" /> WFM 6.1 crashed IE5? - Genesys CTI User Forum
Author Topic: WFM 6.1 crashed IE5?  (Read 11690 times)
Rhonda
Hi there,
Anyone with solution?
I can't activate IE5 at all after installing WFM client onto the NT4 machine. Tried reinstalling IE5 but still failed to get it to work.
Appreciate some lights on this. THanks.
Rhonda
RY
  • What version of WFM are you using?6.1.00?
    RY
  • (Sorry about a duplicate post)
    We were using WFM 6.0 without any problems on NT and we are about to start evaluating 6.1.xxx from next week.
    Can you please describe the problem in more detail, because I am now concerned about our system environment with IE built into Windows NT system, I think this problem might affect other parts of the operating system besides IE.
    Thanks!
    Jeff
  • I had a similar problem with our installation as well. I am looking into the problem right now. I think it has something to do with one of the dlls that workforce manager replaces during the setup.
  • I have looked through release notes for 6.1; however, it does not mention about IE crashing after installation.
    I also looked through 6.0 and 5.1.6 release notes, but it does not mention anything.
    Did you experience this problem on every machine you tried installing WFM on, or on a particular one only? In that case, what kind of machine is it?
    We have not yet started evaluating WFM 6.1; however, I am very apprehensive about installing the product on the machine now. Do you need to reinstall NT to resolve the problem? Were you able to resolve the problem?
    I would really appreciate any information you could pass my way.
    Peter
  • FWIW I've installed WFM 6.1 on a Windows 2000 machine with IE 5.5. No problems were experienced with IE or WFM after the install. Both ran fine.
    Rhonda
  • Hi RY,
    yes, I am having WFM 6.1. I got some MDAC files, Jet.. files, and then WFM6.1 installed onto my NT4 machine. My IE5 was previously working fine, but I can't activate it at all after that.
    Rhonda
    Rhonda
  • I understand that WFM 6.1 is the version compliant with W2K. I have not try it on W2K yet, but I know in that platform the crystal report within WFM6.1 would not export report data correctly. Somehow, my trainer simulated the problem when trying to export data to Excel 2000, and an empty file was generated instead.
    also trying running rotating schedules using [A],[B],[C] settings (can't remember the tab now), it didn't work. Genesys support working on it.
    Rhonda
  • All 10 of my WFM NT clients can't run IE now. I am not sure how this can be resolved or what effort needed...still searching for it.
    Not sure how WFM 5 works, but I am not impressed by WFM6.1. My users are complaining that many features are not there, and that they have to workaround some of the inconvenience. And here I am, looking for fixes for some of the bugs found...
    Rhonda
    « Reply #9 on: January 01, 1970, 12:00:00 AM »
  • did U install MDAC files or Jet... files. I loaded these 2 in before installing WFM. Could be that they overrides some of the window files.
    If this is the case, I am going to let my Genesys consultant hear some music...:)
    « Reply #10 on: January 01, 1970, 12:00:00 AM »
  • Rhonda,
    trying running the following on your system:
    (THIS COMMAND IS CASE SENSITIVE)
    rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
    This will check your internet explorer and tell you if it can be repaired.
