" /> May I use same ID for Detect Event and Cancel Event in SCI? (SCS 7.1) - Genesys CTI User Forum
Author Topic: May I use same ID for Detect Event and Cancel Event in SCI? (SCS 7.1)  (Read 2485 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi all, hope everything's fine around there.
When creating/configuring an Alarm Condition in SCI, may I use the same code for both Detect Event and Cancel Event parameters on a single condition? or is mandatory to use two distinct codes?
Best regards,
Gef.
« Last Edit: March 19, 2020, 03:18:18 PM by Gef Buneri »
Re: May I use same ID for Detect Event and Cancel Event in SCI? (SCS 7.1)
« Reply #1 on: March 19, 2020, 07:17:25 PM »
Hey Gef! How are you doing? Hope everything fine in Italy which has been more heavy impacted...Stay safe
About the ID, no, need to be a different one or a timer
Offline Gef Buneri
« Reply #2 on: March 20, 2020, 12:07:24 AM »
Hi Cav. Here in Italy the situation is quite bad ad the moment, especially in the north of the country; Since 7 of March I'm stuck at home due to the risk of contagion moving outside. My luck I can work from home and I live in a "low precence" area. Hope everything will get better soon for everyone, but I fear thhis will need still 1 or 2 more months if people will respect the rules. In your country is everything allright?
Going back to the question, I mean in SCI I have a predefined number of codes of a specific type I can use from URS (015-22001~22020), but if I have to assign 2 codes, in fact I can create only 10 conditions (2 codes start/clean each). My target is to have all 20 codes to create 20 different reactions. I already assign a 1hour cooldown time for the alarm.
« Reply #3 on: March 20, 2020, 06:31:09 PM »
Well no, because when SCS receives the event, how can it know which to trigger?
Also, custom codes are usually to signal a problem or a specific event... Like a DB problem for each call... How can a different call clean the previous error?
Here in Brazil things are quite slow... Which worries me. At Peru I was there two weeks ago and was able to leave just before the borders were closed. There the action plan is much faster and hope will help to prevent. I also see a month task, will not be fast... Stay safe there.
Offline Gef Buneri
« Reply #4 on: March 25, 2020, 09:18:48 AM »
Hi Cav. Cancel Code can be blank, leaving the cancelation only on timeout? (the goal is still to have as many different available conditions as possible).
I agree... readiness is fundamental in the management of this problem, but sadly in most cases everithing seems to move really slowly on both sides, management and people. Stay safe too.
« Reply #5 on: March 25, 2020, 06:43:54 PM »
[quote author=Gef Buneri link=topic=11567.msg52717#msg52717 date=1585127928]
Yes, that is what I do, and store them at DB so I can check later
Be safe and hope everything is ok
Offline Gef Buneri
« Reply #6 on: March 25, 2020, 08:00:19 PM »
Ok, got it; thank you very much.
Good luck for everything.
Offline genesysguru
    • Genesys Guru Blog
« Reply #7 on: March 26, 2020, 11:39:04 AM »
I've written Kafka Producers which uses the PDSK so that I can publish events (such as Log Server messages) onto topics and then consume them for analysis purposes in microservices.
Regards
Craig
