44:01.286 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.TestingResult
10:44:01.286 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.286 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (388869091@txn-null) from pool in 0 ms
10:44:01.287 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.287 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.287 Dbg 29999 [Ucs-Main] Column creationtime Mapped to ColumnMetaData CreationTime
10:44:01.287 Dbg 29999 [Ucs-Main] Column modelid Mapped to ColumnMetaData ModelId
10:44:01.287 Dbg 29999 [Ucs-Main] Column trainingdataobjectid Mapped to ColumnMetaData TrainingDataObjectId
10:44:01.287 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.288 Dbg 29999 [Ucs-Main] Released connection (388869091@txn-null) to pool
10:44:01.288 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.TestingResult
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#Id Mapped to column Id
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#TheName Mapped to column TheName
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#CreationTime Mapped to column CreationTime
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#ModelId Mapped to column ModelId
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#TrainingDataObjectId Mapped to column TrainingDataObjectId
10:44:01.288 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TestingResult#TheType Mapped to column TheType
10:44:01.289 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.TestingResult
10:44:01.289 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.StandardResponseUsageManager
10:44:01.290 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage
10:44:01.290 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.290 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1773759241@txn-null) from pool in 0 ms
10:44:01.291 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.291 Dbg 29999 [Ucs-Main] Column standardresponseid Mapped to ColumnMetaData StandardResponseId
Offline brendanb
Re: UCS does not want to start
« Reply #9 on: July 25, 2016, 10:44:59 AM »
continued....
slab.icc.api.contactserver.persistent.StandardResponseUsage#EntityTypeId Mapped to column EntityTypeId
10:44:01.293 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage#EntityId Mapped to column EntityId
10:44:01.293 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage#ResponseType Mapped to column ResponseType
10:44:01.293 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage#PersonId Mapped to column PersonId
10:44:01.293 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage#StartDate Mapped to column StartDate
10:44:01.293 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.StandardResponseUsage
10:44:01.293 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryAttributeManager
10:44:01.294 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute
10:44:01.294 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.295 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1740909876@txn-null) from pool in 0 ms
10:44:01.302 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.303 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.303 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.303 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.303 Dbg 29999 [Ucs-Main] Column strvalue Mapped to ColumnMetaData StrValue
10:44:01.303 Dbg 29999 [Ucs-Main] Column longstrvalue Mapped to ColumnMetaData LongStrValue
10:44:01.303 Dbg 29999 [Ucs-Main] Column binvalue Mapped to ColumnMetaData BinValue
10:44:01.303 Dbg 29999 [Ucs-Main] Column intvalue Mapped to ColumnMetaData IntValue
10:44:01.304 Dbg 29999 [Ucs-Main] Column idvalue Mapped to ColumnMetaData IdValue
10:44:01.304 Dbg 29999 [Ucs-Main] Released connection (1740909876@txn-null) to pool
10:44:01.304 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute
10:44:01.304 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#Id Mapped to column Id
10:44:01.304 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#CategoryId Mapped to column CategoryId
10:44:01.304 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#TheName Mapped to column TheName
10:44:01.304 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#TheType Mapped to column TheType
10:44:01.304 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#StrValue Mapped to column StrValue
10:44:01.305 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#LongStrValue Mapped to column LongStrValue
10:44:01.305 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#BinValue Mapped to column BinValue
10:44:01.305 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#IntValue Mapped to column IntValue
10:44:01.305 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute#IdValue Mapped to column IdValue
10:44:01.305 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CategoryAttribute
10:44:01.305 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.TrainingJobManager
10:44:01.308 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.TrainingJob
10:44:01.308 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.309 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1663973984@txn-null) from pool in 0 ms
10:44:01.309 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.309 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.309 Dbg 29999 [Ucs-Main] Column starttime Mapped to ColumnMetaData StartTime
10:44:01.309 Dbg 29999 [Ucs-Main] Column trainingdataobjectid Mapped to ColumnMetaData TrainingDataObjectId
10:44:01.310 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.310 Dbg 29999 [Ucs-Main] Column errormsg Mapped to ColumnMetaData ErrorMsg
10:44:01.310 Dbg 29999 [Ucs-Main] Column modelid Mapped to ColumnMetaData ModelId
10:44:01.310 Dbg 29999 [Ucs-Main] Column modelname Mapped to ColumnMetaData ModelName
10:44:01.310 Dbg 29999 [Ucs-Main] Column testingresultid Mapped to ColumnMetaData TestingResultId
10:44:01.310 Dbg 29999 [Ucs-Main] Column testingresultname Mapped to ColumnMetaData TestingResultName
10:44:01.310 Dbg 29999 [Ucs-Main] Column engine Mapped to ColumnMetaData Engine
10:44:01.310 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.310 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.311 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.311 Dbg 29999 [Ucs-Main] Column params Mapped to ColumnMetaData Params
10:44:01.311 Dbg 29999 [Ucs-Main] Column personid Mapped to ColumnMetaData PersonId
10:44:01.311 Dbg 29999 [Ucs-Main] Column rootname Mapped to ColumnMetaData RootName
10:44:01.311 Dbg 29999 [Ucs-Main] Column advancedparams Mapped to ColumnMetaData AdvancedParams
10:44:01.311 Dbg 29999 [Ucs-Main] Column internalservice Mapped to ColumnMetaData InternalService
10:44:01.311 Dbg 29999 [Ucs-Main] Released connection (1663973984@txn-null) to pool
10:44:01.312 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.TrainingJob
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#Id Mapped to column Id
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TenantId Mapped to column TenantId
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TheType Mapped to column TheType
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#StartTime Mapped to column StartTime
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TrainingDataObjectId Mapped to column TrainingDataObjectId
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#Status Mapped to column Status
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#ErrorMsg Mapped to column ErrorMsg
10:44:01.312 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#ModelId Mapped to column ModelId
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#ModelName Mapped to column ModelName
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TestingResultId Mapped to column TestingResultId
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TestingResultName Mapped to column TestingResultName
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#Engine Mapped to column Engine
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#TenantId Mapped to column TenantId
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#Lang Mapped to column Lang
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#Params Mapped to column Params
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#PersonId Mapped to column PersonId
10:44:01.313 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#RootName Mapped to column RootName
10:44:01.314 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#AdvancedParams Mapped to column AdvancedParams
10:44:01.314 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#InternalService Mapped to column InternalService
10:44:01.314 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingJob#SubTenantId Mapped to column SubTenantId
10:44:01.314 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.TrainingJob
10:44:01.314 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ContactAttributeManager
10:44:01.315 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.ContactAttribute
10:44:01.315 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.316 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1992704346@txn-null) from pool in 0 ms
10:44:01.316 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.316 Dbg 29999 [Ucs-Main] Column contactid Mapped to ColumnMetaData ContactId
10:44:01.316 Dbg 29999 [Ucs-Main] Column attributeid Mapped to ColumnMetaData AttributeId
10:44:01.316 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.317 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.317 Dbg 29999 [Ucs-Main] Column attributename Mapped to ColumnMetaData AttributeName
10:44:01.317 Dbg 29999 [Ucs-Main] Column mimetype Mapped to ColumnMetaData MimeType
10:44:01.317 Dbg 29999 [Ucs-Main] Column strvalue Mapped to ColumnMetaData StrValue
10:44:01.317 Dbg 29999 [Ucs-Main] Column strvaluelowercase Mapped to ColumnMetaData StrValueLowerCase
10:44:01.317 Dbg 29999 [Ucs-Main] Column binvalue Mapped to ColumnMetaData BinValue
10:44:01.317 Dbg 29999 [Ucs-Main] Column datevalue Mapped to ColumnMetaData DateValue
10:44:01.317 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.318 Dbg 29999 [Ucs-Main] Column isprimary Mapped to ColumnMetaData IsPrimary
10:44:01.318 Dbg 29999 [Ucs-Main] Released connection (1992704346@txn-null) to pool
10:44:01.318 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.ContactAttribute
10:44:01.318 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#Id Mapped to column Id
10:44:01.318 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#ContactId Mapped to column ContactId
10:44:01.318 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#AttributeId Mapped to column AttributeId
10:44:01.318 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#MimeType Mapped to column MimeType
10:44:01.318 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#StrValue Mapped to column StrValue
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#StrValueLowerCase Mapped to column StrValueLowerCase
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#BinValue Mapped to column BinValue
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#Description Mapped to column Description
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#IsPrimary Mapped to column IsPrimary
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#AttributeName Mapped to column AttributeName
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#DateValue Mapped to column DateValue