    here is the list of DLL files used by IE (it is huge)
    it applies to:
    Microsoft Internet Explorer version 5 for Windows 95
    Microsoft Internet Explorer version 5 for Windows 98
    Microsoft Internet Explorer version 5 for Windows NT 3.51
    Microsoft Internet Explorer version 5 for Windows NT 4.0
    Microsoft Internet Explorer version 5.5 for Windows 2000
    Windows NT (Intel)
    File Verification
    File name Version
    Actxprxy.dll 5.00.2014.0200
    Advpack.dll 5.00.2014.0200
    Asctrls.ocx 5.00.2014.0200
    Bindfile.dll 5.00.2014.0200
    Browselc.dll 5.00.2014.0200
    Browseui.dll 5.00.2014.0200
    C_20866.nls
    C_28592.nls
    C_28595.nls
    Cabinet.dll 1.0.601.4
    Cdfview.dll 5.00.2014.0200
    Certmgr.msc
    Ckcnv.exe 5.00.2014.0200
    Comcat.dll 4.71.1441.1
    Comctl32.dll 5.80.2014.0200
    Corpol.dll 1998.3.6045.0
    Crypt32.dll 5.131.1877.3
    Cryptdlg.dll 5.0.1555.1
    Cryptext.dll 5.131.1877.3
    Cryptnet.dll 5.131.1877.3
    Cryptui.dll 5.131.1877.3
    Digest.dll 5.00.2014.0200
    Dispex.dll 5.0.0.3128
    Dssbase.dll 5.0.1877.3
    Dsssig.exe 5.0.1877.3
    Es.dll 1998.9.1001.0
    Esenu.dll 1998.9.1001.0
    Esserver.exe 1998.9.1001.0
    Esshared.dll 1998.9.1001.0
    Estier2.dll 1998.9.1001.0
    Grpconv.exe 5.0.1946.1
    Hlink.dll 5.0.0.2278
    Homepage.inf
    Icmfilter.dll 1.0.0.1
    Ie4uinit.exe 5.00.2014.0200
    Iedkcs32.dll 15.00.2014.0200
    Iepeers.dll 5.00.2014.0200
    Iernonce.dll 5.00.2014.0200
    Iesetup.dll 5.00.2014.0200
    Ieuinit.inf
    Imgutil.dll 5.00.2014.0200
    Inetcpl.cpl 5.00.2014.0200
    Inetcplc.dll 5.00.2014.0200
    Initpki.dll 5.131.1877.3
    Inseng.dll 5.00.2014.0200
    Jobexec.dll 5.0.0.1
    Jscript.dll 5.0.0.3511
    Jsproxy.dll 5.00.2014.0200
    Licmgr10.dll 5.00.2014.0200
    Loadwc.exe 5.00.2014.0200
    Mlang.dll 5.00.2014.0200
    Mmefxe.ocx 6.0.6.1105
    Mmutilse.dll 6.0.6.1105
    Mobsync.dll 5.00.2014.0200
    Mobsync.exe 5.00.2014.0200
    Msapsspc.dll 5.0.0.7729
    Mscat32.dll 5.131.1877.3
    Mshta.exe 5.00.2014.0200
    Mshtml.dll 5.00.2014.0200
    Mshtml.tlb 5.00.2014.0200
    Mshtmled.dll 5.00.2014.0200
    Mshtmler.dll 5.00.2014.0200
    Msident.dll 5.00.2014.0200
    Msidle.dll 5.00.2014.0200
    Msidntld.dll 5.00.2014.0200
    Msieftp.dll 5.00.2014.0200
    Msls31.dll 3.10.337.0
    Msnsspc.dll 6.0.0.7753
    Msoss.dll 5.131.1877.3
    Msr2c.dll 1.0.4211.0
    Msr2cenu.dll 1.0.4211.0
    Msrating.dll 5.00.2014.0200
    Mssign32.dll 5.131.1877.3
    Mssip32.dll 5.131.1877.3
    Msxml.dll 5.00.2014.0200
    Occache.dll 5.00.2014.0200
    Plugin.ocx 5.00.2014.0200
    Pngfilt.dll 5.00.2014.0200
    Proctexe.ocx 6.0.6.1105
    Psbase.dll 5.0.1877.3
    Pstorec.dll 5.0.1877.3
    Pstorerc.dll 5.0.1877.3
    Pstores.exe 5.0.1877.3
    Regsvr32.exe 5.0.1585.1
    Rsabase.dll 5.0.1877.3
    Rsaci.rat
    Rsasig.dll 5.0.1877.3
    Schannel.dll 4.84.1900.1877
    Scrobj.dll 1.0.0.3511
    Scrrun.dll 5.0.0.3511
    Sendmail.dll 5.00.2014.0200
    Sens.exe 5.00.2014.0200
    Sensapi.dll 5.00.2014.0200
    Senscfg.dll 5.00.2014.0200
    Setupapi.dll 4.0.1381.10
    Setupwbv.dll 5.00.2014.0200
    Shdoc401.dll 5.00.2014.0200
    Shdoclc.dll 5.00.2014.0200
