" /> German Umlaut Incorrectly Displaying - Genesys CTI User Forum
Author Topic: German Umlaut Incorrectly Displaying  (Read 2568 times)
Offline tomparker12
« on: December 11, 2017, 05:24:28 PM »
Hi there,
I'm trying to get Umlauts to display correctly in an environment. Configuration Server 8.5 is installed and is configured as UTF-8 and allowed for mixed encoding.
When i put the umlaut into the Genesys Person Profile, everything looks fine and renders/ displays fine, but shortly after it reverts to a diamon or a funky character!
Anyone been able to implement this without any issues/ or any advise on how to progress?
Offline tomparker12
RESOLVED | German Umlaut Incorrectly Displaying
« Reply #1 on: December 21, 2017, 09:31:43 AM »
Issue appears to be with CME, applying Umlauts via GA/ GAX successfully displays UTF-8
Re: German Umlaut Incorrectly Displaying
« Reply #2 on: December 21, 2017, 05:10:58 PM »
You using latest CME version?
Offline Janis
« Reply #3 on: December 21, 2017, 09:09:37 PM »
I have same. Do not think that CME will support UTF-8.
Offline GregorV
« Reply #4 on: January 31, 2018, 08:36:51 AM »
did you try Configuration-Server options [b]local[/b] and [b]langid[/b] ?
With [b]locale=de_DE.utf8[/b] and [b]langid=1033[/b] it work for me.
But I know that this is dependent also from language settings in the OS and/or database
Good luck
Gregor
« Reply #5 on: January 31, 2018, 11:33:15 AM »
You have to start and install the Configuration Server as multilanguage - read and follow the documentation