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#SubTenantId Mapped to column SubTenantId
10:44:01.319 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttribute#TenantId Mapped to column TenantId
10:44:01.320 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.ContactAttribute
10:44:01.320 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.DocumentManager
10:44:01.321 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Document
10:44:01.321 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.322 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (256132011@txn-null) from pool in 1 ms
10:44:01.322 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.322 Dbg 29999 [Ucs-Main] Column mimetype Mapped to ColumnMetaData MimeType
10:44:01.322 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.323 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.323 Dbg 29999 [Ucs-Main] Column thesize Mapped to ColumnMetaData TheSize
10:44:01.323 Dbg 29999 [Ucs-Main] Column content Mapped to ColumnMetaData Content
10:44:01.323 Dbg 29999 [Ucs-Main] Released connection (256132011@txn-null) to pool
10:44:01.323 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Document
10:44:01.323 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#Id Mapped to column Id
10:44:01.323 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#MimeType Mapped to column MimeType
10:44:01.324 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#TheName Mapped to column TheName
10:44:01.324 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#Description Mapped to column Description
10:44:01.324 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#TheSize Mapped to column TheSize
10:44:01.324 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Document#Content Mapped to column Content
10:44:01.324 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Document
10:44:01.324 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryManager
10:44:01.325 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Category
10:44:01.326 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.326 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1528531456@txn-null) from pool in 0 ms
10:44:01.327 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.327 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.327 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.327 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.327 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.327 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.328 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.328 Dbg 29999 [Ucs-Main] Released connection (1528531456@txn-null) to pool
10:44:01.328 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Category
10:44:01.328 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#Id Mapped to column Id
10:44:01.328 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#TheName Mapped to column TheName
10:44:01.328 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#OwnerId Mapped to column OwnerId
10:44:01.328 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#ModifiedDate Mapped to column ModifiedDate
10:44:01.329 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#Status Mapped to column Status
10:44:01.329 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#TheType Mapped to column TheType
10:44:01.329 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Category#Description Mapped to column Description
10:44:01.329 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Category
10:44:01.329 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.SNRelationActionManager
10:44:01.330 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.SNRelationAction
10:44:01.330 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.330 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (638545826@txn-null) from pool in 0 ms
10:44:01.331 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.331 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.331 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.331 Dbg 29999 [Ucs-Main] Column socialnetwork Mapped to ColumnMetaData SocialNetwork
10:44:01.332 Dbg 29999 [Ucs-Main] Column serviceaccount Mapped to ColumnMetaData ServiceAccount
10:44:01.332 Dbg 29999 [Ucs-Main] Column action Mapped to ColumnMetaData Action
10:44:01.332 Dbg 29999 [Ucs-Main] Column actor Mapped to ColumnMetaData Actor
10:44:01.332 Dbg 29999 [Ucs-Main] Column startedat Mapped to ColumnMetaData StartedAt
10:44:01.332 Dbg 29999 [Ucs-Main] Column finishedat Mapped to ColumnMetaData FinishedAt
10:44:01.332 Dbg 29999 [Ucs-Main] Column progress Mapped to ColumnMetaData Progress
10:44:01.332 Dbg 29999 [Ucs-Main] Released connection (638545826@txn-null) to pool
10:44:01.332 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.SNRelationAction
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#Id Mapped to column Id
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#TenantId Mapped to column TenantId
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#SocialNetwork Mapped to column SocialNetwork
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#ServiceAccount Mapped to column ServiceAccount
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#Action Mapped to column Action
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#Actor Mapped to column Actor
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#StartedAt Mapped to column StartedAt
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#FinishedAt Mapped to column FinishedAt
10:44:01.333 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#Progress Mapped to column Progress
10:44:01.334 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelationAction#SubTenantId Mapped to column SubTenantId
10:44:01.334 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.SNRelationAction
10:44:01.334 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.SNRelationManager
10:44:01.335 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.SNRelation
10:44:01.335 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.335 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (2009784172@txn-null) from pool in 0 ms
10:44:01.336 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.336 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.336 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.336 Dbg 29999 [Ucs-Main] Column socialnetwork Mapped to ColumnMetaData SocialNetwork
10:44:01.336 Dbg 29999 [Ucs-Main] Column serviceaccount Mapped to ColumnMetaData ServiceAccount
10:44:01.336 Dbg 29999 [Ucs-Main] Column clientaccount Mapped to ColumnMetaData ClientAccount
10:44:01.336 Dbg 29999 [Ucs-Main] Column relation Mapped to ColumnMetaData Relation
10:44:01.336 Dbg 29999 [Ucs-Main] Column source Mapped to ColumnMetaData Source
10:44:01.337 Dbg 29999 [Ucs-Main] Column updatedat Mapped to ColumnMetaData UpdatedAt
10:44:01.337 Dbg 29999 [Ucs-Main] Released connection (2009784172@txn-null) to pool
10:44:01.337 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.SNRelation
10:44:01.337 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#Id Mapped to column Id
10:44:01.337 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#TenantId Mapped to column TenantId
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#SocialNetwork Mapped to column SocialNetwork
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#ServiceAccount Mapped to column ServiceAccount
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#ClientAccount Mapped to column ClientAccount
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#Relation Mapped to column Relation
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#Source Mapped to column Source
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#UpdatedAt Mapped to column UpdatedAt
10:44:01.340 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.SNRelation#SubTenantId Mapped to column SubTenantId
10:44:01.340 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.SNRelation
10:44:01.341 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ModelManager
10:44:01.342 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Model
10:44:01.342 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.342 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (723988328@txn-null) from pool in 0 ms
10:44:01.343 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.343 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.343 Dbg 29999 [Ucs-Main] Column model Mapped to ColumnMetaData Model
10:44:01.343 Dbg 29999 [Ucs-Main] Column creationdate Mapped to ColumnMetaData CreationDate
10:44:01.343 Dbg 29999 [Ucs-Main] Column trainingdataobjectid Mapped to ColumnMetaData TrainingDataObjectId
10:44:01.343 Dbg 29999 [Ucs-Main] Column isactive Mapped to ColumnMetaData IsActive
10:44:01.343 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.343 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.343 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.344 Dbg 29999 [Ucs-Main] Column modelsize Mapped to ColumnMetaData ModelSize
10:44:01.344 Dbg 29999 [Ucs-Main] Column rundate Mapped to ColumnMetaData RunDate
10:44:01.344 Dbg 29999 [Ucs-Main] Column rundurationsec Mapped to ColumnMetaData RunDurationSec
10:44:01.344 Dbg 29999 [Ucs-Main] Column appname Mapped to ColumnMetaData AppName
10:44:01.344 Dbg 29999 [Ucs-Main] Column engine Mapped to ColumnMetaData Engine
10:44:01.344 Dbg 29999 [Ucs-Main] Column personid Mapped to ColumnMetaData PersonId
10:44:01.344 Dbg 29999 [Ucs-Main] Column params Mapped to ColumnMetaData Params
10:44:01.344 Dbg 29999 [Ucs-Main] Column rootname Mapped to ColumnMetaData RootName
10:44:01.345 Dbg 29999 [Ucs-Main] Column advancedparams Mapped to ColumnMetaData AdvancedParams
10:44:01.345 Dbg 29999 [Ucs-Main] Released connection (723988328@txn-null) to pool
10:44:01.345 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Model
10:44:01.345 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#Id Mapped to column Id
10:44:01.345 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#TenantId Mapped to column TenantId
10:44:01.345 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#TheName Mapped to column TheName
10:44:01.345 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#Model Mapped to column Model
10:44:01.345 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#CreationDate Mapped to column CreationDate
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#TrainingDataObjectId Mapped to column TrainingDataObjectId
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#IsActive Mapped to column IsActive
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#Lang Mapped to column Lang
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#ModelSize Mapped to column ModelSize
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#RunDate Mapped to column RunDate
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#RunDurationSec Mapped to column RunDurationSec
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#AppName Mapped to column AppName
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#Engine Mapped to column Engine
10:44:01.346 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#PersonId Mapped to column PersonId
10:44:01.347 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#Params Mapped to column Params
10:44:01.347 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#RootName Mapped to column RootName