    Shdocvw.dll 5.00.2014.0200
    Shfolder.dll 5.00.2014.0200
    Shlwapi.dll 5.00.2014.0200
    Softpub.dll 5.131.1877.3
    T2embed.dll 0.2.0.69
    Tdc.ocx 1.2.0.31
    Thumbvw.dll 5.00.2014.0200
    Url.dll 5.00.2014.0200
    Urlmon.dll 5.00.2014.0200
    Userstub.exe 5.00.2014.0200
    Vbscript.dll 5.0.0.3511
    Webcheck.dll 5.00.2014.0200
    Wininet.dll 5.00.2014.0200
    Wintrust.dll 5.131.1877.3
    Wldap32.dll 5.0.1579.0
    Wshext.dll 5.0.531.7
    Wshom.ocx 5.0.531.7
    Xenroll.dll 5.131.1877.3
    File Registration
    Actxprxy.dll
    Asctrls.ocx
    Browseui.dll
    Cdfview.dll
    Comcat.dll
    Comctl32.dll
    Corpol.dll
    Cryptdlg.dll
    Digest.dll
    Dispex.dll
    Dssbase.dll
    Hlink.dll
    Icmfilter.dll
    Iepeers.dll
    Iesetup.dll
    Imgutil.dll
    Inetcpl.cpl
    Initpki.dll
    Inseng.dll
    Jscript.dll
    Licmgr10.dll
    Mlang.dll
    Mmefxe.ocx
    Mobsync.dll
    Msapsspc.dll
    Mshta.exe
    Mshtml.dll
    Mshtmled.dll
    Msident.dll
    Msieftp.dll
    Msnsspc.dll
    Msr2c.dll
    Msrating.dll
    Msxml.dll
    Occache.dll
    Oleaut32.dll
    Plugin.ocx
    Pngfilt.dll
    Proctexe.ocx
    Pstores.exe
    Rsabase.dll
    Scrobj.dll
    Sendmail.dll
    Setupwbv.dll
    Shdoc401.dll
    Shdocvw.dll
    Tdc.ocx
    Thumbvw.dll
    Urlmon.dll
    Vbscript.dll
    Webcheck.dll
    Wininet.dll
    Windows NT (Alpha)
    File Verification
    File name Version
    Atl.dll 2.0.7024.0
    C_20866.nls
    C_28592.nls
    C_28595.nls
    Certmgr.msc
    Corpol.dll 1998.3.6025.0
    Homepage.inf
    Ieuinit.inf
    Jobexec.dll 5.0.0.1
    Mmefxe.ocx 2.0.0.7310
    Mmutilse.dll 2.0.0.7310
    Rsaci.rat
    Tdc.ocx 1.2.0.31
    Wshom.ocx 5.0.531.7
    File Registration
    Actxprxy.dll
    Asctrls.ocx
    Atl.dll
    Browseui.dll
    Cdfview.dll
    Comcat.dll
    Comctl32.dll
    Corpol.dll
    Cryptdlg.dll
    Digest.dll
    Dispex.dll
    Dssbase.dll
    Hlink.dll
    Iepeers.dll
    Iesetup.dll
    Imgutil.dll
    Inetcpl.cpl
    Initpki.dll
    Inseng.dll
    Jscript.dll
    Licmgr10.dll
    Mlang.dll
    Mmefxe.ocx
    Mobsync.dll
    Msapsspc.dll
    Mshta.exe
    Mshtml.dll
    Mshtmled.dll
    Msident.dll
    Msieftp.dll
    Msnsspc.dll
    Msrating.dll
    Msxml.dll
    Occache.dll
    Oleaut32.dll
    Plugin.ocx
    Pngfilt.dll
    Pstores.exe
    Rsabase.dll
    Scrobj.dll
    Sendmail.dll
    Setupwbv.dll
    Shdoc401.dll
    Shdocvw.dll
    Tdc.ocx
    Thumbvw.dll
    Urlmon.dll
    Vbscript.dll
    Webcheck.dll
    Wininet.dll
    Rhonda
    « Reply #11 on: January 01, 1970, 12:00:00 AM »
  • Thanks Vic,
    will try it out. Thanks for your help.
    « Reply #12 on: January 01, 1970, 12:00:00 AM »
  • Did it work?
    Naoki
    « Reply #13 on: January 01, 1970, 12:00:00 AM »
  • Vic, Rhonda:
    have you tried using ICD with WFM? I want to propose to my company to use workforce manager to create schedules and then combine it with inbound routing, but I cannot find any good examples or case studies for it.
    Would you have some documents you could send me?
    Thank you in advance,
    Naoki
    richard
    ZvKpSyiBvRGXh
    « Reply #14 on: May 10, 2009, 02:20:46 PM »
  • NBxkil dkv7Rq29nVvzm74lApqSw
