" /> CCPulse StatServer - Genesys CTI User Forum
Author Topic: CCPulse StatServer  (Read 4619 times)
Martin
CCPulse StatServer
I want to know your opinion about this .
We experienced some problems with our StatServer who feed CCPulse for 40 agents and 5 administrators. Some times the Server is running at 100 % of cpu use and it becomes unable to reply. StatServer is alone on the server a Dell powerEdge 2300, 2 cpu P3 500 Mhz etcc
I have an idea of our problems but i'm not sure.
1 The first thing, all statistics in our templates in CCPulse have a notification frequency of 2 seconds. I think it's too short.
2 We put the option Time profile(last 30 minutes) on StatServer and it's seems it creates a overload on the server.
If you have any suggestions for our problem with StatServer
thanks
Stefan C
CCPulse StatServer
  • Hi Martin,
    Is the StatServer only used for CCPulse users ? If so you are fine.
    Turn of logging for the statserver, this really helps.
    What version of Genesys are you running ?
    With version 5.1.5 StatServer performance has greatly improved.
    Regards,
    Stefan
    Stefan C
    CCPulse StatServer
  • The 2nd processor is not going to help much, StatServer is not multithreaded.
    Stefan
