" /> 186-Set is in target state - Genesys CTI User Forum
Author Topic: 186-Set is in target state  (Read 4701 times)
Offline eferreyra
  • Pachu
« on: November 20, 2007, 05:50:49 PM »
Any clue about why this error can happen or what that means in the Login of an Agent, using T-Library Activex Toolkit 7.2
Thanks.
Offline catanirex
Re: 186-Set is in target state
« Reply #1 on: November 21, 2007, 07:56:40 AM »
Check the physical telephone, pick up the receiver and place it on the table.
Try again.
« Reply #2 on: December 14, 2007, 10:26:38 AM »
Here are two possibilities as I see it:
1. another agent logged into the same DN
2. your phone was off the hook
Best regards,
