" /> Find amount of calls that can access your IVR ports at the same time - Genesys CTI User Forum
Author Topic: Find amount of calls that can access your IVR ports at the same time  (Read 3210 times)
Offline wim1981
Goodmorning
Little question:
How can i find the amount of calls that can access one ivr port at the same time?
I saw in Configuration Manager the TServer_GVP_1 license option. "num_of_license.
Is that the amount of calls that can access one port?
Greets
Wim
Re: Find amount of calls that can access your IVR ports at the same time
« Reply #1 on: October 30, 2014, 09:09:48 AM »
Do you mean VTP or access to the GVP through the trunk? In first case you can use standard reports (CCA). In second case, you can use reporting server for GVP or build your own reporting engine based on sinks from GVP components.
Offline wim1981
« Reply #2 on: October 30, 2014, 09:23:00 AM »
[quote author=Kubig link=topic=8577.msg37795#msg37795 date=1414660188]
I think it is the acces to the GVP. There are ivr ports that accept te calls. But what i want to know is how many calls can access one port?
« Reply #3 on: October 30, 2014, 09:24:19 AM »
One port can access just one call at one moment
Offline wim1981
« Reply #4 on: October 30, 2014, 09:27:32 AM »
[quote author=Kubig link=topic=8577.msg37797#msg37797 date=1414661059]
aha, so if i'm raesoning. I have 15 ports. So my IVR can have 15 calls at the same time.
« Reply #5 on: October 30, 2014, 09:48:42 AM »
Exactly.
PS:  You can find it out within documentations.
Offline wim1981
« Reply #6 on: October 30, 2014, 10:06:37 AM »
[quote author=Kubig link=topic=8577.msg37799#msg37799 date=1414662522]
Exactly.
Ok thanks a lot.
Greets
