" /> How many calls Genesys can support? - Genesys CTI User Forum
Author Topic: How many calls Genesys can support?  (Read 3652 times)
Offline Leonxxx86
« on: August 23, 2016, 05:45:34 AM »
Offline nonny
Re: How many calls Genesys can support?
« Reply #1 on: August 23, 2016, 07:20:09 AM »
As many as required.  You size it up and down accordingly with as many sites or applications required.  There are sizing documents around.  There's also the key thing about the infrastructure of the client where you deploy.
Sent from my SM-N9005 using Tapatalk
Offline Leonxxx86
« Reply #2 on: August 23, 2016, 10:59:47 PM »
So there is no licences restricted? and Also Cisco CTI rout point support up to 4500 calls, does Genesys support that many? Thanks
« Reply #3 on: August 24, 2016, 02:39:44 AM »
You can have 1 license for 1 agent but 200 PRI, so would have 199 queued calls.
As already said, all depends on infra, no software limits per-se. You can put more URS in LB.
Ask your pre-sales about this stuff for a better understanding on your environment
Offline Fra
« Reply #4 on: August 24, 2016, 10:50:01 AM »
[quote author=Leonxxx86 link=topic=9816.msg44501#msg44501 date=1471993187]
Are you asking about capacity limitations related to Genesys applications performances or commercial restrictions??
- Technically: plenty of documentation available from the vendor, no simple answer (depends on which application / suite you are referring to, interaction type, complexity of tailored solution etc etc etc). Simple answer: there is no such thing as limitation per route point.
- Licenses: of course there are license restrictions, again though, depends on whether you are referring to commercial agreements - you purchase 100 agent seats, what are you entitled to do with those - or limitations imposed by technical licenses  - you've deployed licenses for 100 IVR ports, what happens when they're all busy and the 101st call is routed to the IVR.
Adam G
« Reply #5 on: August 24, 2016, 11:26:34 AM »
[quote author=Leonxxx86 link=topic=9816.msg44456#msg44456 date=1471931134]
...as many as you pay for...
Offline vma
« Reply #6 on: August 24, 2016, 01:34:34 PM »
there are contact centers with more than 1m calls per day so as already stated: as many as you pay for :)