10:44:01.347 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#AdvancedParams Mapped to column AdvancedParams
10:44:01.347 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Model#SubTenantId Mapped to column SubTenantId
10:44:01.347 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Model
10:44:01.347 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.FieldValueManager
10:44:01.349 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.FieldValue
10:44:01.349 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.349 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1858009050@txn-null) from pool in 0 ms
10:44:01.350 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.350 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.350 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.350 Dbg 29999 [Ucs-Main] Column isconstant Mapped to ColumnMetaData IsConstant
10:44:01.350 Dbg 29999 [Ucs-Main] Column thecomment Mapped to ColumnMetaData TheComment
10:44:01.350 Dbg 29999 [Ucs-Main] Column strvalue Mapped to ColumnMetaData StrValue
10:44:01.350 Dbg 29999 [Ucs-Main] Column intvalue Mapped to ColumnMetaData IntValue
10:44:01.351 Dbg 29999 [Ucs-Main] Column doublevalue Mapped to ColumnMetaData DoubleValue
10:44:01.351 Dbg 29999 [Ucs-Main] Column datevalue Mapped to ColumnMetaData DateValue
10:44:01.351 Dbg 29999 [Ucs-Main] Released connection (1858009050@txn-null) to pool
10:44:01.351 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.FieldValue
10:44:01.351 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#Id Mapped to column Id
10:44:01.351 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#TheName Mapped to column TheName
10:44:01.351 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#TheType Mapped to column TheType
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#IsConstant Mapped to column IsConstant
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#TheComment Mapped to column TheComment
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#StrValue Mapped to column StrValue
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#IntValue Mapped to column IntValue
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#DoubleValue Mapped to column DoubleValue
10:44:01.352 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldValue#DateValue Mapped to column DateValue
10:44:01.352 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.FieldValue
10:44:01.352 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.IxnContentSentReceivedManager
10:44:01.353 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived
10:44:01.353 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.353 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1453627907@txn-null) from pool in 0 ms
10:44:01.354 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.354 Dbg 29999 [Ucs-Main] Column mimetype Mapped to ColumnMetaData MimeType
10:44:01.354 Dbg 29999 [Ucs-Main] Column thesize Mapped to ColumnMetaData TheSize
10:44:01.355 Dbg 29999 [Ucs-Main] Column content Mapped to ColumnMetaData Content
10:44:01.355 Dbg 29999 [Ucs-Main] Released connection (1453627907@txn-null) to pool
10:44:01.355 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived
10:44:01.355 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived#Id Mapped to column Id
10:44:01.355 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived#MimeType Mapped to column MimeType
10:44:01.355 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived#TheSize Mapped to column TheSize
10:44:01.355 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived#Content Mapped to column Content
10:44:01.355 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.IxnContentSentReceived
10:44:01.356 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.IxnContentManager
10:44:01.356 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.IxnContent
10:44:01.356 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.357 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1393495997@txn-null) from pool in 1 ms
10:44:01.357 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.357 Dbg 29999 [Ucs-Main] Column mimetype Mapped to ColumnMetaData MimeType
10:44:01.357 Dbg 29999 [Ucs-Main] Column thesize Mapped to ColumnMetaData TheSize
10:44:01.358 Dbg 29999 [Ucs-Main] Column content Mapped to ColumnMetaData Content
10:44:01.358 Dbg 29999 [Ucs-Main] Released connection (1393495997@txn-null) to pool
10:44:01.358 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.IxnContent
10:44:01.358 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContent#Id Mapped to column Id
10:44:01.358 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContent#MimeType Mapped to column MimeType
10:44:01.358 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContent#TheSize Mapped to column TheSize
10:44:01.358 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnContent#Content Mapped to column Content
10:44:01.358 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.IxnContent
10:44:01.359 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryStatisticManager
10:44:01.359 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic
10:44:01.360 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.360 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (699753134@txn-null) from pool in 0 ms
10:44:01.360 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.361 Dbg 29999 [Ucs-Main] Column testingresultid Mapped to ColumnMetaData TestingResultId
10:44:01.361 Dbg 29999 [Ucs-Main] Column confidencelevel Mapped to ColumnMetaData ConfidenceLevel
10:44:01.361 Dbg 29999 [Ucs-Main] Column classificationcategoryid Mapped to ColumnMetaData ClassificationCategoryId
10:44:01.361 Dbg 29999 [Ucs-Main] Column valuename Mapped to ColumnMetaData ValueName
10:44:01.361 Dbg 29999 [Ucs-Main] Column value Mapped to ColumnMetaData Value
10:44:01.361 Dbg 29999 [Ucs-Main] Released connection (699753134@txn-null) to pool
10:44:01.361 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#Id Mapped to column Id
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#TestingResultId Mapped to column TestingResultId
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#ConfidenceLevel Mapped to column ConfidenceLevel
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#ClassificationCategoryId Mapped to column ClassificationCategoryId
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#ValueName Mapped to column ValueName
10:44:01.362 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic#Value Mapped to column Value
10:44:01.362 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CategoryStatistic
10:44:01.362 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CoBrowseManager
10:44:01.364 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CoBrowse
10:44:01.364 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.364 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1991503323@txn-null) from pool in 0 ms
10:44:01.368 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.368 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.368 Dbg 29999 [Ucs-Main] Column entitytypeid Mapped to ColumnMetaData EntityTypeId
10:44:01.368 Dbg 29999 [Ucs-Main] Column mediatypeid Mapped to ColumnMetaData MediaTypeId
10:44:01.368 Dbg 29999 [Ucs-Main] Column typeid Mapped to ColumnMetaData TypeId
10:44:01.369 Dbg 29999 [Ucs-Main] Column subtypeid Mapped to ColumnMetaData SubtypeId
10:44:01.369 Dbg 29999 [Ucs-Main] Column externalid Mapped to ColumnMetaData ExternalId
10:44:01.369 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.369 Dbg 29999 [Ucs-Main] Column contactid Mapped to ColumnMetaData ContactId
10:44:01.369 Dbg 29999 [Ucs-Main] Column parentid Mapped to ColumnMetaData ParentId
10:44:01.369 Dbg 29999 [Ucs-Main] Column startdate Mapped to ColumnMetaData StartDate
10:44:01.369 Dbg 29999 [Ucs-Main] Column enddate Mapped to ColumnMetaData EndDate
10:44:01.369 Dbg 29999 [Ucs-Main] Column threadid Mapped to ColumnMetaData ThreadId
10:44:01.369 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.370 Dbg 29999 [Ucs-Main] Column timeshift Mapped to ColumnMetaData Timeshift
10:44:01.370 Dbg 29999 [Ucs-Main] Column subject Mapped to ColumnMetaData Subject
10:44:01.370 Dbg 29999 [Ucs-Main] Column text Mapped to ColumnMetaData Text
10:44:01.370 Dbg 29999 [Ucs-Main] Column structuredtext Mapped to ColumnMetaData StructuredText
10:44:01.370 Dbg 29999 [Ucs-Main] Column structtextmimetype Mapped to ColumnMetaData StructTextMimeType
10:44:01.370 Dbg 29999 [Ucs-Main] Column thecomment Mapped to ColumnMetaData TheComment
10:44:01.370 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.370 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.370 Dbg 29999 [Ucs-Main] Column threadhash Mapped to ColumnMetaData ThreadHash
10:44:01.371 Dbg 29999 [Ucs-Main] Column canbeparent Mapped to ColumnMetaData CanBeParent
10:44:01.371 Dbg 29999 [Ucs-Main] Column creatorappid Mapped to ColumnMetaData CreatorAppId
10:44:01.371 Dbg 29999 [Ucs-Main] Column queuename Mapped to ColumnMetaData QueueName
10:44:01.371 Dbg 29999 [Ucs-Main] Column allattributes Mapped to ColumnMetaData AllAttributes
10:44:01.371 Dbg 29999 [Ucs-Main] Column strattribute1 Mapped to ColumnMetaData StrAttribute1
10:44:01.371 Dbg 29999 [Ucs-Main] Column strattribute2 Mapped to ColumnMetaData StrAttribute2
10:44:01.371 Dbg 29999 [Ucs-Main] Column strattribute3 Mapped to ColumnMetaData StrAttribute3
10:44:01.371 Dbg 29999 [Ucs-Main] Column strattribute4 Mapped to ColumnMetaData StrAttribute4
10:44:01.371 Dbg 29999 [Ucs-Main] Column strattribute5 Mapped to ColumnMetaData StrAttribute5
10:44:01.372 Dbg 29999 [Ucs-Main] Column strattribute6 Mapped to ColumnMetaData StrAttribute6
10:44:01.372 Dbg 29999 [Ucs-Main] Column strattribute7 Mapped to ColumnMetaData StrAttribute7
10:44:01.372 Dbg 29999 [Ucs-Main] Column strattribute8 Mapped to ColumnMetaData StrAttribute8
10:44:01.372 Dbg 29999 [Ucs-Main] Column strattribute9 Mapped to ColumnMetaData StrAttribute9
10:44:01.372 Dbg 29999 [Ucs-Main] Column strattribute10 Mapped to ColumnMetaData StrAttribute10
10:44:01.372 Dbg 29999 [Ucs-Main] Column intattribute1 Mapped to ColumnMetaData IntAttribute1
10:44:01.372 Dbg 29999 [Ucs-Main] Column intattribute2 Mapped to ColumnMetaData IntAttribute2
10:44:01.372 Dbg 29999 [Ucs-Main] Column intattribute3 Mapped to ColumnMetaData IntAttribute3
10:44:01.372 Dbg 29999 [Ucs-Main] Column intattribute4 Mapped to ColumnMetaData IntAttribute4
10:44:01.373 Dbg 29999 [Ucs-Main] Column intattribute5 Mapped to ColumnMetaData IntAttribute5
10:44:01.373 Dbg 29999 [Ucs-Main] Column isspam Mapped to ColumnMetaData IsSpam
10:44:01.373 Dbg 29999 [Ucs-Main] Column websafeemailstatus Mapped to ColumnMetaData WebSafeEmailStatus
10:44:01.373 Dbg 29999 [Ucs-Main] Column iscategoryapproved Mapped to ColumnMetaData IsCategoryApproved
10:44:01.373 Dbg 29999 [Ucs-Main] Column stoppedreason Mapped to ColumnMetaData StoppedReason
10:44:01.373 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.373 Dbg 29999 [Ucs-Main] Released connection (1991503323@txn-null) to pool
10:44:01.374 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CoBrowse
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Id Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.374 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.375 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.376 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
To be continued....
Offline brendanb
« Reply #10 on: July 25, 2016, 10:47:31 AM »
continued ......
