" /> Stream Manager (SM) Connections Tab in CME:SIP server vs Config server - Genesys CTI User Forum
Author Topic: Stream Manager (SM) Connections Tab in CME:SIP server vs Config server  (Read 3563 times)
Offline kapusta1152
What is the correct information for Stream Manager (SM) Connections Tab in CME?
1. I saw that some SM connected to Message Server (msg) and configuration server.
2. Other SM    has connection to SIP server and msg  server.
Re: Stream Manager (SM) Connections Tab in CME:SIP server vs Config server
« Reply #1 on: November 18, 2010, 08:54:39 PM »
Well you can find that info on the deployment documentation. CfgServer....why???
Message Server for logs. SipServer...no...communication is done via SIP...
Offline kapusta1152
« Reply #2 on: November 22, 2010, 03:23:35 PM »
Thanks for your feedback, but what do you think about potential negative effect of these “extra connections” to configuration and SIP servers?
RoboH
« Reply #3 on: December 17, 2010, 09:43:12 PM »
Hi
The negative effect can come if the SM won't ignore them.
The cavagnaro is right. There is no need for it.
The SM application is configured in the treatment DN of switch Annex -> TServer -> contact. The TServer SIP checks the treatment DN if required in routing to play some treatment with SM.
From DN options the TServerSIP starts communication against the SM.
It is not necessary to configure additional connections in TServerSIP or SM.
Robert
Offline sunbabu15
« Reply #4 on: December 21, 2010, 06:00:47 PM »
Hi Robo,
That means SIP-tsrvr will pick only those DN's having Contact options under Annex->Tsrvr, for playing some treatment with SM as part of the routing.
Regards,
« Reply #5 on: December 21, 2010, 08:56:05 PM »
[quote author=sunbabu15 link=topic=6022.msg26372#msg26372 date=1292954447]
Yes, SIP Server looks only for DNs of type Voice IP Service with correct Annex tab (see documentation for list of mandatory parameters).
