" /> Help, I can not find IVR logs - Genesys CTI User Forum
Author Topic: Help, I can not find IVR logs  (Read 2120 times)
Offline ManuPlatform
« on: March 28, 2017, 09:59:11 PM »
My IVR initially generated a log file on the path:
Inetpub / wwwroot / MyIVR / Log / log.txt
But, at the moment it does not generate it anymore.
Where can I configure the Log path?
Is there any service to restart, to solve this?
Thank
Re: Help, I can not find IVR logs
« Reply #1 on: March 28, 2017, 10:53:53 PM »
Which IVR?
GVP? 7.6 or 8.x? VoiceGenie?
You need to be more specific and usually logs are configured via SCI or CME
Offline Amy
« Reply #2 on: March 29, 2017, 03:00:28 PM »
Hi ,
if you mean vocal application(vxml) I don't think you can configure a log for those application, their logs are being wrote in MCP log.I hope that helps  :)
« Reply #3 on: March 29, 2017, 04:39:55 PM »
[quote author=cavagnaro link=topic=10241.msg46475#msg46475 date=1490741633]
Which IVR?
Good day dear,
I'm using Genesys Studio 7.6, on the Genesys Voice Platform, I used the EMPS server to make that configuration, but 2 days ago I stopped creating logs. What could it be?
regards.
« Reply #4 on: March 29, 2017, 04:47:39 PM »
[quote author=CCS link=topic=10241.msg46483#msg46483 date=1490799628]
Hi ,
good day friend,
Ivr uses ASP in vxml and it works with IIS, it leaves a log record, using the 'Log' block or the VBscript 'call setLog (0,' call log ')' command, but 2 days ago I found the reason for it
regards