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.377 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.378 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.379 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowse#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.379 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CoBrowse
10:44:01.379 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.GlobalStatisticManager
10:44:01.380 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic
10:44:01.380 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.380 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (2144397182@txn-null) from pool in 0 ms
10:44:01.381 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.381 Dbg 29999 [Ucs-Main] Column testingresultid Mapped to ColumnMetaData TestingResultId
10:44:01.381 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.381 Dbg 29999 [Ucs-Main] Column confidencelevel Mapped to ColumnMetaData ConfidenceLevel
10:44:01.381 Dbg 29999 [Ucs-Main] Column valuename Mapped to ColumnMetaData ValueName
10:44:01.381 Dbg 29999 [Ucs-Main] Column value Mapped to ColumnMetaData Value
10:44:01.382 Dbg 29999 [Ucs-Main] Released connection (2144397182@txn-null) to pool
10:44:01.382 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#Id Mapped to column Id
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#TestingResultId Mapped to column TestingResultId
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#TheType Mapped to column TheType
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#ConfidenceLevel Mapped to column ConfidenceLevel
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#ValueName Mapped to column ValueName
10:44:01.382 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic#Value Mapped to column Value
10:44:01.383 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.GlobalStatistic
10:44:01.383 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.IxnAttributeMetaDataManager
10:44:01.384 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData
10:44:01.384 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.384 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1660815049@txn-null) from pool in 0 ms
10:44:01.385 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.385 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.385 Dbg 29999 [Ucs-Main] Column displayname Mapped to ColumnMetaData DisplayName
10:44:01.385 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.385 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.385 Dbg 29999 [Ucs-Main] Column active Mapped to ColumnMetaData Active
10:44:01.385 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.385 Dbg 29999 [Ucs-Main] Column format Mapped to ColumnMetaData Format
10:44:01.386 Dbg 29999 [Ucs-Main] Column issortable Mapped to ColumnMetaData IsSortable
10:44:01.386 Dbg 29999 [Ucs-Main] Column mappingcolumnname Mapped to ColumnMetaData MappingColumnName
10:44:01.386 Dbg 29999 [Ucs-Main] Released connection (1660815049@txn-null) to pool
10:44:01.386 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData
10:44:01.386 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#Id Mapped to column Id
10:44:01.386 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#TenantId Mapped to column TenantId
10:44:01.386 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#TheName Mapped to column TheName
10:44:01.386 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#DisplayName Mapped to column DisplayName
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#TheType Mapped to column TheType
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#Active Mapped to column Active
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#ModifiedDate Mapped to column ModifiedDate
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#Format Mapped to column Format
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#IsSortable Mapped to column IsSortable
10:44:01.387 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData#MappingColumnName Mapped to column MappingColumnName
10:44:01.387 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.IxnAttributeMetaData
10:44:01.387 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.StandardResponseFavoriteManager
10:44:01.388 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite
10:44:01.389 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.389 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (944247051@txn-null) from pool in 0 ms
10:44:01.389 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.389 Dbg 29999 [Ucs-Main] Column standardresponseid Mapped to ColumnMetaData StandardResponseId
10:44:01.390 Dbg 29999 [Ucs-Main] Column personid Mapped to ColumnMetaData PersonId
10:44:01.390 Dbg 29999 [Ucs-Main] Released connection (944247051@txn-null) to pool
10:44:01.390 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite
10:44:01.390 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite#Id Mapped to column Id
10:44:01.390 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite#StandardResponseId Mapped to column StandardResponseId
10:44:01.390 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite#PersonId Mapped to column PersonId
10:44:01.390 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.StandardResponseFavorite
10:44:01.390 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.FAQObjectCategoriesManager
10:44:01.391 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories
10:44:01.392 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.392 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1143654081@txn-null) from pool in 0 ms
10:44:01.392 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.393 Dbg 29999 [Ucs-Main] Column faqid Mapped to ColumnMetaData FAQId
10:44:01.393 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.393 Dbg 29999 [Ucs-Main] Column info Mapped to ColumnMetaData Info
10:44:01.393 Dbg 29999 [Ucs-Main] Released connection (1143654081@txn-null) to pool
10:44:01.393 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories
10:44:01.393 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories#Id Mapped to column Id
10:44:01.393 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories#FAQId Mapped to column FAQId
10:44:01.393 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories#CategoryId Mapped to column CategoryId
10:44:01.394 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories#Info Mapped to column Info
10:44:01.394 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.FAQObjectCategories
10:44:01.394 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PIIRuleManager
10:44:01.395 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PIIRule
10:44:01.395 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.395 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1339174785@txn-null) from pool in 0 ms
10:44:01.396 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.396 Dbg 29999 [Ucs-Main] Column name Mapped to ColumnMetaData Name
10:44:01.396 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.396 Dbg 29999 [Ucs-Main] Column regexid Mapped to ColumnMetaData RegExId
10:44:01.396 Dbg 29999 [Ucs-Main] Column replacementpattern Mapped to ColumnMetaData ReplacementPattern
10:44:01.396 Dbg 29999 [Ucs-Main] Column actions Mapped to ColumnMetaData Actions
10:44:01.396 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.396 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.397 Dbg 29999 [Ucs-Main] Released connection (1339174785@txn-null) to pool
10:44:01.397 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PIIRule
10:44:01.397 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#Id Mapped to column Id
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#TenantId Mapped to column TenantId
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#Name Mapped to column Name
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#Description Mapped to column Description
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#RegExId Mapped to column RegExId
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#Actions Mapped to column Actions
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#ReplacementPattern Mapped to column ReplacementPattern
10:44:01.398 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRule#SubTenantId Mapped to column SubTenantId
10:44:01.398 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PIIRule
10:44:01.398 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.TrainingDataObjectManager
10:44:01.399 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject
10:44:01.400 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.400 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1323924764@txn-null) from pool in 0 ms
10:44:01.400 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.401 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.401 Dbg 29999 [Ucs-Main] Column creationtime Mapped to ColumnMetaData CreationTime
10:44:01.401 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.401 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.401 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.401 Dbg 29999 [Ucs-Main] Column starttime Mapped to ColumnMetaData StartTime
10:44:01.401 Dbg 29999 [Ucs-Main] Column endtime Mapped to ColumnMetaData EndTime
10:44:01.401 Dbg 29999 [Ucs-Main] Column rootname Mapped to ColumnMetaData RootName
10:44:01.402 Dbg 29999 [Ucs-Main] Released connection (1323924764@txn-null) to pool
10:44:01.402 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#Id Mapped to column Id
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#TenantId Mapped to column TenantId
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#TheName Mapped to column TheName
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#CreationTime Mapped to column CreationTime
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#Lang Mapped to column Lang
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#StartTime Mapped to column StartTime
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#EndTime Mapped to column EndTime
10:44:01.402 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#RootName Mapped to column RootName
10:44:01.403 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject#SubTenantId Mapped to column SubTenantId
10:44:01.403 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.TrainingDataObject
10:44:01.403 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.InteractionManager
10:44:01.403 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.403 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.403 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (267411891@txn-null) from pool in 0 ms
10:44:01.404 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.404 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.404 Dbg 29999 [Ucs-Main] Column entitytypeid Mapped to ColumnMetaData EntityTypeId
10:44:01.404 Dbg 29999 [Ucs-Main] Column mediatypeid Mapped to ColumnMetaData MediaTypeId
10:44:01.404 Dbg 29999 [Ucs-Main] Column typeid Mapped to ColumnMetaData TypeId
10:44:01.404 Dbg 29999 [Ucs-Main] Column subtypeid Mapped to ColumnMetaData SubtypeId
10:44:01.404 Dbg 29999 [Ucs-Main] Column externalid Mapped to ColumnMetaData ExternalId
10:44:01.404 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.405 Dbg 29999 [Ucs-Main] Column contactid Mapped to ColumnMetaData ContactId
10:44:01.405 Dbg 29999 [Ucs-Main] Column parentid Mapped to ColumnMetaData ParentId
10:44:01.405 Dbg 29999 [Ucs-Main] Column startdate Mapped to ColumnMetaData StartDate
10:44:01.405 Dbg 29999 [Ucs-Main] Column enddate Mapped to ColumnMetaData EndDate
10:44:01.405 Dbg 29999 [Ucs-Main] Column threadid Mapped to ColumnMetaData ThreadId
10:44:01.405 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.405 Dbg 29999 [Ucs-Main] Column timeshift Mapped to ColumnMetaData Timeshift
10:44:01.405 Dbg 29999 [Ucs-Main] Column subject Mapped to ColumnMetaData Subject
10:44:01.405 Dbg 29999 [Ucs-Main] Column text Mapped to ColumnMetaData Text
10:44:01.405 Dbg 29999 [Ucs-Main] Column structuredtext Mapped to ColumnMetaData StructuredText
10:44:01.406 Dbg 29999 [Ucs-Main] Column structtextmimetype Mapped to ColumnMetaData StructTextMimeType
10:44:01.406 Dbg 29999 [Ucs-Main] Column thecomment Mapped to ColumnMetaData TheComment
10:44:01.406 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.406 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.406 Dbg 29999 [Ucs-Main] Column threadhash Mapped to ColumnMetaData ThreadHash
10:44:01.406 Dbg 29999 [Ucs-Main] Column canbeparent Mapped to ColumnMetaData CanBeParent
10:44:01.406 Dbg 29999 [Ucs-Main] Column creatorappid Mapped to ColumnMetaData CreatorAppId
10:44:01.406 Dbg 29999 [Ucs-Main] Column queuename Mapped to ColumnMetaData QueueName
10:44:01.406 Dbg 29999 [Ucs-Main] Column allattributes Mapped to ColumnMetaData AllAttributes
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute1 Mapped to ColumnMetaData StrAttribute1
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute2 Mapped to ColumnMetaData StrAttribute2
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute3 Mapped to ColumnMetaData StrAttribute3
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute4 Mapped to ColumnMetaData StrAttribute4
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute5 Mapped to ColumnMetaData StrAttribute5
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute6 Mapped to ColumnMetaData StrAttribute6
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute7 Mapped to ColumnMetaData StrAttribute7
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute8 Mapped to ColumnMetaData StrAttribute8
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute9 Mapped to ColumnMetaData StrAttribute9
10:44:01.407 Dbg 29999 [Ucs-Main] Column strattribute10 Mapped to ColumnMetaData StrAttribute10
10:44:01.408 Dbg 29999 [Ucs-Main] Column intattribute1 Mapped to ColumnMetaData IntAttribute1
10:44:01.408 Dbg 29999 [Ucs-Main] Column intattribute2 Mapped to ColumnMetaData IntAttribute2
10:44:01.408 Dbg 29999 [Ucs-Main] Column intattribute3 Mapped to ColumnMetaData IntAttribute3
10:44:01.408 Dbg 29999 [Ucs-Main] Column intattribute4 Mapped to ColumnMetaData IntAttribute4
10:44:01.408 Dbg 29999 [Ucs-Main] Column intattribute5 Mapped to ColumnMetaData IntAttribute5
10:44:01.408 Dbg 29999 [Ucs-Main] Column isspam Mapped to ColumnMetaData IsSpam
10:44:01.408 Dbg 29999 [Ucs-Main] Column websafeemailstatus Mapped to ColumnMetaData WebSafeEmailStatus
10:44:01.408 Dbg 29999 [Ucs-Main] Column iscategoryapproved Mapped to ColumnMetaData IsCategoryApproved
