" /> CCPulse+ not showing "Create historical view" - Genesys CTI User Forum
Author Topic: CCPulse+ not showing "Create historical view"  (Read 3955 times)
Gabriel Madoz
It's strange what is happening because some days ago this feature was working well, and since yesterday (we don't know why) this option appears greyed (unavailable). We troubleshoot the problem and we could see that we have connection to ETL_Service and DAP_for_Datamart on CCPulse+ app.
So, we test to restart StatServer_CCPulse, ETL_Service.....reinstall CCPulse+ but still not works.
Thanks for any help
Mark
CCPulse not showing
  • I am having the same problem and still searching for a resolution. the option always comes on whenever the etl service is installed/reinstalled, but as soon as I stopped the entire solution, the option wouldn't come on anymore. the doc says CCP+ doesn't maintain a persistent connection to datamart, but doesn't says how to reconnect back....
    ecki
    CCPulse not showing
  • Hi.
    Could you tell me please, which version of CCP do you have?
    Gabriel Madoz
    CCPulse not showing
  • Well, finally we found a solution.
    Ok, CCPulse+ must have a connection to ETL_Service and ETL_Service must have a connection to DAPforDatamart.
    Also DAPforDatamart ..... MUST..... appear as component of the Enterprise Routing Solution. (I used the Genesys Wizard)
