" /> Reg: oracle 9i compatibility with T-server 7.6 - Genesys CTI User Forum
Author Topic: Reg: oracle 9i compatibility with T-server 7.6  (Read 3297 times)
Offline JJR
« on: March 02, 2011, 04:37:20 AM »
I have couple of questions with respect to oracle database and t-server components. Could any one help me out here.
Currently we are running with framework 7.2 with oracle9i databases. We are planning to upgrade the database to 10g.
1. Is the existing framework & T-server compatible with Oracle10g?
2. If we upgrade the T-server component alone 7.6, and keeping the database at oracle9i, Does this option works? and does it support call concentrator.
3. Is it compatible if we upgrade the T-server to 7.6 and database to oracle 10g.
Thank you for your assistance.
Thanks - JJR
Re: Reg: oracle 9i compatibility with T-server 7.6
« Reply #1 on: March 02, 2011, 05:56:29 AM »
Tserver...Database....Tserver....Database....T....D....t...d...t...
TServer has nothing to do with a DataBase, TServer is the media connector only. You need to check DBServer component compatibility. Moving to 7.6 would require a DB reconfiguration, check with your Genesys provider on how will this impact your environment.
DBServer 7.6 does support Oracle 10g, check system documentation
« Reply #2 on: March 02, 2011, 08:26:59 AM »
Hi JJR,
As Cav wrote, T-Server has no connection to a database but there are other Genesys components that interoperability with Oracle 10g must be checked.
[quote]Is the existing framework & T-server compatible with Oracle10g?[/quote]
Yes - see my previous sentence and Cavagnaro's post
[quote]If we upgrade the T-server component alone 7.6, and keeping the database at oracle9i, Does this option works? and does it support call concentrator.[/quote]
I assume you have Call Concentrator release 7.0 as there is no 7.2 release. T-Server 7.6 is newer than CCon 7.0 so I assume no interoperability tests were run. I would recommend you to ask Genesys Support about support of such deployment.
[quote]Is it compatible if we upgrade the T-server to 7.6 and database to oracle 10g.[/quote]
Again, T-Server is 'out of game' here ;). Both DBServer 7.2 and CCon 7.0 support Oracle 10g.
Offline JJR
« Reply #3 on: March 02, 2011, 12:11:26 PM »
Thank you for the detailed information!!. It gave me a lot of information.
Could you please provide me the system document if you have ,where i can get the details of the compatible genesys components & their version for Oracle 10g.
Thanks - JJR
« Reply #4 on: March 03, 2011, 08:57:20 AM »
JJR,
Sorry but I can't send you any Genesys document. You would need to download it by yourself from Genesys Support website or ask you Genesys partner to download it for you.
Document name is 'Genesys Supported Operating Environment Reference Manual'.