10:44:01.408 Dbg 29999 [Ucs-Main] Column stoppedreason Mapped to ColumnMetaData StoppedReason
10:44:01.408 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.409 Dbg 29999 [Ucs-Main] Released connection (267411891@txn-null) to pool
10:44:01.409 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.409 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.409 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.EmailOutManager
10:44:01.410 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.EmailOut
10:44:01.417 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.418 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (796721845@txn-null) from pool in 1 ms
10:44:01.418 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.418 Dbg 29999 [Ucs-Main] Column fromaddress Mapped to ColumnMetaData FromAddress
10:44:01.418 Dbg 29999 [Ucs-Main] Column frompersonal Mapped to ColumnMetaData FromPersonal
10:44:01.418 Dbg 29999 [Ucs-Main] Column replytoaddress Mapped to ColumnMetaData ReplyToAddress
10:44:01.419 Dbg 29999 [Ucs-Main] Column toaddresses Mapped to ColumnMetaData ToAddresses
10:44:01.419 Dbg 29999 [Ucs-Main] Column ccaddresses Mapped to ColumnMetaData CcAddresses
10:44:01.419 Dbg 29999 [Ucs-Main] Column bccaddresses Mapped to ColumnMetaData BccAddresses
10:44:01.419 Dbg 29999 [Ucs-Main] Column sentdate Mapped to ColumnMetaData SentDate
10:44:01.419 Dbg 29999 [Ucs-Main] Column forward Mapped to ColumnMetaData Forward
10:44:01.419 Dbg 29999 [Ucs-Main] Column referenceid Mapped to ColumnMetaData ReferenceId
10:44:01.419 Dbg 29999 [Ucs-Main] Column reviewerid Mapped to ColumnMetaData ReviewerId
10:44:01.419 Dbg 29999 [Ucs-Main] Column standardresponseid Mapped to ColumnMetaData StandardResponseId
10:44:01.419 Dbg 29999 [Ucs-Main] Released connection (796721845@txn-null) to pool
10:44:01.420 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.EmailOut
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Id Mapped to column Id
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#FromAddress Mapped to column FromAddress
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#FromPersonal Mapped to column FromPersonal
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ReplyToAddress Mapped to column ReplyToAddress
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ToAddresses Mapped to column ToAddresses
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#CcAddresses Mapped to column CcAddresses
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#BccAddresses Mapped to column BccAddresses
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#SentDate Mapped to column SentDate
10:44:01.420 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Forward Mapped to column Forward
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ReferenceId Mapped to column ReferenceId
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ReviewerId Mapped to column ReviewerId
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StandardResponseId Mapped to column StandardResponseId
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.421 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.422 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.423 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.424 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.425 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.426 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.426 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.426 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailOut#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.426 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.EmailOut
10:44:01.426 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PIIRegExManager
10:44:01.427 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PIIRegEx
10:44:01.427 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.427 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1717377650@txn-null) from pool in 0 ms
10:44:01.428 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.428 Dbg 29999 [Ucs-Main] Column name Mapped to ColumnMetaData Name
10:44:01.428 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.429 Dbg 29999 [Ucs-Main] Column properties Mapped to ColumnMetaData Properties
10:44:01.429 Dbg 29999 [Ucs-Main] Column expression Mapped to ColumnMetaData Expression
10:44:01.429 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.429 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.429 Dbg 29999 [Ucs-Main] Released connection (1717377650@txn-null) to pool
10:44:01.429 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PIIRegEx
10:44:01.429 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#Id Mapped to column Id
10:44:01.429 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#TenantId Mapped to column TenantId
10:44:01.430 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#Name Mapped to column Name
10:44:01.430 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#Description Mapped to column Description
10:44:01.430 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#Properties Mapped to column Properties
10:44:01.430 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#Expression Mapped to column Expression
10:44:01.430 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIRegEx#SubTenantId Mapped to column SubTenantId
10:44:01.430 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PIIRegEx
10:44:01.430 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PIIGroupContentManager
10:44:01.431 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent
10:44:01.431 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.431 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (20719285@txn-null) from pool in 0 ms
10:44:01.438 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.438 Dbg 29999 [Ucs-Main] Column piigroupid Mapped to ColumnMetaData PIIGroupId
10:44:01.438 Dbg 29999 [Ucs-Main] Column piiruleid Mapped to ColumnMetaData PIIRuleId
10:44:01.439 Dbg 29999 [Ucs-Main] Column piirulestatus Mapped to ColumnMetaData PIIRuleStatus
10:44:01.439 Dbg 29999 [Ucs-Main] Column piirulepriority Mapped to ColumnMetaData PIIRulePriority
10:44:01.439 Dbg 29999 [Ucs-Main] Released connection (20719285@txn-null) to pool
10:44:01.439 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent
10:44:01.439 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent#Id Mapped to column Id
10:44:01.439 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent#PIIGroupId Mapped to column PIIGroupId
10:44:01.439 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent#PIIRuleId Mapped to column PIIRuleId
10:44:01.439 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent#PIIRuleStatus Mapped to column PIIRuleStatus
10:44:01.439 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent#PIIRulePriority Mapped to column PIIRulePriority
10:44:01.440 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PIIGroupContent
10:44:01.440 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PIITestMessageManager
10:44:01.440 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PIITestMessage
10:44:01.441 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.441 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (303763994@txn-null) from pool in 0 ms
10:44:01.441 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.441 Dbg 29999 [Ucs-Main] Column relatedobjectid Mapped to ColumnMetaData RelatedObjectId
10:44:01.442 Dbg 29999 [Ucs-Main] Column relatedobjecttype Mapped to ColumnMetaData RelatedObjectType
10:44:01.442 Dbg 29999 [Ucs-Main] Column name Mapped to ColumnMetaData Name
10:44:01.442 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.442 Dbg 29999 [Ucs-Main] Column text Mapped to ColumnMetaData Text
10:44:01.442 Dbg 29999 [Ucs-Main] Released connection (303763994@txn-null) to pool
10:44:01.442 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PIITestMessage
10:44:01.442 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#Id Mapped to column Id
10:44:01.442 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#RelatedObjectId Mapped to column RelatedObjectId
10:44:01.442 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#Description Mapped to column Description
10:44:01.443 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#RelatedObjectType Mapped to column RelatedObjectType
10:44:01.443 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#Name Mapped to column Name
10:44:01.443 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIITestMessage#Text Mapped to column Text
10:44:01.443 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PIITestMessage
10:44:01.443 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.IndexEventManager
10:44:01.444 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.IndexEvent
10:44:01.444 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.444 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1385615419@txn-null) from pool in 0 ms
10:44:01.445 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.445 Dbg 29999 [Ucs-Main] Column indexname Mapped to ColumnMetaData IndexName
10:44:01.445 Dbg 29999 [Ucs-Main] Column eventdate Mapped to ColumnMetaData EventDate
10:44:01.445 Dbg 29999 [Ucs-Main] Column operation Mapped to ColumnMetaData Operation
10:44:01.445 Dbg 29999 [Ucs-Main] Column processedpri Mapped to ColumnMetaData ProcessedPri
10:44:01.445 Dbg 29999 [Ucs-Main] Column processedbck Mapped to ColumnMetaData ProcessedBck
10:44:01.445 Dbg 29999 [Ucs-Main] Released connection (1385615419@txn-null) to pool
10:44:01.445 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.IndexEvent
10:44:01.445 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#Id Mapped to column Id
10:44:01.446 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#IndexName Mapped to column IndexName
10:44:01.446 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#EventDate Mapped to column EventDate
10:44:01.446 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#Operation Mapped to column Operation
10:44:01.446 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#ProcessedPri Mapped to column ProcessedPri
10:44:01.446 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IndexEvent#ProcessedBck Mapped to column ProcessedBck
10:44:01.446 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.IndexEvent
10:44:01.446 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ContactManager
10:44:01.451 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Contact
10:44:01.451 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.451 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (427800296@txn-null) from pool in 0 ms
10:44:01.452 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.452 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.452 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.452 Dbg 29999 [Ucs-Main] Column isexternalresource Mapped to ColumnMetaData IsExternalResource
10:44:01.452 Dbg 29999 [Ucs-Main] Column strattribute1 Mapped to ColumnMetaData StrAttribute1
10:44:01.452 Dbg 29999 [Ucs-Main] Column strattribute2 Mapped to ColumnMetaData StrAttribute2
10:44:01.452 Dbg 29999 [Ucs-Main] Column strattribute3 Mapped to ColumnMetaData StrAttribute3
10:44:01.452 Dbg 29999 [Ucs-Main] Column strattribute4 Mapped to ColumnMetaData StrAttribute4
10:44:01.452 Dbg 29999 [Ucs-Main] Column strattribute5 Mapped to ColumnMetaData StrAttribute5
10:44:01.453 Dbg 29999 [Ucs-Main] Column strattribute6 Mapped to ColumnMetaData StrAttribute6
10:44:01.453 Dbg 29999 [Ucs-Main] Column strattribute7 Mapped to ColumnMetaData StrAttribute7
10:44:01.453 Dbg 29999 [Ucs-Main] Column strattribute8 Mapped to ColumnMetaData StrAttribute8
10:44:01.453 Dbg 29999 [Ucs-Main] Column strattribute9 Mapped to ColumnMetaData StrAttribute9
10:44:01.453 Dbg 29999 [Ucs-Main] Column strattribute10 Mapped to ColumnMetaData StrAttribute10
10:44:01.453 Dbg 29999 [Ucs-Main] Column dateattribute1 Mapped to ColumnMetaData DateAttribute1
10:44:01.453 Dbg 29999 [Ucs-Main] Column dateattribute2 Mapped to ColumnMetaData DateAttribute2
10:44:01.453 Dbg 29999 [Ucs-Main] Column dateattribute3 Mapped to ColumnMetaData DateAttribute3
10:44:01.453 Dbg 29999 [Ucs-Main] Column createddate Mapped to ColumnMetaData CreatedDate
10:44:01.453 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.454 Dbg 29999 [Ucs-Main] Column mergeid Mapped to ColumnMetaData MergeId
10:44:01.454 Dbg 29999 [Ucs-Main] Released connection (427800296@txn-null) to pool
10:44:01.454 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Contact
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#Id Mapped to column Id
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#TenantId Mapped to column TenantId
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#IsExternalResource Mapped to column IsExternalResource
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute1 Mapped to column StrAttribute1
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute2 Mapped to column StrAttribute2
10:44:01.454 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute3 Mapped to column StrAttribute3
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute4 Mapped to column StrAttribute4
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute5 Mapped to column StrAttribute5
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute6 Mapped to column StrAttribute6
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute7 Mapped to column StrAttribute7
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute8 Mapped to column StrAttribute8
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute9 Mapped to column StrAttribute9
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#StrAttribute10 Mapped to column StrAttribute10
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#DateAttribute1 Mapped to column DateAttribute1
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#DateAttribute2 Mapped to column DateAttribute2
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#DateAttribute3 Mapped to column DateAttribute3
10:44:01.455 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#CreatedDate Mapped to column CreatedDate
10:44:01.456 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#ModifiedDate Mapped to column ModifiedDate
10:44:01.456 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#MergeId Mapped to column MergeId
10:44:01.456 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Contact#SubTenantId Mapped to column SubTenantId
10:44:01.456 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Contact
to be continued.....
