" /> Genesys Call routing - Agent Skill Based - Genesys CTI User Forum
Author Topic: Genesys Call routing - Agent Skill Based  (Read 7166 times)
Offline Raja Sekhar
  • Genesys Routing Applciation developer
« on: September 26, 2016, 04:40:11 PM »
Hi Team,
I have a requirement , Where agent should always receive calls based on Level of his Skill, without considering the Call waiting time inside target.
For example, Agent 1 is in Busy status
Agent 1 Has three skills
[b]GOLD [/b]= 10
[b]SILVER[/b]=5
[b]PLATINUM[/b]=1
Agent1 is part of three  agent groups
[b]AG_GOLD_HGH [/b]
[b]AG_SILVER_MED[/b]
[b]AG_PLATINUM_LOW[/b]
Agent1 is part of three  VQ
[b]VQ_GOLD_HGH[/b]
[b]VQ_SILVER_MED[/b]
[b]VQ_PLATINUM_LOW[/b]
Calls waiting In VQ ,
[b]VQ_GOLD [/b] = 5
[b]VQ_SILVER[/b] = 10
[b]VQ_PLATINUM[/b] = 15
When Agent 1 Makes him self ready , He should receive call from [b]GOLD[/b] queue call at any cost.
I cannot consider Priority based Routing Because, in real time there is an access to users to change the level of agent skill.
For example the users may change the skill to Agent 1 as,
[b]GOLD [/b]= 1
[b]SILVER[/b]=5
[b]PLATINUM[/b]=10
so dynamically , he will belongs to,
[b]AG_GOLD_LOW [/b]
[b]AG_PLATINUM_HGH[/b]
[b]VQ_GOLD_LOW[/b]
[b]VQ_PLATINUM_HGH[/b]
When agent skill is changed in real time, and if agent becomes ready, He should receive call from [b]PLATINUM_HGH[/b] queue.
So when i am Routing a call to agent  from URS , i should even consider the other Queues to which thee agent belongs to and calls waiting in that Queue.
In-turn it Ends up like, before targeting the call to the selected agent(custom routing), i should query agent skill, ann check the calls waiting in the corresponding  queue using stats. This methodology looks very complicated .
i have seen topics 'how сhoose agent with maximum skill value' and 'Retrieve targeted agent skill'  in this forum, Bus those cases are applicable for[b] skill based routing[/b]
I can explain you more briefly, if requested. ;)
Kindly suggest me the better way of doing routing.  :)
BR/Raja
Offline Raja Sekhar
Re: Genesys Call routing - Agent Skill Based
« Reply #1 on: September 26, 2016, 04:41:32 PM »
Environment has no ORS , Rule Engine ;)
« Reply #2 on: September 26, 2016, 05:22:24 PM »
Your concepts are wrong to start with, this is priority routing. Skills does not determine routing priority, skills only tells which users match which conditions. Even if you change the skills what does it has to do with the VIP call being answered? Priority Sir, only way
Offline Raja Sekhar
« Reply #3 on: September 26, 2016, 05:36:33 PM »
Agreed.
In my scenario, i have two URS, and it is proved that when we use two diff stat servers, in p2p environment, priority routing s not recommended.
I did tried configuring a common statserver for two sipservers and urs used the same.to park call to agents.
In this scenario, i faced agent being reserved by both urs at same at same time.
Resulted n agents getting two calls at a time.
To solve this, i have configured different transition_time, verification time n both the URS.
So, in my case priority routing will not work.
Can u suggest a bettet way.
Offline Tambo
« Reply #4 on: September 26, 2016, 10:57:39 PM »
Queue priorities overrule skill level, if you want gold asnswered first always have gold queue priority highest even by 1 . Lowest queue priority will queue for 10 hrs or more if that's what you want. Agent skill could be the lowest but will always get gold first.
1 routing stat server should work best.
Offline terry
« Reply #5 on: September 27, 2016, 01:48:31 AM »
Basically it is like Tambo described.
You can target agent with GOLD=10 with priority 10, GOLD=9 with priority 9, GOLD=8 with priority 8, etc.
The same about SOLVER and PLATINUM.
When some agent becomes ready the first call (with highest priority) will be one waiting this agent's maximum skill.
Multiple statservers and priorities are not recommended in situations when one URS can targets the same agents through different statservers.
In all other cases there are no problems with it.
If both URSes reserves the same agent at the same time most likely agent reservation is not properly configured. Just check do both URSes uses the same tserver for reservation. If yes just check tserver logs why it reserves the same agent twice.
Also there is a shortcut to using pattern "wait higher skill with higher priority". Instead of targeting call to GOLD=10 with priority 10, 9 with priority 9, etc.
you can targets call to any agents with skill GOLD just before doing that call SetIdealAgent("GOLD=10").
Offline Raja Sekhar
« Reply #6 on: September 27, 2016, 07:08:20 AM »
Hi All,
Thank You very much for your replies.
@Terry : We have two Diff URS mapped to two diff SIP servers, A common stat server is used for routing, results in agent of one switch reserved by both URS at same time when call volume is so high. Due to which we have set different Default options for Both the URS.
Different values for the Options Like transition_time,Verification_time, Has completely  reduced the issue of multiple calls landing to agent.
[b]SetIdealAgent[/b] is some thing i have to explore and will come back to you.
@Tambo and @cavagnaro : If I had one URS mapped with one SIP, I would have used Queue priority Routing , But two Diff URS mapped to two diff SIP servers , ISCC communication between SIP servers , and using Common statserver for Routing interactions. Priority routing doesn work in when we use multiple URS , which i came to know through this forum.
can Pseudo statistics can help me in this scenario?
Offline Tambo
« Reply #7 on: September 27, 2016, 08:56:59 AM »
why dont you use LDS to load balance through both URS that would help to stop the racing condition you have.
do you really need 2 URS is your volumes that high ??
Offline Fra
« Reply #8 on: September 27, 2016, 09:12:07 AM »
yeah, what do you mean exactly with call volume being so high?
Offline Raja Sekhar
« Reply #9 on: September 27, 2016, 09:21:50 AM »
@Tambo : We are using URS for Voice inbound and Outbound together in two different sites , The Business requirements and strategies loaded are totally Different. If we are considering  LDS for this Routing, requires architecture change.So finding better way to achieve it without touching architecture.
@Fra : The number of interactions excuted by both the URS per second in different sites are large in number, i.e. the call volume reaching the sip server is so high, results in Racing condition at times.
Offline Fra
« Reply #10 on: September 27, 2016, 09:40:32 AM »
Can you quantify in CAPS what 'high' means for you?
Offline Raja Sekhar
« Reply #11 on: September 27, 2016, 11:11:29 AM »
'CAPS' is 25.
Offline Tambo
« Reply #12 on: September 27, 2016, 11:44:11 AM »
ok so 25 is very high in my opinion so your infrastructure and network must be good.
are you talking about call routing priorities for inbound only?
are you doing full call blending with agents on inbound and outbound at same time?
Offline Raja Sekhar
« Reply #13 on: September 27, 2016, 01:22:18 PM »
@Tambo :  We would like to prioritize the calls only for inbound agents, which is achievable through strategies loaded to RP.
Offline Tambo
« Reply #14 on: September 27, 2016, 02:31:04 PM »
i still don't get why you can't use queue priorities though as it accurately describes your routing.
make a list object up with all of your queues in there and assign priorities.