Offline brendanb
Re: UCS does not want to start
« Reply #11 on: July 25, 2016, 10:48:19 AM »
continued ....
10:44:01.456 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.StandardResponseManager
10:44:01.458 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.StandardResponse
10:44:01.458 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.458 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1073651091@txn-null) from pool in 0 ms
10:44:01.459 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.459 Dbg 29999 [Ucs-Main] Column standardresponseid Mapped to ColumnMetaData StandardResponseId
10:44:01.459 Dbg 29999 [Ucs-Main] Column body Mapped to ColumnMetaData Body
10:44:01.459 Dbg 29999 [Ucs-Main] Column structuredbody Mapped to ColumnMetaData StructuredBody
10:44:01.459 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.459 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.460 Dbg 29999 [Ucs-Main] Column isactive Mapped to ColumnMetaData IsActive
10:44:01.460 Dbg 29999 [Ucs-Main] Column ackusagetype Mapped to ColumnMetaData AckUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column autorespusagetype Mapped to ColumnMetaData AutoRespUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column agentdesktopusagetype Mapped to ColumnMetaData AgentDesktopUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column wssusagetype Mapped to ColumnMetaData WSSUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column emailoutusagetype Mapped to ColumnMetaData EmailOutUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column voiceautorespusagetype Mapped to ColumnMetaData VoiceAutoRespUsageType
10:44:01.460 Dbg 29999 [Ucs-Main] Column version Mapped to ColumnMetaData Version
10:44:01.460 Dbg 29999 [Ucs-Main] Column ownerid Mapped to ColumnMetaData OwnerId
10:44:01.460 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.461 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.461 Dbg 29999 [Ucs-Main] Column expirationdate Mapped to ColumnMetaData ExpirationDate
10:44:01.461 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.461 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.461 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.461 Dbg 29999 [Ucs-Main] Column subject Mapped to ColumnMetaData Subject
10:44:01.461 Dbg 29999 [Ucs-Main] Column startdate Mapped to ColumnMetaData StartDate
10:44:01.461 Dbg 29999 [Ucs-Main] Column mimetype Mapped to ColumnMetaData MimeType
10:44:01.461 Dbg 29999 [Ucs-Main] Column customfieldcodes Mapped to ColumnMetaData CustomFieldCodes
10:44:01.461 Dbg 29999 [Ucs-Main] Column arefieldcodesparsed Mapped to ColumnMetaData AreFieldCodesParsed
10:44:01.462 Dbg 29999 [Ucs-Main] Released connection (1073651091@txn-null) to pool
10:44:01.462 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.StandardResponse
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Id Mapped to column Id
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#TenantId Mapped to column TenantId
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#StandardResponseId Mapped to column StandardResponseId
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Body Mapped to column Body
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#TheName Mapped to column TheName
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Description Mapped to column Description
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#IsActive Mapped to column IsActive
10:44:01.462 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Version Mapped to column Version
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#OwnerId Mapped to column OwnerId
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#ModifiedDate Mapped to column ModifiedDate
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Status Mapped to column Status
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#ExpirationDate Mapped to column ExpirationDate
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Lang Mapped to column Lang
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#AckUsageType Mapped to column AckUsageType
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#AutoRespUsageType Mapped to column AutoRespUsageType
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#AgentDesktopUsageType Mapped to column AgentDesktopUsageType
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#WSSUsageType Mapped to column WSSUsageType
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#EmailOutUsageType Mapped to column EmailOutUsageType
10:44:01.463 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#VoiceAutoRespUsageType Mapped to column VoiceAutoRespUsageType
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#Subject Mapped to column Subject
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#StartDate Mapped to column StartDate
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#MimeType Mapped to column MimeType
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#CustomFieldCodes Mapped to column CustomFieldCodes
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#AreFieldCodesParsed Mapped to column AreFieldCodesParsed
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#StructuredBody Mapped to column StructuredBody
10:44:01.464 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.StandardResponse#SubTenantId Mapped to column SubTenantId
10:44:01.464 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.StandardResponse
10:44:01.464 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.EmRouteManager
10:44:01.465 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.EmRoute
10:44:01.466 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.466 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (736459263@txn-null) from pool in 0 ms
10:44:01.466 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.466 Dbg 29999 [Ucs-Main] Column addressestomatch Mapped to ColumnMetaData AddressesToMatch
10:44:01.467 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.467 Dbg 29999 [Ucs-Main] Column isenabled Mapped to ColumnMetaData IsEnabled
10:44:01.467 Dbg 29999 [Ucs-Main] Column matchtext Mapped to ColumnMetaData MatchText
10:44:01.467 Dbg 29999 [Ucs-Main] Column matchtextinheader Mapped to ColumnMetaData MatchTextInHeader
10:44:01.467 Dbg 29999 [Ucs-Main] Column matchtextinbody Mapped to ColumnMetaData MatchTextInBody
10:44:01.467 Dbg 29999 [Ucs-Main] Column matchtextinsubject Mapped to ColumnMetaData MatchTextInSubject
10:44:01.467 Dbg 29999 [Ucs-Main] Column theorder Mapped to ColumnMetaData TheOrder
10:44:01.467 Dbg 29999 [Ucs-Main] Column logicalrule Mapped to ColumnMetaData LogicalRule
10:44:01.467 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.467 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.468 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.468 Dbg 29999 [Ucs-Main] Released connection (736459263@txn-null) to pool
10:44:01.468 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.EmRoute
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#Id Mapped to column Id
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#TenantId Mapped to column TenantId
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#AddressesToMatch Mapped to column AddressesToMatch
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#Description Mapped to column Description
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#IsEnabled Mapped to column IsEnabled
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#MatchText Mapped to column MatchText
10:44:01.468 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#MatchTextInHeader Mapped to column MatchTextInHeader
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#MatchTextInBody Mapped to column MatchTextInBody
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#MatchTextInSubject Mapped to column MatchTextInSubject
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#TheOrder Mapped to column TheOrder
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#LogicalRule Mapped to column LogicalRule
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#Lang Mapped to column Lang
10:44:01.469 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmRoute#SubTenantId Mapped to column SubTenantId
10:44:01.469 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.EmRoute
10:44:01.469 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.EmailInManager
10:44:01.471 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.EmailIn
10:44:01.471 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.471 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (19344067@txn-null) from pool in 0 ms
10:44:01.472 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.472 Dbg 29999 [Ucs-Main] Column fromaddress Mapped to ColumnMetaData FromAddress
10:44:01.472 Dbg 29999 [Ucs-Main] Column frompersonal Mapped to ColumnMetaData FromPersonal
10:44:01.472 Dbg 29999 [Ucs-Main] Column replytoaddress Mapped to ColumnMetaData ReplyToAddress
10:44:01.472 Dbg 29999 [Ucs-Main] Column toaddresses Mapped to ColumnMetaData ToAddresses
10:44:01.472 Dbg 29999 [Ucs-Main] Column ccaddresses Mapped to ColumnMetaData CcAddresses
10:44:01.472 Dbg 29999 [Ucs-Main] Column bccaddresses Mapped to ColumnMetaData BccAddresses
10:44:01.472 Dbg 29999 [Ucs-Main] Column sentdate Mapped to ColumnMetaData SentDate
10:44:01.472 Dbg 29999 [Ucs-Main] Column mailbox Mapped to ColumnMetaData Mailbox
10:44:01.472 Dbg 29999 [Ucs-Main] Column whichrulematched Mapped to ColumnMetaData WhichRuleMatched
10:44:01.473 Dbg 29999 [Ucs-Main] Column emailoutid Mapped to ColumnMetaData EmailOutId
10:44:01.473 Dbg 29999 [Ucs-Main] Column header Mapped to ColumnMetaData Header
10:44:01.473 Dbg 29999 [Ucs-Main] Released connection (19344067@txn-null) to pool
10:44:01.473 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.EmailIn
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Id Mapped to column Id
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#FromAddress Mapped to column FromAddress
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#FromPersonal Mapped to column FromPersonal
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ReplyToAddress Mapped to column ReplyToAddress
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ToAddresses Mapped to column ToAddresses
10:44:01.473 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#CcAddresses Mapped to column CcAddresses
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#BccAddresses Mapped to column BccAddresses
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#SentDate Mapped to column SentDate
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Mailbox Mapped to column Mailbox
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#WhichRuleMatched Mapped to column WhichRuleMatched
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#EmailOutId Mapped to column EmailOutId
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Header Mapped to column Header
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.474 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.475 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.476 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.477 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailIn#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.478 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.EmailIn
10:44:01.478 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ContactAttributeMetaDataManager
10:44:01.479 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData
10:44:01.480 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.480 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (776687204@txn-null) from pool in 0 ms
10:44:01.480 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.480 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.480 Dbg 29999 [Ucs-Main] Column displayname Mapped to ColumnMetaData DisplayName
10:44:01.481 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.481 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.481 Dbg 29999 [Ucs-Main] Column active Mapped to ColumnMetaData Active
10:44:01.481 Dbg 29999 [Ucs-Main] Column modifieddate Mapped to ColumnMetaData ModifiedDate
10:44:01.481 Dbg 29999 [Ucs-Main] Column format Mapped to ColumnMetaData Format
10:44:01.481 Dbg 29999 [Ucs-Main] Column issearchable Mapped to ColumnMetaData IsSearchable
10:44:01.481 Dbg 29999 [Ucs-Main] Column iscasesensitive Mapped to ColumnMetaData IsCaseSensitive
10:44:01.481 Dbg 29999 [Ucs-Main] Column issortable Mapped to ColumnMetaData IsSortable
10:44:01.481 Dbg 29999 [Ucs-Main] Column mappingcolumnname Mapped to ColumnMetaData MappingColumnName
10:44:01.481 Dbg 29999 [Ucs-Main] Column searchlevel Mapped to ColumnMetaData SearchLevel
10:44:01.482 Dbg 29999 [Ucs-Main] Column cardinality Mapped to ColumnMetaData Cardinality
10:44:01.482 Dbg 29999 [Ucs-Main] Released connection (776687204@txn-null) to pool
10:44:01.482 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#Id Mapped to column Id
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#TenantId Mapped to column TenantId
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#TheName Mapped to column TheName
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#TheType Mapped to column TheType
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#Active Mapped to column Active
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#ModifiedDate Mapped to column ModifiedDate
10:44:01.482 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#DisplayName Mapped to column DisplayName
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#Format Mapped to column Format
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#IsSearchable Mapped to column IsSearchable
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#IsCaseSensitive Mapped to column IsCaseSensitive
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#IsSortable Mapped to column IsSortable
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#MappingColumnName Mapped to column MappingColumnName
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#SearchLevel Mapped to column SearchLevel
10:44:01.483 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData#Cardinality Mapped to column Cardinality
10:44:01.483 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.ContactAttributeMetaData
10:44:01.483 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.IntegrityReportManager
10:44:01.484 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.IntegrityReport
10:44:01.484 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.485 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (751745151@txn-null) from pool in 0 ms
10:44:01.485 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.485 Dbg 29999 [Ucs-Main] Column issueid Mapped to ColumnMetaData IssueId
10:44:01.485 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.486 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.486 Dbg 29999 [Ucs-Main] Column detectiondate Mapped to ColumnMetaData DetectionDate
10:44:01.486 Dbg 29999 [Ucs-Main] Column correctiondate Mapped to ColumnMetaData CorrectionDate
10:44:01.486 Dbg 29999 [Ucs-Main] Column firstid Mapped to ColumnMetaData FirstId
10:44:01.486 Dbg 29999 [Ucs-Main] Column secondid Mapped to ColumnMetaData SecondId
10:44:01.486 Dbg 29999 [Ucs-Main] Column status Mapped to ColumnMetaData Status
10:44:01.486 Dbg 29999 [Ucs-Main] Column sessionid Mapped to ColumnMetaData SessionId
10:44:01.486 Dbg 29999 [Ucs-Main] Released connection (751745151@txn-null) to pool
10:44:01.486 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.IntegrityReport
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#Id Mapped to column Id
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#IssueId Mapped to column IssueId
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#TenantId Mapped to column TenantId
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#DetectionDate Mapped to column DetectionDate
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#CorrectionDate Mapped to column CorrectionDate
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#FirstId Mapped to column FirstId
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#SecondId Mapped to column SecondId
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#Status Mapped to column Status
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#SessionId Mapped to column SessionId
10:44:01.487 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.IntegrityReport#SubTenantId Mapped to column SubTenantId
10:44:01.487 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.IntegrityReport
10:44:01.488 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CoBrowseURLManager
10:44:01.488 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL
10:44:01.489 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.489 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (585193008@txn-null) from pool in 0 ms
10:44:01.489 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.489 Dbg 29999 [Ucs-Main] Column interactionid Mapped to ColumnMetaData InteractionId
10:44:01.489 Dbg 29999 [Ucs-Main] Column url Mapped to ColumnMetaData URL
10:44:01.490 Dbg 29999 [Ucs-Main] Column visiteddate Mapped to ColumnMetaData VisitedDate
10:44:01.490 Dbg 29999 [Ucs-Main] Released connection (585193008@txn-null) to pool
10:44:01.490 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL
10:44:01.490 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL#Id Mapped to column Id
10:44:01.490 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL#InteractionId Mapped to column InteractionId
10:44:01.490 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL#URL Mapped to column URL
10:44:01.490 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL#VisitedDate Mapped to column VisitedDate
10:44:01.490 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CoBrowseURL
10:44:01.490 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ResourcePropertyManager
10:44:01.491 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.ResourceProperty
10:44:01.491 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.491 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (75027226@txn-null) from pool in 0 ms
10:44:01.492 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.492 Dbg 29999 [Ucs-Main] Column personid Mapped to ColumnMetaData PersonId
10:44:01.492 Dbg 29999 [Ucs-Main] Column thekey Mapped to ColumnMetaData TheKey
10:44:01.492 Dbg 29999 [Ucs-Main] Column isstring Mapped to ColumnMetaData IsString
10:44:01.492 Dbg 29999 [Ucs-Main] Column strvalue Mapped to ColumnMetaData StrValue
10:44:01.492 Dbg 29999 [Ucs-Main] Column binvalue Mapped to ColumnMetaData BinValue
10:44:01.493 Dbg 29999 [Ucs-Main] Released connection (75027226@txn-null) to pool
10:44:01.493 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.ResourceProperty
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#Id Mapped to column Id
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#PersonId Mapped to column PersonId
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#TheKey Mapped to column TheKey
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#IsString Mapped to column IsString
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#StrValue Mapped to column StrValue
10:44:01.493 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ResourceProperty#BinValue Mapped to column BinValue
10:44:01.493 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.ResourceProperty
10:44:01.493 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.EmailClassificationResultManager
10:44:01.494 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult
10:44:01.494 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.495 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1195405023@txn-null) from pool in 1 ms
10:44:01.495 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.495 Dbg 29999 [Ucs-Main] Column testingresultid Mapped to ColumnMetaData TestingResultId
10:44:01.495 Dbg 29999 [Ucs-Main] Column trainingemailid Mapped to ColumnMetaData TrainingEmailId
10:44:01.495 Dbg 29999 [Ucs-Main] Column classificationcategoryid Mapped to ColumnMetaData ClassificationCategoryId
10:44:01.495 Dbg 29999 [Ucs-Main] Column confidencelevel Mapped to ColumnMetaData ConfidenceLevel
10:44:01.496 Dbg 29999 [Ucs-Main] Released connection (1195405023@txn-null) to pool
10:44:01.496 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult
10:44:01.496 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult#Id Mapped to column Id
10:44:01.496 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult#TestingResultId Mapped to column TestingResultId
10:44:01.496 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult#TrainingEmailId Mapped to column TrainingEmailId
10:44:01.496 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult#ClassificationCategoryId Mapped to column ClassificationCategoryId
10:44:01.496 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult#ConfidenceLevel Mapped to column ConfidenceLevel
10:44:01.496 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.EmailClassificationResult
10:44:01.496 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.FieldCodeManager
10:44:01.497 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.FieldCode
10:44:01.497 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.497 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1246052888@txn-null) from pool in 0 ms
10:44:01.498 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.498 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.498 Dbg 29999 [Ucs-Main] Column value Mapped to ColumnMetaData Value
10:44:01.498 Dbg 29999 [Ucs-Main] Column thecomment Mapped to ColumnMetaData TheComment
10:44:01.498 Dbg 29999 [Ucs-Main] Released connection (1246052888@txn-null) to pool
10:44:01.498 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.FieldCode
10:44:01.499 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldCode#Id Mapped to column Id
10:44:01.499 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldCode#TheName Mapped to column TheName
10:44:01.499 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldCode#Value Mapped to column Value
10:44:01.499 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.FieldCode#TheComment Mapped to column TheComment
10:44:01.499 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.FieldCode
10:44:01.499 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.TrainingEmailManager
10:44:01.500 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.TrainingEmail
10:44:01.500 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.501 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1545082086@txn-null) from pool in 1 ms
10:44:01.501 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.501 Dbg 29999 [Ucs-Main] Column subject Mapped to ColumnMetaData Subject
10:44:01.501 Dbg 29999 [Ucs-Main] Column agentid Mapped to ColumnMetaData AgentId
10:44:01.501 Dbg 29999 [Ucs-Main] Column receiveddate Mapped to ColumnMetaData ReceivedDate
10:44:01.501 Dbg 29999 [Ucs-Main] Column text Mapped to ColumnMetaData Text
10:44:01.501 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.502 Dbg 29999 [Ucs-Main] Column trainingdataobjectid Mapped to ColumnMetaData TrainingDataObjectId
10:44:01.502 Dbg 29999 [Ucs-Main] Column responsetext Mapped to ColumnMetaData ResponseText
10:44:01.502 Dbg 29999 [Ucs-Main] Released connection (1545082086@txn-null) to pool
10:44:01.502 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.TrainingEmail
10:44:01.502 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#Id Mapped to column Id
10:44:01.502 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#Subject Mapped to column Subject
10:44:01.502 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#AgentId Mapped to column AgentId
10:44:01.502 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#ReceivedDate Mapped to column ReceivedDate
10:44:01.502 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#Text Mapped to column Text
10:44:01.503 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#CategoryId Mapped to column CategoryId
10:44:01.503 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#TrainingDataObjectId Mapped to column TrainingDataObjectId
10:44:01.503 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.TrainingEmail#ResponseText Mapped to column ResponseText
10:44:01.503 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.TrainingEmail
10:44:01.503 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.ContactArchiveSynchroManager
10:44:01.504 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro
10:44:01.504 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.504 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (1594152949@txn-null) from pool in 0 ms
10:44:01.505 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.505 Dbg 29999 [Ucs-Main] Column operationdate Mapped to ColumnMetaData OperationDate
10:44:01.505 Dbg 29999 [Ucs-Main] Column operation Mapped to ColumnMetaData Operation
10:44:01.505 Dbg 29999 [Ucs-Main] Column srccontactid Mapped to ColumnMetaData SrcContactId
10:44:01.505 Dbg 29999 [Ucs-Main] Column destinationcontactid Mapped to ColumnMetaData DestinationContactId
10:44:01.505 Dbg 29999 [Ucs-Main] Column mergeid Mapped to ColumnMetaData MergeId
10:44:01.505 Dbg 29999 [Ucs-Main] Released connection (1594152949@txn-null) to pool
10:44:01.505 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro
10:44:01.505 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#Id Mapped to column Id
10:44:01.506 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#OperationDate Mapped to column OperationDate
10:44:01.506 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#Operation Mapped to column Operation
10:44:01.506 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#SrcContactId Mapped to column SrcContactId
10:44:01.506 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#DestinationContactId Mapped to column DestinationContactId
10:44:01.506 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro#MergeId Mapped to column MergeId
10:44:01.506 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.ContactArchiveSynchro
10:44:01.506 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.PIIGroupManager
10:44:01.507 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.PIIGroup
10:44:01.507 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.507 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (2041197401@txn-null) from pool in 0 ms
10:44:01.508 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.508 Dbg 29999 [Ucs-Main] Column name Mapped to ColumnMetaData Name
10:44:01.508 Dbg 29999 [Ucs-Main] Column description Mapped to ColumnMetaData Description
10:44:01.508 Dbg 29999 [Ucs-Main] Column type Mapped to ColumnMetaData Type
10:44:01.508 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.509 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.509 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.510 Dbg 29999 [Ucs-Main] Released connection (2041197401@txn-null) to pool
10:44:01.510 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.PIIGroup
10:44:01.510 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#Id Mapped to column Id
10:44:01.510 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#TenantId Mapped to column TenantId
10:44:01.511 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#Name Mapped to column Name
10:44:01.511 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#Description Mapped to column Description
10:44:01.511 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#Type Mapped to column Type
10:44:01.511 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#CategoryId Mapped to column CategoryId
10:44:01.511 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.PIIGroup#SubTenantId Mapped to column SubTenantId
10:44:01.511 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.PIIGroup
10:44:01.512 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CategoryRootManager
10:44:01.512 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.CategoryRoot
10:44:01.512 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.513 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (219760597@txn-null) from pool in 0 ms
10:44:01.517 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.518 Dbg 29999 [Ucs-Main] Column categoryid Mapped to ColumnMetaData CategoryId
10:44:01.518 Dbg 29999 [Ucs-Main] Column thename Mapped to ColumnMetaData TheName
10:44:01.518 Dbg 29999 [Ucs-Main] Column tenantid Mapped to ColumnMetaData TenantId
10:44:01.518 Dbg 29999 [Ucs-Main] Column subtenantid Mapped to ColumnMetaData SubTenantId
10:44:01.518 Dbg 29999 [Ucs-Main] Column lang Mapped to ColumnMetaData Lang
10:44:01.518 Dbg 29999 [Ucs-Main] Released connection (219760597@txn-null) to pool
10:44:01.518 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.CategoryRoot
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#Id Mapped to column Id
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#TenantId Mapped to column TenantId
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#CategoryId Mapped to column CategoryId
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#TheName Mapped to column TheName
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#Lang Mapped to column Lang
10:44:01.519 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.CategoryRoot#SubTenantId Mapped to column SubTenantId
10:44:01.519 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.CategoryRoot
10:44:01.519 Dbg 29999 [Ucs-Main] loading com.genesyslab.icc.contactserver.persistent.CallbackManager
10:44:01.521 Dbg 29999 [Ucs-Main] Creating MetaData for Class com.genesyslab.icc.api.contactserver.persistent.Callback
10:44:01.521 Dbg 29999 [Ucs-Main] [Main DS] Acquiring new connection from pool (queue size: 1 )
10:44:01.521 Dbg 29999 [Ucs-Main] [Main DS] Acquired new connection (335866143@txn-null) from pool in 0 ms
10:44:01.522 Dbg 29999 [Ucs-Main] Column id Mapped to ColumnMetaData Id
10:44:01.522 Dbg 29999 [Ucs-Main] Column callbackstatus Mapped to ColumnMetaData CallBackStatus
10:44:01.522 Dbg 29999 [Ucs-Main] Column detaileddescription Mapped to ColumnMetaData DetailedDescription
10:44:01.522 Dbg 29999 [Ucs-Main] Column customdata Mapped to ColumnMetaData CustomData
10:44:01.523 Dbg 29999 [Ucs-Main] Column desiredresponsetype Mapped to ColumnMetaData DesiredResponseType
10:44:01.523 Dbg 29999 [Ucs-Main] Column starttime Mapped to ColumnMetaData StartTime
10:44:01.523 Dbg 29999 [Ucs-Main] Column endtime Mapped to ColumnMetaData EndTime
10:44:01.523 Dbg 29999 [Ucs-Main] Column customernumber Mapped to ColumnMetaData CustomerNumber
10:44:01.523 Dbg 29999 [Ucs-Main] Column attempts Mapped to ColumnMetaData Attempts
10:44:01.523 Dbg 29999 [Ucs-Main] Column dn Mapped to ColumnMetaData DN
10:44:01.523 Dbg 29999 [Ucs-Main] Column location Mapped to ColumnMetaData Location
10:44:01.523 Dbg 29999 [Ucs-Main] Column callbackserverid Mapped to ColumnMetaData CallbackServerID
10:44:01.523 Dbg 29999 [Ucs-Main] Column callresult Mapped to ColumnMetaData CallResult
10:44:01.524 Dbg 29999 [Ucs-Main] Column thetype Mapped to ColumnMetaData TheType
10:44:01.524 Dbg 29999 [Ucs-Main] Released connection (335866143@txn-null) to pool
10:44:01.524 Dbg 29999 [Ucs-Main] Creating Mapping for Class com.genesyslab.icc.api.contactserver.persistent.Callback
10:44:01.524 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Id Mapped to column Id
10:44:01.524 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CallBackStatus Mapped to column CallBackStatus
10:44:01.524 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#DetailedDescription Mapped to column DetailedDescription
10:44:01.524 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CustomData Mapped to column CustomData
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#DesiredResponseType Mapped to column DesiredResponseType
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StartTime Mapped to column StartTime
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#EndTime Mapped to column EndTime
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CustomerNumber Mapped to column CustomerNumber
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Attempts Mapped to column Attempts
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#DN Mapped to column DN
10:44:01.525 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Location Mapped to column Location
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CallbackServerID Mapped to column CallbackServerID
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#TheType Mapped to column TheType
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CallResult Mapped to column CallResult
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#TenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#MediaTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#TypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#SubtypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#ExternalId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#OwnerId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.526 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Status Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StartDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#ThreadId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#EndDate Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Timeshift Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Subject Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Text Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StructTextMimeType Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StructuredText Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#TheComment Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#ThreadHash Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.527 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CanBeParent Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IsCategoryApproved Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StoppedReason Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#ContactId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#ParentId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CategoryId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#Lang Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#QueueName Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#CreatorAppId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#EntityTypeId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#AllAttributes Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.528 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IsSpam Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.529 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#WebSafeEmailStatus Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.529 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.529 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.529 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute6 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute7 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute8 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute9 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#StrAttribute10 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute1 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute2 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute3 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.530 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute4 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.531 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#IntAttribute5 Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.531 Dbg 29999 [Ucs-Main] Attribute com.genesyslab.icc.api.contactserver.persistent.Callback#SubTenantId Mapped to parent class com.genesyslab.icc.api.contactserver.persistent.Interaction
10:44:01.531 Dbg 29999 [Ucs-Main] Register Persistent Manager for class com.genesyslab.icc.api.contactserver.persistent.Callback
10:44:01.543 Std 29997 [Ucs-Main] Abnormal server exit, code:-1
End
Re: UCS does not want to start
« Reply #12 on: July 25, 2016, 01:57:41 PM »
??? ??? You say this is a new installation but can see this is Genesys demosrv image...so...what are you doing exactly?
Offline n3vek7
    • ITKB
« Reply #13 on: July 25, 2016, 04:15:13 PM »
There are missing .jar files to execute jdbc connection.
[s]10:43:59.545 Std 21297 [Ucs-Main] unable to read jar file './lib/db/oracle/ucp.jar' : file not found.[/s]
10:43:59.548 Std 05200 sqljdbc4.jar. Version not available Path  ./lib/db/microsoft/sqljdbc4.jar
You need to copy them in UCS execution folders. (specified above in the code section)
I had this problem before, if UCS is using jdbc it requires those .jar to be in place.
[s]http://www.oracle.com/technetwork/database/enterprise-edition/downloads/ucp-112010-099129.html[/s]
http://www.java2s.com/Code/Jar/s/Downloadsqljdbc420jar.htm
EDIT: Nevermind, may not be related, but if you're using SQL Server, you may need to have that .jar file (sqljdbc4.jar) to be accessible.
« Last Edit: July 25, 2016, 04:44:09 PM by n3vek7 »
Offline brendanb
« Reply #14 on: July 26, 2016, 09:58:26 AM »
Hi Cagnavaro
I am busy building a demo server. The license was issued with the server name demosrv. This is not a demo image received from Genesys.
Regards
